GIBBSVAR: Procedure for VAR estimation via Gibbs sampling
Postby tclark » Fri May 09, 2008 11:53 am
Drawing on code from Tom Doan, this procedure can be used to estimate (and obtain forecasts from) VARs with Litterman priors via Gibbs sampling. The file itself provides documentation. Be forewarned that there are various aspects of the procedure that could be made more user friendly or coded more efficiently.
* PROCEDURE:  GibbsVAR.src
* syntax: @GibbsVAR(options) y stpt endpt prenobs lags prelags ndraws burndraws meanfirstlag Pipriorprec shrinkage fcper &
*                   PiRes SigmaRes ForecastRes
*           Written by Todd Clark of the Federal Reserve Bank of Kansas City, drawing on code by Tom Doan
* PURPOSE:  Using Gibbs sampling to compute posterior distributions of the parameters of a VAR, along with forecasts
*           The model/estimator is the normal-diffuse of Kadiyala and Karlsson (1997), "Numerical Methods for Estimation and
*           Inference in Bayesian VAR Models," Journal of Applied Econometrics, pp 99-132
* NOTES:  (1) priors for slope coefs of VAR, Pi(L), are handled with modified Litterman approach, without options
* INPUT:    y                  vector of series of observed endogenous variables
*           stpt               starting point of estimation (meaning observations back to stpt-lags) serve as initial values
*           endpt              end point of estimation sample
*           prenobs            number of observations in pre-sample to use for setting priors.  If the actual number available
*                                falls short of prenobs, the priors (in this case, just the prior variance on Pi) are pulled
*                                from values that need to be defined from outside the procedure.
*           lags               Lag length of the VAR.
*           prelags            lag of AR models used in pre-sample estimation that pins down some priors
*           ndraws             number of total posterior draws
*           burndraws          number of burnin draws
*           MeanFirstLag       Prior mean vector for first own lag (Pi), as in Litterman/Minneapolis convention
*           Pipriorprec        If there are enough data in the training sample, the prior precision is estimated based on the pre-sample;
*                                  if there isn't enough data, the prior precision needs to be given (input) in Pipriorprec
*           Shrinkage          Hyperparameters in prior. Smaller values produces priors which are more concentrated around zero.
*                              - Shrinkage(1): Baseline tightness parameter.
*                              - Shrinkage(2): Own/others shrinkage
*                              - Shrinkage(3): Lag length shrinkage parameter.
*                              - note:  putting loose prior on constant
*           fcper              number of periods ahead to forecast (set to 0 to skip forecasting)
* OUTPUT:   PiRes              vector of post-burn draws of Pi
*           SigmaRes           vector of post-burn draws of Sigma
*           ForecastRes        rect array of time series of forecasts, covering post-burn draws and num of variables
*   -Options:
*     printmean/[noprintmean] : display posterior means and standard deviations (default is noprint)
* FIRST:    2008-05-09
*********************************** declarations
procedure GibbsVAR y stpt endpt prenobs lags prelags ndraws burndraws meanfirstlag Pipriorprec shrinkage fcper PiRes SigmaRes ForecastRes
type vec[ser] y
type int stpt endpt prenobs lags prelags ndraws burndraws fcper
type vec meanfirstlag shrinkage
type vec[rec] *PiRes
type vec[symm] *SigmaRes
type rec[ser] *ForecastRes
type symm *Pipriorprec
** start here
option switch prmean 0
* note that what this local stuff is used for becomes clearer below
local int nvar draws_burn ncoef i j l draws nobs rawstpt ystpt availprenobs
local vec[ser] forecasts
local vec univar ux Pihat_ols Pimean Pidraw Pipriormean Pidiff
local symm hx wparm hb Sigma invSigma xxxols xx olssigma
local rec minnmean minnprec Pidraw_mat fx meanmat sdmat Piover
local model varmodel
*********************************** dimensioning
***** key dimensions
comp nvar = %rows(y)
comp ncoef = nvar*lags+1              ;* number of coefficients in each equation
comp draws_burn = ndraws - burndraws
***** stuff stored, for all post-burn draws
dim PiRes(draws_burn) SigmaRes(draws_burn) ForecastRes(draws_burn,nvar)
***** stuff for Pi computations
dim Pidraw(ncoef*nvar) ;* vector for drawing Pi
dim univar(nvar)  ;* for storing univariate st devs used in setting Pi prior standard deviations
dim Pimean(nvar*ncoef) Pidiff(nvar*ncoef) ux(nvar*ncoef) ;* used for drawing innovations
overlay Pidiff(1) with Piover(ncoef,nvar)
***** stuff for Pi prior
comp minnmean = %zeros(ncoef,nvar)
comp minnprec = %zeros(ncoef,nvar)  ;* precision^2 = inverse of the variance
*********************************** setting priors (Minneapolis prior on slope coefs Pi) from pre-sample estimates
*********************************** Note:  precision is only set if the available sample size (availprenobs)
*********************************** is at least as great as specified by the inputs (prenobs+prelags).
*********************************** If the sample isn't big enough, precision is left at the value provided in the
*********************************** procedure call.
comp rawstpt = 0
do i = 1,nvar
 inquire(series=y(i)) ystpt *
 comp rawstpt = %imax(rawstpt,ystpt)
comp availprenobs = stpt-1 - rawstpt + 1
if availprenobs>=(prenobs+prelags)
  do i = 1,nvar
    linreg(noprint) y(i) stpt-prenobs stpt-1
    # constant y(i){1 to prelags}
    comp univar(i)=sqrt(%seesq)  ;* %rss/%nobs
***** setting mean and precision
do i=1,nvar
 do j=1,nvar
  do l=1,lags
   comp minnmean((j-1)*lags+l,i)=(i==j.and.l==1)*MeanFirstLag(i)
    comp minnprec((j-1)*lags+l,i)=univar(j)/univar(i)*%if(i==j,float(l)**shrinkage(3)/shrinkage(1),float(l)**shrinkage(3)/(shrinkage(2)*shrinkage(1)))
  end do l
 comp minnmean(ncoef,i)=0.0  ;* flat prior on intercept
  comp minnprec(ncoef,i)=1./(1000.*univar(i))
comp Pipriormean=%vec(minnmean)         ;* prior mean, in vector form
  ewise minnprec(i,j)=minnprec(i,j)**2
  comp Pipriorprec=%diag(%vec(minnprec))  ;* inverse of prior variance matrix
*********************************** MCMC
smpl stpt endpt  ;* sample for estimation
***** setting up VAR used in loop, and obtaining OLS estimates of VAR and related moments used in Gibbs sampler
system(model=varmodel)
variables y
lags 1 to lags
kfset xxxols
estimate(noprint)
comp Pihat_ols=%vec(%modelgetcoeffs(varmodel))
comp nobs = %nobs
comp olssigma = nobs*%sigma
comp xx = inv(xxxols)
************************************ setting initial values needed in MCMC
comp sigma=%ranwisharti(%decomp(inv(olssigma)),nobs)
do draws=1,ndraws
 ********************** STEP 1:  drawing Pi (VAR slope coefs)
 ****** drawing slope coefficients, and reassigning them to model
 comp invSigma = inv(sigma)
 comp hb=%kroneker(invsigma,xx)
 comp hx=inv(hb+Pipriorprec)
 comp Pimean=hx*(Pipriorprec*Pipriormean+hb*Pihat_ols)
 comp fx=%decomp(hx)
 comp Pidraw = Pimean+fx*(ux=%ran(1.0))
 comp Pidraw_mat = %vectorect(Pidraw,ncoef)
 ********** STEP 2: Draw Sigma
 comp Pidiff=Pidraw-Pihat_ols
 comp wparm=olssigma+%mqform(xx,Piover)   ;* remember that wparm computed this way (as in K-K) is the same as it would be computed as the sum of squared residuals
 comp sigma=%ranwisharti(%decomp(inv(wparm)),nobs)
 ******* storage of MCMC draws, and construction of foreasts for storage
 if draws>burndraws
   *** storing everything but forecasts
   comp PiRes(draws-burndraws) = Pidraw_mat
   comp SigmaRes(draws-burndraws) = Sigma
   *** construction and storing forecasts
   if fcper>0
     comp %modelsetcoeffs(varmodel,Pidraw_mat)
     simulate(model=varmodel,results=forecasts) * fcper endpt+1 sigma
     do i = 1,nvar
      set forecastRes(draws-burndraws,i) endpt+1 endpt+fcper = forecasts(i){0}
end do draws
if prmean==1
dis ''
** MCMC mean and standard deviation for Pi
comp meanmat = %zeros(%rows(PiRes(1)),%cols(PiRes(1)))
comp sdmat = %zeros(%rows(PiRes(1)),%cols(PiRes(1)))
do i = 1,draws_burn
 comp meanmat = meanmat + PiRes(i)
 comp sdmat = sdmat + PiRes(i).*PiRes(i)
comp meanmat = meanmat*(1./draws_burn)
comp sdmat = %sqrt(sdmat*(1./draws_burn) - meanmat.*meanmat)
dis 'Pi mean ='
dis ###.### meanmat
dis 'Pi st dev ='
dis ###.### sdmat
** MCMC mean and standard deviation for Sigma
comp meanmat = %zeros(%rows(SigmaRes(1)),%cols(SigmaRes(1)))
comp sdmat = %zeros(%rows(SigmaRes(1)),%cols(SigmaRes(1)))
do i = 1,draws_burn
 comp meanmat = meanmat + SigmaRes(i)
 comp sdmat = sdmat + SigmaRes(i).*SigmaRes(i)
dis 'Sigma mean ='
dis ###.### meanmat
dis 'Sigma st dev ='
dis ###.### sdmat
(post edited to change the name of the procedure to GIBBSVAR, to distinguish it from the old VAR procedure available on the Estima web site).
Todd Clark
Economic Research Dept.
tclark
Return to RATS Procedures
Who is online
