Bjornland-Leitemo JME 2009
Postby TomDoan » Wed Jun 29, 2011 1:28 pm
This is a replication file for Bjørnland, Hilde C. and Kai Leitemo (2009): "Identifying the Interdependence between US Monetary Policy and the Stock Market", Journal of Monetary Economics, vol 56, pp 275-282. This uses the ShortAndLong procedure (http://www.estima.com/forum/viewtopic.php?f=7&t=1095) to estimate a structural VAR on a five variable system, and includes Monte Carlo integration of the IRF's.
b_l_jme_2009.rpf
Program file
(7.35 KiB) Downloaded 432 times
Data_Bjornland_Leitemo_JME_2009.xls
Data file
(47.5 KiB) Downloaded 306 times
Re: Bjornland-Leitemo JME 2009
Postby Tony » Wed Jun 29, 2011 9:26 pm
When I try to run the code you posted here, I got the following massage.
20. INTR{4} NA
21. Constant NA
F-Tests, Dependent Variable INTR
Variance is Zero. Tests Can't be Done
## EQ4. Equation %MODELEQN(VARSTO Has At Least One Undefined or NA Coefficient
What is the problem here, how to handle it?
I am using Rats8.0.
Tony
Postby pangchunyang » Thu Jun 30, 2011 10:25 am
At first, I also come across this problem, but when I rerun the prog, this info is gone. So, you just rerun it.
However, in the 2nd time of runing this prog, a warning came out as
## OP3. This Instruction Does Not Have An Option FAC
>>>>teps=nsteps,factor=<<<<
What is the problem with my RATS pro 7.3?
pangchunyang
Postby TomDoan » Thu Jun 30, 2011 12:59 pm
pangchunyang wrote:At first, I also come across this problem, but when I rerun the prog, this info is gone. So, you just rerun it.
You need the updated VARIRF procedure:
http://www.estima.com/forum/viewtopic.php?f=7&t=1114
Postby pangchunyang » Fri Jul 01, 2011 5:45 am
Thank you, Tom! It works well and nearly exactly the same with the results in the original paper.
pangchunyang
cron
