LSUnit (LM unit root test with multiple breaks)
Postby TomDoan » Wed Mar 05, 2008 6:07 pm
This implements a number of varieties of LM unit root tests allowing for 0, 1, 2 or even more structural breaks of one of two varieties, as described in Lee and Strazicich(2003), "Minimum LM Unit Root Test with Two Structural Breaks," Review of Economics and Statistics, vol 85, no. 4, pp 1082-1089. This differs slightly from Lee and Strazicich's Gauss code as the lag pruning regressions use a common estimation range (from maxlag+1 on) rather than the lag+1 samples used in the Gauss code. The method chosen here would make it simpler to change the pruning method to an alternative like minimum AIC.
I incorporated a number of suggestions made by Junsoo Lee regarding the output, which includes output of all the coefficients other than the auxiliary lags.
Note that this can take a very long time for two or more breaks if the data set is large (>500 observations). The calculation time goes up with T^(# of breaks+1), so with 1000 data points, you're looking at roughly 1000 times as long to do two breaks as one.
Tom Doan
Estima
Procedure file:
lsunit.src
(9.67 KiB) Downloaded 654 times
Example:
source lsunit.src
data(format=free,unit=input,org=cols) 1 38 year x
1960    11508
1961    11369
1962    11930
1963    12636
1964    13194
1965    13264
1966    13875
1967    14193
1968    15172
1969    15712
1970    16316
1971    16872
1972    17563
1973    18489
1974    18606
1975    18741
1976    18728
1977    18480
1978    19303
1979    19682
1980    19968
1981    20271
1982    19464
1983    20127
1984    20712
1985    21438
1986    21719
1987    22443
1988    23040
1989    22995
1990    22226
1991    21921
1992    22367
1993    23176
1994    24144
1995    24818
1996    25077
1997    25608
set logx = log(x)
@lsunit(breaks=2,pi=.10,lags=5,method=gtos,model=crash) logx
@lsunit(breaks=2,pi=.10,lags=5,method=gtos,model=break) logx
Reason: Replace in-line code with file
Doubt in Lee-Strazicich Unit Root Test
Postby Jose » Sat Apr 26, 2008 12:13 pm
Hello TomDoan!
I'm using the procedure of rats to "Lee-Strazicich Unit Root" and I have a doubt about the output. An Example:
Lee-Strazicich Unit Root Test, Series QCVEN
Regression Run From 1971:03 to 2006:04
Observations 141
Crash Model with 1 breaks
With 1 chosen from 5
Variable Coefficient Std Error
S{1} -0.0896 -2.7737
Constant 0.0062 0.9871
D(1986:04) 0.2750 4.2558
My doubt is whether the numbers in the column "Std Error" are standard errors rather than t-student statistics. This numbers are really the standards errors?
Thanks for your attention,
Anchieta
Obs: I have post this same message in other topic, ok?
Jose
Postby TomDoan » Mon Apr 28, 2008 2:21 pm
You're correct. Those are the t-statistics. I've corrected the code shown in the previous message on 28 April 2008.
Re: LSUnit (LM unit root test with multiple breaks)
Postby ecsaa » Tue Aug 31, 2010 10:18 am
I am relatively new to RATS programming.
Can you tell me whether this program code can be adapted to report:
1) the coefficient and t-ratio of the trend term;
2) the number of lags in the estimated equation.
Many thanks for any assistance.
ecsaa
Postby TomDoan » Tue Aug 31, 2010 2:28 pm
Lee-Strazicich Unit Root Test, Series LOGX
Regression Run From 7 to 38
Observations          32
Trend Break Model with 2 breaks
With 2 chosen from 5
Variable     Coefficient T-Stat
S{1}             -1.0983 -5.1986
Constant          0.0198  2.4096
D(11)            -0.0152 -0.8670
DT(11)            0.0272  2.0811
D(31)            -0.0146 -0.7537
DT(31)           -0.0119 -1.3742
The "With 2 chosen from 5" is missing the word "lags", but that's the report on the number of lags used.
The overall trend rate is actually the Constant in the output since the entire equation is first differenced.
Postby trangan_20142011 » Thu May 09, 2013 5:38 pm
Dear Tom Doan,
Could I ask you about reading RATS result for LS's structural breaks from the above example? Actually I am newly to RATS program. I used lsunit.rsc to run this test, however I donot how to read the result. Specifically, what does it mean for S(1)? what is the calculated t-statistic to compare with the critical value? How to choose the critical value for model C "Break", as in the example?
Could you recommend me some reference documents for improving my knowledge on using RATS?
Thank you for your attention. I hope to receive your reply asap.
Best regards,
trangan_20142011
Postby TomDoan » Fri May 10, 2013 2:24 pm
trangan_20142011 wrote:Dear Tom Doan,
Best regards,
S{1} is the lagged detrended data---the t statistic on it is the unit root test statistic.
The critical values aren't that sensitive to the location. However, in the example, the estimation range is 7 to 38 and the breaks are at 11 and 31.
11 is a bit over 10% into the range and 31 is about 75% in so the closest one will be .2,.8.
If you have a specific textbook that you're using or have used for which we have the worked examples, going through and looking at how RATS does their various examples would be the best way to learn. If you have a certain area of interest that's covered by one of our e-courses (http://www.estima.com/courses_completed.shtml) those can be very useful.
Postby trangan_20142011 » Mon May 13, 2013 6:21 pm
Hi Tom Doan,
Thank you for your reply.
In the results for model C, there are two calculated values for D(11) and DT(11). What t-statistics (for D(11) or DT(11)) should I use to compare with the the critical value? I ask this because Model C for both intercept and trend stationary. In my study, there is little statistically significant breaks, is there any problem for this?
Many thanks.
trangan_20142011
Postby trangan_20142011 » Mon May 13, 2013 6:29 pm
Moreover, in terms of text books, I have some, but none of them includes examples about using RATS. Please advise me, tks.
trangan_20142011
Postby TomDoan » Mon May 13, 2013 8:39 pm
trangan_20142011 wrote:Hi Tom Doan,
Neither. The test statistic is the t-stat on S{1}.
trangan_20142011 wrote:I ask this because Model C for both intercept and trend stationary. In my study, there is little statistically significant breaks, is there any problem for this?
No. Read carefully section 11.6 of the RATS v8 User's Guide, particularly the second paragraph.
Postby trangan_20142011 » Fri May 17, 2013 8:42 am
Dear Tom Doan,
I read the citation that Doan (2000) recommends against differencing even if the variable contains a unit root because it throws away in information concerning the co-movements of variables. Could you explain it for me? If it is right, why do we need to test unit root?
Thank you very much.
trangan_20142011
Postby TomDoan » Fri May 17, 2013 10:53 am
That's specifically in the context of a VAR, and that's not all that controversial---if there is cointegration, then a VAR estimated in differences is misspecified.
trangan_20142011 wrote:If it is right, why do we need to test unit root?
Because referees insist upon it. That's not intended to be flip. That's reality.
Return to RATS Procedures
Who is online
