MCVARDoDraws - Procedure for drawing IRF's by Monte Carlo
Postby TomDoan » Fri Jul 17, 2009 3:07 pm
The attached is a procedure which was largely taken out of the MonteVar procedure. This does the draws only, leaving the graphing and other analysis to other procedures (particularly MCGraphIRF).
MCVARDoDraws does a Choleski factorization, though it can easily be adapted to other situations. Its options are:
MODEL=model to analyze [required, should already be estimated]
STEPS=number of response steps[48]
DRAWS=number of Monte Carlo draws[1000]
ACCUMULATE=list of variables (by position) to accumulate [none]
The ACCUMULATE option allows you to estimate the VAR in differences, then convert the impulse responses to the responses of the levels. For instance, ACCUMULATE=||1|| will "undifference" the 1st variable.
MCVARDoDraws defines the global %%responses in the format used by MCGraphIRF and some other procedures. It does not directly produce any output.
Minor revision 8 April 2011
mcvardodraws.src
(3.72 KiB) Downloaded 185 times
If you want to replace the Choleski factorization with some other one, that is done at the following location in the procedure. We would recommend that you first make a renamed copy of the procedure file before editing:
   * The next line is where a particular factorization of sigmad is
   * input into the calculation. This does the Choleski factorization in
   * standard order, which is what is used above in drawing the
   * coefficients.
   compute factor=fsigmad
Instead of factor=fsigmad, you want factor = whatever your factor matrix is. An example is the following, which uses a factorization with short and long-run restrictions:
compute phiinv=inv(%modellagsums(model))
@ShortAndLong(lr=lr,sr=sr,masum=phiinv) sigmad factor
The LR and SR matrices need to be passed into the procedure in some way; adding them as options to your new procedure is probably the best way to handle that. So you would include the following among the options:
option rect LR
option rect SR
Re: MCVARDoDraws - Procedure for drawing IRF's by Monte Carlo
Postby MC128 » Sun Sep 20, 2009 3:39 am
Do you know how to modify the MCVARDoDraws to factorization other than the choleski?? Should I include the A and B matrix (i.e. A and B matrix from SVAR) into the procedure?
And would the mean impulse response be the same as the point estimate from the OLS?
Thanks!
MC
MC128
Postby TomDoan » Mon Sep 21, 2009 10:16 am
MC128 wrote:Hi Tom,
      compute sigmad  =%ranwisharti(fwish,wishdof)
      compute fsigmad =%decomp(sigmad)
The first of these draws a sigma matrix from the unconditional distribution. The second creates a factor of that. It's that second instruction that need to be replaced to create a different factor. That could be with a CVMODEL instruction, which would include the FACTOR=FSIGMAD option.
MC128 wrote:And would the mean impulse response be the same as the point estimate from the OLS?
Other than for the first step, no. Once you've done MC integration, the mean or median of the drawn responses is a better estimate than the point estimate from OLS.
Postby MC128 » Mon Sep 21, 2009 8:12 pm
Thanks for your reply. I have tried your suggestion...but the programme crashes.....Is the following command correctly writen?
May I also ask whether the Rats could draw bootstrapped confidence interval?
Many thanks.
MC
source ABDraws.src
source MCGraphIRF.src
compute nstep=25
compute nshocks=3
dec vect[strings] cl(nshocks)
compute cl=||"GDP","Expenditure","Revenue"||
dec vect[strings] vl(3)
compute vl=||"GDP","Expenditure","Revenue"||
dec frml[rect] afrml bfrml
nonlin aey ary aye ayr bre ber
*assume structural revenue shock have no impact on structural spending shock - ber = 0
*if assume structural spending shock have no impact on structural revenue shock - bre = 0
frml afrml = ||1.0,-aye,-ayr|$
               -aey,1.0,0.0|$
               -ary,0.0,1.0||
frml bfrml = ||1.0,0.0,0.0|$
               0.0,1.0,ber|$
               0.0,bre,1.0||
system(model=varmodel)
variables gdp govspendb revenue
lags 1 to 4
estimate(noprint)
compute aye=ayr=bre=0
nonlin aey=0.0 ary=0.25 aye ayr bre ber=0.0
cvmodel(a=afrml,b=bfrml,method=bfgs,pmethod=genetic,piters=20,factor=swish) %sigma
@varirf(model=varmodel,step=nstep,vlabels=vl,byshocks,factor=swish)
@ABDraws(model=varmodel,step=nstep)
@MCGraphIRF(model=varmodel,varlabels=vl,shocklabels=cl,$
  page=byshock,stddev=1.0,columns=1,include=||1,2,3||)
ABDraws.src
changing the MCVARDoDraws.src to alternative factorization
(3.71 KiB) Downloaded 238 times
MC128
Postby TomDoan » Mon Sep 21, 2009 9:25 pm
Redo the
estimate(noprint)
right before doing the @abdraws call. The procedure is expecting that the last estimation is estimation of the VAR.
There's an example of bootstrapping for a VAR in the Sims and Zha replications.
Postby MC128 » Mon Sep 21, 2009 9:56 pm
For unknow reason, the Rats programme crash again.....I have attached the programme for your reference....many thanks.
MC
fiscalshocks(bp).PRG
(1.63 KiB) Downloaded 249 times
MC128
Postby TomDoan » Tue Sep 22, 2009 10:31 am
Aren't you getting a message that AFRML isn't defined? You're trying to source the abdraws procedure before AFRML and BFRML (which are referenced in it) have been defined. If you get rid of those two early source instructions (which you don't need anyway), it should work.
Return to RATS Procedures
Who is online
