GLSDetrend - local to unity detrending
Postby TomDoan » Fri Aug 29, 2008 10:07 am
This is a local to unity detrending routine allowing for various types of trends, including ones with a break at a known point.
* @GLSDetrend(options) y start end yd
* Local to unity GLS detrending routine. Includes the ERS cases (no constant,
* constant, constant and trend) as well as the Perron and Rodriguez cases
* (constant and trend with a single break). This just does the detrending, not the
* actual unit root test(s). For models with breaks, you need to input the break
* point.
* Parameters:
*   y  = input series
*   start end = range to detrend [by default, defined range of y]
*   yd = output detrended series (required)
* Options:
*   DET=NONE/[CONSTANT]/TREND
*   BREAK=[NONE]/INTERCEPT/TREND/BOTH
*    Note - Perron and Rodriguez don't include the case with just a break in
*    the intercept.
*   TB=entry for break (required if any of the BREAK options are used). The dummies
*     are (t>=TB) for the intercept and max(t-TB,0) for the trend, so the structure
*     is different at TB than at TB-1.
*   CBAR=(positive) value for GLS rho=1-cbar/T. Default depends upon the model.
*   U/[NOU]  U indicates unconditional distribution (for U0) is to be used
* References:
*   Elliott, Rothenberg and Stock(1996), "Efficient Tests for an Autoregressive Unit
*    Root", Econometrica, vol 64, no. 4, pp 813-836.
*   Perron and Rodriguez(2003), "GLS Detrending, Efficient Unit Root Tests and
*    Structural Change",  Journal of Econometrics, vol 115, pp 1-27.
* Variables Defined:
*   The standard regression variables can be used. The regressors are in order
*     1, t, intercept break dummy, trend break dummy
* Revision Schedule:
*   08/2008 Written by Tom Doan, Estima.
procedure GLSDetrend y start end yd
type series  y *yd
type integer start end
option choice  det      2  none constant trend
option choice  break    0  none intercept trend both
option integer tb
option switch  u        0
option real    cbar
local integer        startl endl nobs i
local vect[series]   z za
local series         ya yd
local real rhot      initialsf
if .not.%defined(y) {
   disp "Syntax: @GLSDetrend(options)  Y start end yd"
   return
if .not.%defined(yd) {
   disp "Syntax: @GLSDetrend(options)  y start end YD(required)"
   return
inquire(series=y) startl<<start endl<<end
stats(noprint) y startl endl
if %nmiss>0 {
   disp "@GLSDetrend can't be used on data with missing values"
   return
compute nobs=%nobs
if (break>=2) {
   if .not.%defined(tb) {
      disp "@GLSDetrend(break=...) requires option TB to set break point"
      return
   * Break models always include 1 and t
   dim z(3+(break==4))
   compute rhot=%if(%defined(cbar),1-abs(cbar)/nobs,1-23.0/nobs)
else
if (det==3) {
   dim z(2)
   compute rhot=%if(%defined(cbar),1-abs(cbar)/nobs,%if(u,1-10.0/nobs,1-13.5/nobs))
else
if (det==2) {
   dim z(1)
   compute rhot=%if(%defined(cbar),1-abs(cbar)/nobs,%if(u,1-10.0/nobs,1-7.0/nobs))
else {
   dim z(0)
   compute rhot=%if(%defined(cbar),1-abs(cbar)/nobs,1-10.0/nobs)
compute initialsf=%if(u,sqrt(1-rhot^2),1.0)
if %rows(z)>=1
   set z(1)  startl endl = 1.0
if %rows(z)>=2
   set z(2)  startl endl = t-startl+1
if %rows(z)>=3 {
   if break<>3
      set z(3) startl endl = t>=tb
   else
      set z(3) startl endl = %max(t-tb,0.0)
   if break==4
      set z(4) startl endl = %max(t-tb,0.0)
dim za(%rows(z))
do i=1,%rows(z)
   set za(i) startl endl = %if(t==startl,initialsf*z(i),z(i)-rhot*z(i){1})
set ya startl endl = %if(t==startl,initialsf*y,y-rhot*y{1})
linreg(noprint) ya startl endl
# za
set yd startl endl = y-%dot(%xt(z,t),%beta)
Re: GLSDetrend - local to unity detrending
Postby Anna » Wed Oct 14, 2009 8:41 am
Hey Tom,
I think there is a minor mistake in that program, concerning the case of a break in the intercept only. As far as I can see, the program takes c=23 in that case, but it should actually be 13.5 as in Elliot et. al. if I understand Perron & Rodriguez correctly. They do not consider a break in the level only because this is "just a special case" of Elliot et al.'s slowly evolving deterministics (or so). If this was the case, I think Elliots c-value should be taken and not Perron & Rodriguez, right?
Best wishes
Anna
Anna
Postby Anna » Wed Oct 14, 2009 12:14 pm
And another question: I am wondering, why do you write this:
Why not just "ut" as defined by the last linreg command?
Anna
Postby TomDoan » Wed Oct 14, 2009 3:26 pm
Anna wrote:Hey Tom,
Best wishes
Anna
Although it allows for the BREAK=INTERCEPT option, it won't do it. All the BREAKs are either trend or trend + intercept.
Postby TomDoan » Wed Oct 14, 2009 3:27 pm
Anna wrote:And another question: I am wondering, why do you write this:
The previous linreg is on GLS transformed data, but what's needed for yd is the calculation on the original data.
Return to RATS Procedures
