DMARIANO - Diebold-Mariano test (revised)
Re: DMARIANO - revision of Diebold-Mariano procedure
Postby TomDoan » Fri Oct 01, 2010 6:17 am
test stat P(DM>X)
-1.0220 0.00004
1.0220 0.99996
here i accept the H0 coz the 1.0220 is smaller than critical value of 1.645 at 10% significant level.
You shouldn't have to look up critical values---the whole point of using the %ttest function is to get the significance level so you don't have to check tables. However, that looks like a typo, since the other numbers are +/-10.xxxx, not +/- 1.xxxx.
test stat P(DM>X)
-10.0220 0.99996
10.0220 0.00004
or
test stat P(DM>X)
-10.0220 0.00004
10.0220 0.99996
If you're asking which you want, it's the first. Positive numbers cast doubt on a set of forecasts. The first of these will clearly indicate that the first set of forecasts is better than the second. The null in the first line is that f1=f2 vs f2 better than f1; and the null in the second is that f1=f2 vs f1 better than f2.
Postby wendyyuan » Mon Oct 04, 2010 5:22 am
Thanks, Tom
As you said ‘If you're asking which you want, it's the first. Positive numbers cast doubt on a set of forecasts. The first of these will clearly indicate that the first set of forecasts is better than the second. ’
Does it mean we only check out the forecast that produces negative test stats? Given negative test stats, when the P value is larger than 95% or less than 5%, we accept H1; when it is out of the two ranges, we fail to reject H0?
wendyyuan
Postby TomDoan » Mon Oct 04, 2010 7:23 am
What you have are two separate one-tailed tests, not one two-tailed test. The only case where you might reject one forecasting procedure in favor of the other is where the difference in the test statistics is positive; where it's negative, you're in the wrong tail to reject.
Postby TWG » Fri Mar 25, 2011 12:21 pm
Tom, I have a question about how to interpret the results of Diebold and Mariano test.
Diebold-Mariano Forecast Comparison Test
Forecasts of X1 over 2006:01 to 2010:12
Forecast MSE Test Stat P(DM>x)
NAIVE1 5.66636695 1.0928 0.13724
M1P1 3.94101250 -1.0928 0.86276
Here in the first line H0) NAIVE1 = M1P1 and H1) M1P1 Better than NAIVE1.
Therefore accept the hypothesis that M1P1 is better than NAIVE1.
But in the second line of the test is: :
H0) NAIVE1 = M1P1 and H1) NAIVE1 Better Than M1P1.
Therefore accept the hypothesis that NAIVE1 is better than M1P1.
Given this, how can I interpret what is the best result to say that one forecast are better than other.
Regards
W
TWG
Postby TomDoan » Fri Mar 25, 2011 12:36 pm
TWG wrote:Tom, I have a question about how to interpret the results of Diebold and Mariano test.
Not at conventional significance levels, but there's certainly some evidence of it.
TWG wrote:But in the second line of the test is: :
Why would you reject H0? The p-value is huge.
TWG wrote:Given this, how can I interpret what is the best result to say that one forecast are better than other.
Regards
W
Postby TWG » Fri Mar 25, 2011 12:45 pm
Tom, thanks very much for the quick reply. Another more basic question. When I compare forecast for 12 steps ahead. The correct is to put lags, like this
@dmariano(lags=11) GDP naive12 M1P12
Or this is not necessary?
TWG
Postby TomDoan » Fri Mar 25, 2011 1:21 pm
TWG wrote:Tom, thanks very much for the quick reply. Another more basic question. When I compare forecast for 12 steps ahead. The correct is to put lags, like this
The proper use of this is with LAGS=11 for 12 step ahead forecasts.
Postby TWG » Fri Mar 25, 2011 1:44 pm
Tom, for the Granger-Newbold forecast comparison test, for compare forecast 12 steps ahead, the syntax is the same?.
@GNewbold(lags=11) GDP naive12 M1P12
Regards
W
TWG
Postby TomDoan » Fri Mar 25, 2011 3:44 pm
TWG wrote:Tom, for the Granger-Newbold forecast comparison test, for compare forecast 12 steps ahead, the syntax is the same?.
Regards
W
No. The Granger-Newbold test doesn't allow for serial correlation in the forecast errors.
Re: DMARIANO - Diebold-Mariano test (revised)
Postby IRJ » Wed Feb 20, 2013 7:52 am
Are there any examples of using the clarforetest.src procedure? I'm trying to it unsuccessfully. I want to compare two nested models. The first equation is a random walk, while the second is VECM with a cointegration vector of [1,-1].
When I do:
@forecastproc(scheme=2) 2002:01 libor1mus
#libor1mus{1}
#constant libor1mus-emratentl dlibor1mus{1 to 3} demratentl{1 to 3}
I get the error message "## SR3. Tried to Use Series Number 142, Only 124 Are Available".
In fact, looking at the procedure, I think the procedure does the forecasting itself, while I already have the forecasts I'm interested in comparing. Is there a simpler way to obtain the Clark and McCraken (2001) test statistic along the lines of what is done in the DMARIANO.SRC procudure by just inputting the actual and the 2 forecast series?
IRJ
Previous
Return to RATS Procedures
Who is online
