Crash after changing dimension of array
Postby jonasdovern » Thu Jan 19, 2012 8:34 am
I have the following problem: Consider the following procedure that I wrote for demonstration purposes:
procedure testproc
   option ser[vec[vec]] array
   option integer       size
   local ser[vec[vec]] larray
   local vec[vec]      lvec
   local integer       k i
   dim lvec(size)
   gset larray 1 10 = lvec
   do k=1,10
      do i=1,size
         dim larray(k)(i)(5)
         comp larray(k)(i) = %const(1.)
   end do k
   gset array 1 10 = larray(t)
end procedure
RATS crashes (shuts down completely under Windows) without giving an error messages whenever I run this twice with changing "size".
decl ser[vec[vec]] test
@testproc(array=test,size=5)
@testproc(array=test,size=4)
I would like the procedure to work when the output array hasn't been used before - but also when it has been used before with another dimension. Is there a way of avoiding these crashes?
jonasdovern
