Lumsdaine - Pappel Unit root
Postby FaeK » Tue Mar 13, 2012 6:45 am
Hi all,
In implementing lumsdaine and Papell unit root test I get this messege: (## CP18. LPUNIT is not the Name of a PROCEDURE. (Did you forget to SOURCE?)
>>>>@LPUnit(<<<<)
this is the procedure I implemented: @LPUnit(BREAK = INTERCEPT, NBREAKS=2, METHOD=AIC) series
I am using RATS 7.3. I do not what is wrong?
many thanks in advance, if anyone provides help.
Faek
FaeK
Re: Lumsdaine - Pappel Unit root
Postby moderator » Tue Mar 13, 2012 9:43 am
You need to make sure that you have the LPUNIT.SRC file installed somewhere (it should have been installed along with RATS automatically). Then, either make sure that RATS can find the LPUNIT.SRC file automatically, or add an explicit SOURCE instruction (with the appropriate path) to your code to compile the procedure file before calling the procedure.
See Section 16.2.1 (Using Existing Procedures) in the User's Guide for details on this.
Tom Maycock
Estima
moderator
Site Admin
Postby FaeK » Thu Mar 15, 2012 5:29 am
Thanks very much for your help. RATS help is amazing.
Kinds
Faek
FaeK
