Graph with series differentiate by colors and symbols
Postby Aktar » Wed Jan 25, 2012 3:55 pm
I don't find the code needed for differentiate series with symbol and in the same time with color on a same graph. The style symbols give the same output.
Thank You.
Aktar
Re: Graph with series differentiate by colors and symbols
Postby moderator » Wed Jan 25, 2012 4:43 pm
If you want series to have both different colors and different symbols, you can use the Graph Style Sheet feature. This allows you to create your own style definitions, saved in a text file, which you read in using OPEN and GRPARM(IMPORT=...) instructions.
If you have version 8, see the Introduction (Section 3.16 in particular) for details.
Tom Maycock
Estima
moderator
Site Admin
Postby randerson » Tue May 14, 2013 4:38 pm
Might someone post the 6-digit hex codes for the line default line colors? I did not see these in the manual. These appear to be needed when using graph style sheets to add symbols to colored lines.
randerson
Postby TomDoan » Tue May 14, 2013 9:21 pm
These are the colors of the first nine:
  1. RGB_BLACK 000000
  2. RGB_BLUE 0000FF
  3. RGB_GREEN 00FF00
  4. RGB_RED FF0000
  5. RGB_CYAN 00FFFF
  6. RGB_MAGENTA FF00FF
  7. RGB_YELLOW FFFF
  8. RGB_ORANGE FF8000
  9. RGB_BROWN 804000
Return to Graphics, Reports, and Other Output
Who is online
cron
