WESTCHOTEST - Robust Q Statistic
Postby TomDoan » Wed Mar 14, 2012 2:19 pm
This computes the modified Ljung-Box test, robust to heteroscedasticity, proposed in West and Cho(1995), "The predictive ability of several models of exchange rate volatility," Journal of Econometrics, vol. 69, no 2, 367-391. The standard Q assumes (for its asymptotics) that E(e(t)^2e(t-j)^2)=s^4 for all j where s^2 is the variance of the e process. This allows empirical estimates of those expectations instead.
westchotest.src
Procedure file
(2.54 KiB) Downloaded 50 times
@WestChoTest( options ) series start end
Parameters:
series series to analyze
start end range of <<series>> to use. By default, the defined range of <<series>>
Options:
NUMBER=# of lags to use [roughly 2 sqrt(# of observations]
DFC=degrees of freedom correction for Q [0]
[PRINT]/NOPRINT
Return to RATS Procedures
cron
