Rolling CHOW TEST
Rolling CHOW TEST
Postby kanishkpanchal » Fri Nov 05, 2010 4:30 pm
Hi All,
I wanted to get some suggestions on how to do a "ROLLING CHOW TEST" in RATS when the date of structural break is not known. In the final results, we should get the test statistic for all the observations (am I right?). I am new to RATS coding. I tried to go through the manual but it has examples only for known structural dates.
Your help will be greatly appreciated.
kanishkpanchal
Re: Rolling CHOW TEST
Postby TomDoan » Mon Nov 08, 2010 2:33 pm
Use the @APBREAKTEST procedure or the @REGHBREAK procedure. I've attached a program (and its data file) which use @APBREAKTEST and also do the calculation of break test statistics using HAC standard errors.
onebreak.rpf
(2.48 KiB) Downloaded 187 times
ch15_oj.rat
(16.75 KiB) Downloaded 168 times
Postby kanishkpanchal » Fri Nov 19, 2010 5:51 pm
Thank you so much!
kanishkpanchal
Who is online
