Uhlig JME 2005 Sign-Restricted IRF's for VAR
Postby TomDoan » Fri Jun 01, 2012 9:47 am
This is a set of replication files for Uhlig(2005), "What are the effects of monetary policy on output? Results from an agnostic identification procedure", Journal of Monetary Economics, vol 52, no 2, 381-419. This extracts a monetary policy shock from a six-variable VAR based upon sign-restrictions on the responses of the variables. It uses two different approaches: a rejection method of drawing shocks then rejecting those that fail to meet the sign restrictions, and a penalty function approach which severely penalizes responses which have the wrong sign. Other than the uhlig1 program, all of these first draw VAR coefficients using standard methods before analyzing the shocks.
We've added two often requested calculations to those done in the paper: uhlig2 with shocks computes a range of historical shocks based upon the weights on the standard residuals, and uhlig2 with history does the historical decomposition of the effects of the drawn shock.
uhlig1.rpf
Rejection method - applied to OLS estimates
(3.21 KiB) Downloaded 101 times
uhlig2.rpf
Rejection method with draws for VAR coefficients. Impulse responses and FEVD.
(4.67 KiB) Downloaded 94 times
uhlig2 with shocks.rpf
Same as uhlig2.rpf but computes the shocks themselves
(5.03 KiB) Downloaded 71 times
uhlig2 with history.rpf
Same as uhlig2.rpf but does historical decomposition
(7.8 KiB) Downloaded 77 times
uhlig3.rpf
Penalty function method
(4.21 KiB) Downloaded 63 times
uhligdata.xls
Data file
(96 KiB) Downloaded 101 times
Return to Examples and Sample Code
Who is online
Users browsing this forum: No registered users and 2 guests
