PRINFACTORS - updated version
Postby TomDoan » Thu Jun 07, 2007 3:34 pm
This has been updated to include several new options. It also sign-flips loading vectors which are predominantly negative.
*  PRINFACTORS does a principal components based factor analysis
*  of an input covariance or correlation matrix.
*  Syntax:
*  @PRINFACTORS( options ) sigma
*  Options:
*    NCOMPS=number of components [number of variables]
*    PRINT/[NOPRINT]  Controls whether the output will be displayed.
*    SIGMAHAT=output sigma matrix [not used]
*    LOADINGS=RECTANGULAR of loadings of components onto variables [not used]
*    VECTORS=RECTANGULAR of eigenvectors [not used]
*    VALUES=VECTOR of eigenvalues [not used]
*    COMMUNALITIES=VECTOR of communalities for variables [not used]
*  Parameters:
*    sigma -- The input covariance matrix.
*  Revision Schedule
*  05/05 Written by Tom Doan, Estima
*  08/06 Corrections to the comments describing the procedure syntax.
*  03/07 Define %VARIANCE. Add COMMUNALITIES, VECTORS and VALUES option.
*        Sign flip loading vectors which are primarily negative.
procedure prinfactors sigma
type symm sigma
option integer ncomps   0
option switch  print    0
option symm             *sigmahat
option rect             *loadings
option rect             *vectors
option vect             *values
option vect             *communalities
local rect eigenvec
local vect eigenval princoef scalings
local int  n nvars icomp
local real totalvar running
compute nvars=%rows(sigma)
* Do an eigen decomposition of the input matrix.
eigen sigma eigenval eigenvec
if %defined(values)
   compute values=eigenval
if %defined(vectors)
   compute vectors=eigenvec
* Figure out how many components need to be computed
if .not.ncomps
   compute n = nvars
else
   compute n = ncomps
if print {
   report(action=define)
   report(atrow=1,atcol=2,span) "Principal Components Analysis"
   report(atcol=1,atrow=2,fillby=cols) "Eigenvalue" "Proportion" "Cumulative" "Eigenvector"
* Get the total variation for normalizing the contributions
compute totalvar=%sum(eigenval)
* Initialize the running sum of the covariances
if %defined(sigmahat)
   compute sigmahat=%zeros(nvars,nvars)
* And the running sum of the variance explained
if %defined(communalities)
   compute communalities=%zeros(nvars,1)
compute running=0.0
do icomp=1,n
   compute running=running+eigenval(icomp)
   compute princoef=%xcol(eigenvec,icomp)
      compute communalities=communalities+eigenval(icomp)*princoef.^2
   if print
      report(col=new,atrow=2,fillby=cols) eigenval(icomp) eigenval(icomp)/totalvar running/totalvar princoef
      compute sigmahat=sigmahat+%outerxx(princoef)*eigenval(icomp)
end do icomp
if print
  report(action=show)
* Replace the diagonal elements of sigmahat with the input elements
if %defined(sigmahat) {
   do icomp=1,nvars
      compute sigmahat(icomp,icomp)=sigma(icomp,icomp)
compute %variance   =totalvar
*  Compute the loadings if requested. Sign flip column which is predominantly negative
if %defined(loadings) {
   dim loadings(nvars,n)
   dim scalings(n)
   do j=1,n
      compute scalings(j)=sqrt(eigenval(j))*%sign(%sum(%xcol(eigenvec,j)))
   ewise loadings(i,j)=eigenvec(i,j)*scalings(j)
Sign reversal
Postby dniggeler@gmx.ch » Fri Jul 13, 2007 10:07 am
Hi
Could you please explain to a Rats beginner why in contrast to other stats program I get eigenvectors with a flipped sign.
Thank you for your help,
Dieter.
BhFS Behavioural Finance Solutions GmbH
Dieter Niggeler
Plattenstrasse 32
8032 Zurich Switzerland
dniggeler@gmx.ch
Postby TomDoan » Tue Jul 24, 2007 11:43 am
The signs of eigenvectors are arbitrary. RATS uses a translation of EISPACK FORTRAN code which is probably almost identical to the newer LAPACK code. There's no sign choice in that at all; the signs of the eigenvectors are what they are based upon the input matrix and the order of calculations.
The sign choice is mathematically irrelevant - it only affects how easy it is to read the results. What sign choice is most useful will actually depend upon the situation. The recoding of PRINFACTORS makes the sum of the elements in an eigenvector positive. While this is arguably more useful than having the sign determined effectively randomly, I could think of situations where making the largest value positive would make it easier to read. (CATS, for instance, by default will normalize an eigenvector to make its largest element 1.0).
Re: PRINFACTORS - updated version
Postby IRJ » Thu Mar 07, 2013 10:30 am
How can one extract the principal components from the procedure @prinfactors? More specifically, how can one obtain the output of the procedure @princomp using @prinfactors? And how can one normalize the eigenvectors in the two procedures so that the largest eigenvector takes a value of one?
IRJ
Postby TomDoan » Fri Mar 08, 2013 10:25 am
IRJ wrote:How can one extract the principal components from the procedure @prinfactors? More specifically, how can one obtain the output of the procedure @princomp using @prinfactors? And how can one normalize the eigenvectors in the two procedures so that the largest eigenvector takes a value of one?
If you want the principal components, just use @PRINCOMP.
As an example of rescaling:
compute eigen=%ranmat(5,5)
dec vect maxv(%rows(eigen))
ewise maxv(i)=%maxvalue(%abs(%xcol(eigen,i)))
compute eigen=%ddivide(eigen,maxv)
Return to RATS Procedures
Who is online
