Below find example code for using Uhlig's (1997, Econometrica) method to estimate a BVAR with stochastic volatility. Comments welcome.
************ Program including estimator of Uhlig's (Econometrica 1997) BVAR with stochastic volatility
************ Program written by Taisuke Nakata from the Federal Reserve Bank of Kansas City, with
************ edits by Todd Clark, based on Matlab code kindly provided by Harald Uhlig (for Uhlig estimator),
************ as well as Gibbs sampling BVAR code written by Tom Doan.
************ Using Uhlig's model and several others, the program generates forecasts of GDP growth, core PCE
************ inflation, and the federal funds rate. The VARs are specified in terms of GDP growth, core
************ inflation less an exponentially smoothed trend, and the funds rate less trend inflation
************ (such detrending makes the model similar to those considered in Kozicki and Tinsley (2001 JME, 2001 JEDC)).
************ In addition to displaying forecasts for 2007 and 2008, the program plots densities of forecasts from
************ the Uhlig model and constant volatility BVARs. The plots are saved to .eps files.
************ Note that, in contrast to the specifications used in Uhlig (1997), Doan, Litterman, and Sims (1984), among others,
************ the VARs are specified in terms of GDP growth, detrended inflation, and a real interest rate, rather than
************ log levels of GDP, the price index, and the nominal interest rate.
************ The program uses data on real GDP, total and core PCE price indexes, and the funds rate stored in a file data_q.xls
************ 02/09/2007
comp fixlags = 4 ;* fixed lag order to use in VARs
comp styr = 1947
cal styr 1 4
comp stsmpl = styr:1
comp endsmpl = 2006:4 ;* "endsmpl" is the last observation period.
all stsmpl endsmpl+10 ;* +10 to pad sample for forecasting
smpl stsmpl endsmpl
seed 2011+endsmpl ;* If you get two-hamped forecast distribution, assign a different value for "seed".
******************************** setting dimensions (# models, etc.)
comp nvar = 3 ;* number of variables in the VAR model (GDP, infl, ff rate)
comp nvar_real = 1 ;* number of real variables in the VAR model (GDP), ordered first in the system
comp nmeth = 6 ;* number of forecast methods to be considered
dec vec[string] methlabels(nmeth) ;* vector of strings to store short descriptions of each method
**** horizons (#s of periods)
comp [vec[int]] horz = ||1,2,4,8||
comp nhorz = %rows(horz)
comp maxh = horz(nhorz)
** note: the forecasts for 4 and 8 periods ahead are accumulated to obtain four-quarter rates of growth and inflation
** (but the quarterly level of the interest rate)
******************************** setting up and reading in data
open data data_q.xls
data(format=xls,org=col) / GDP PCEPI PCEXFEPI FFR
close
**** annualized log growth rates, stored in vector of series for use in VAR
dec vec[ser] y(nvar)
dofor i = GDP PCEXFEPI PCEPI
set(scratch) i = 400.*log(i{0}/i{1})
set infl = pcexfepi; set totalinfl = pcepi
**** storing data in vector of series for use in VAR
comp j = 0
dofor i = GDP INFL FFR
comp j = j+1
set y(j) = i{0}
labels y(j)
# 'Y_'+%l(i)
**** differencing inflation and int rate, for use in benchmark MA models
dec vec[ser] dyser(nvar) ylevser(nvar)
dofor i = nvar_real+1 to nvar
set(scratch) dyser(i) = y(i){0} - y(i){1}
set(scratch) ylevser(i) = y(i){0}
**** estimate trend with exp. smoothing of inflation (yields a trend similar to the inflation expectations
**** series of Kozicki and Tinsley)
comp smparam = .07
inquire(series=infl) stpt_p *
inquire(series=totalinfl) stpt_totp *
clear ptrend
stats(noprint) totalinfl stpt_p-40 stpt_p-1
comp ptrend(stpt_p-1) = %mean
set ptrend stpt_p endsmpl = ptrend{1} + smparam*(infl - ptrend{1})
set rawptrend stpt_p endsmpl = ptrend ;* making a copy for use in the forecasting loop
set(scratch) y(nvar_real+1) = infl - ptrend{1}
set(scratch) y(nvar_real+2) = ffr - ptrend{1}
*print(dates) 1959:1 endsmpl infl ptrend
**** determining common sample to be used in estimation (after adjustment for lag order)
comp stpt = stsmpl
comp endpt = endsmpl
do i = 1,nvar
inquire(series=y(i)) stptser endptser
comp stpt = %imax(stptser,stpt)
comp endpt = %imin(endpt,endptser)
dis %datelabel(stpt) %datelabel(endpt)
******************************** stuff for Bayesian estimation:
******** prior means of first lag of dep variable in each equation (basic intention is to push VAR towards AR(1) models)
dec vec bvarprior(nvar)
comp bvarprior = %const(0.)
comp bvarprior(1) = .3 ;* GDP growth equation
comp bvarprior(nvar_real+1) = .7 ;* infl equation
comp bvarprior(nvar_real+2) = .9 ;* int rate equation
**** means for use in calibrating intercepts in Uhlig estimator
dec vec bvarmean(nvar)
comp bvarmean = %const(0.)
comp bvarmean(1) = 3.2 ;* GDP growth equation
comp bvarmean(nvar_real+1) = 0. ;* detrended infl equation
comp bvarmean(nvar_real+2) = 2.5 ;* (real) int rate equation
******** for conventional BVAR estimation
comp TIGHT = .2 ;* overall tightness of prior
comp OTHER = 0.5 ;* relative weight on other lags
comp decay = 1. ;* controls how the prior variance tightens as the lag order grows
comp lambda3 = decay ;* hyperparameter determining lag decay rate in full Minnesota implementation (the one using Gibbs sampling)
******* stuff for RATS' Gibbs sampling approach (taken from code by Tom Doan)
dec rect bover
dec vect bhat bmean bdiff ux
comp ndraws = 2000
comp burnindraws = ndraws/10
comp draws_burn = ndraws - burnindraws
******* stuff for Minnesota prior forecasts
declare rect sxx svtr swish betaols betadraw ranc
declare symm sigmad
dec vec univar(nvar)
******************************** stuff for Uhlig estimation
comp ndraws_uhlig = 4000
comp ncoef = nvar*fixlags + 1 ;*always include intercept
dec vec[rec] yser xser eser phiser ;* Needed to generate the data
dec vec[rec] nser invnser bhatser sser ;* Needed to calculate the posterior
comp niterate=21 ;* Following Uhlig's code.
dec vec[rec] bseq(niterate)
dec vec[vec] bseqv(niterate)
dec vec gradvec
smpl stsmpl endsmpl
dec vec udraw w_store(ndraws_uhlig)
comp maxnobs = endsmpl-stsmpl+1
dim yser(maxnobs+maxh) xser(maxnobs+maxh) eser(maxnobs+1) phiser(maxnobs+1) nser(maxnobs+1) invnser(maxnobs+1) bhatser(maxnobs+1) sser(maxnobs+1)
do vtime=1,maxnobs
comp yser(vtime) = %zeros(nvar,1)
comp eser(vtime) = %zeros(nvar,1)
comp xser(vtime) = %zeros(ncoef,1)
comp nser(vtime) = %zeros(ncoef,ncoef)
comp invnser(vtime) = %zeros(ncoef,ncoef)
comp bhatser(vtime) = %zeros(nvar,ncoef)
comp sser(vtime) = %zeros(nvar,nvar)
end do vtime
comp v = 20. ;* recommended by Uhlig. (v=20 for quarterly data and v=60 for monthly data)
comp lambda = v/(v+1) ;* recommended by Uhlig.
** these zeta settings are meant to be in line with the conventional BVAR settings (and differ somewhat from Uhlig's suggestion)
comp zeta1 = 1./tight**2. ;* overall tightness of the prior
comp zeta2 = 1. ;* the increase in tightness for higher lags
comp zeta3 = 1./tight**2. ;* tightness of prior for constant
* (we impose an informative prior to prevent the intercept from moving around too much over time)
do vtime=1,maxnobs
comp xser(vtime)(1,1) = 1.
end do vtime
**** prior for coefs (same as in conventional BVAR)
do i=1,nvar
comp bhatser(1)(i,i+1) = bvarprior(i)
**** prior variance for intercept
comp nser(1)(1,1) = zeta3 ;* precision (the inverse of variance) of your prior for beta
**** prior mean for coefficients
dis ####.# bhatser(1)
******************************** stuff for forecasting
**** equation setup
dec vec[equations] vareqs(nvar) univareqs(nvar)
list mmm = 1 to nvar
dec vec[ser] forecasts(nvar) ;* vector of series used for temporary storage of quarterly forecasts
dec rec[real] fcy1(nmeth,nvar) fcy2(nmeth,nvar) fcy4(nmeth,nvar) fcy8(nmeth,nvar)
;* rectangular arrays for storing forecasts obtained with each method, one array for each horizon
** matrices for storing draws of Bayesian forecasts at the end of the sample, for density calculations
dec vec[rec] bfc1(nmeth) bfc2(nmeth) bfc4(nmeth) bfc8(nmeth) ;* separate vectors for each forecast horizon
do i = 1,nmeth
dim bfc1(i)(%imax(ndraws,ndraws_uhlig),nvar)
dim bfc2(i)(%imax(ndraws,ndraws_uhlig),nvar)
dim bfc4(i)(%imax(ndraws,ndraws_uhlig),nvar)
dim bfc8(i)(%imax(ndraws,ndraws_uhlig),nvar)
smpl stpt endsmpl+10
clear forecasts
comp stpt = stpt+fixlags ;* redefine starting point for sample estimate to reflect lags allowed
******************************** FORMING FORECASTS
comp rolln = 80 ;* size of sample used in rolling VAR estimates
comp time = endsmpl+1 ;* the forecast origin is endsmpl+1
dis '************************************************ forecast origin = ' %datelabel(time)
comp mod = 0
********************* defining common sample for VAR estimation
comp endpt = time-1
smpl stpt endpt
set ptrend stpt_p endsmpl = rawptrend{0}
********************* benchmark univariate AR(2) model for GDP growth, MA(1) models for changes in inflation, int rate
comp mod = mod+1
comp methlabels(mod) = 'univariate benchmark'
do i = 1,nvar_real
linreg(noprint,define=univareqs(i)) y(i)
# constant y(i){1 to 2}
ufore(equation=univareqs(i)) forecasts(i) endpt+1 endpt+maxh
comp rollstpt = %imax(stpt-fixlags+1,endpt-40+1) ;* start of estimation sample for rolling 10-year approach
boxjenk(ma=1,define=mamodel,noprint) dyser(i) rollstpt endpt
ufore(equation=mamodel) forecasts(i) endpt+1 endpt+maxh
accum forecasts(i) endpt+1 endpt+maxh accumfc
set forecasts(i) endpt+1 endpt+maxh = ylevser(i)(endpt) + accumfc{0}
*** forecasts for all variables
do i = 1,nvar
comp fcy1(mod,i) = forecasts(i)(time)
comp fcy2(mod,i) = forecasts(i)(time+1)
if i==nvar
comp fcy4(mod,i) = forecasts(i)(time+3)
comp fcy8(mod,i) = forecasts(i)(time+7)
else
comp fcy4(mod,i) = (forecasts(i)(time)+forecasts(i)(time+1)+forecasts(i)(time+2)+forecasts(i)(time+3))/4.
comp fcy8(mod,i) = (forecasts(i)(time+4)+forecasts(i)(time+5)+forecasts(i)(time+6)+forecasts(i)(time+7))/4.
********************* VAR
comp mod = mod+1
comp methlabels(mod) = 'VAR('+%string(fixlags)+')'
system(model=varmodel)
variables y
lags 1 to fixlags
kfset xxxols
estimate(noprint)
forecast(model=varmodel,results=forecasts) * maxh endpt+1
*** storing stuff needed below in posterior simulations
compute sigma=%sigma
compute olssigma=%sigma
compute xx =inv(xxxols)
compute bhat=%vec(%modelgetcoeffs(varmodel))
compute sxx =%decomp(xxxols)
compute svtr =tr(%decomp(sigma))
compute ncoef =%rows(sxx)
compute T = %nobs
compute wishdof= T - ncoef
*** obtaining forecasts of the level of infl and int rate from the detrended forecasts
set ptrend endpt+1 endpt+maxh = 0.
do ftime = endpt+1,endpt+maxh
comp forecasts(nvar-1)(ftime) = forecasts(nvar-1)(ftime) + ptrend(ftime-1)
comp forecasts(nvar)(ftime) = forecasts(nvar)(ftime) + ptrend(ftime-1)
comp ptrend(ftime) = ptrend(ftime-1) + smparam*(forecasts(nvar-1)(ftime) - ptrend(ftime-1))
end do ftime
do i = 1,nvar
if i==nvar
else
********************* BVAR, Minnesota prior (using Gibbs sampling to get proper posterior mean of multi-step forecasts,
********************* as well as full posterior density)
********************* (note that I modified Doan's Gibbs sampling prior setup to follow the canned Minnesota settings)
comp mod = mod+1
comp methlabels(mod) = 'Minnesota BVAR('+%string(fixlags)+')'
do i = 1,nvar
comp fcy1(mod,i) = 0.
comp fcy2(mod,i) = 0.
comp fcy4(mod,i) = 0.
comp fcy8(mod,i) = 0.
* Create the prior mean and (square root of) precision. The olssee values are used to
* scale the precision. The prior mean is 1 for the first own lag in each equation, and
* 0 otherwise. The constant is given a mean of zero with a zero precision (that is, a flat
* prior).
comp lags = fixlags
compute ncoef=lags*nvar+1
comp minnmean = %zeros(ncoef,nvar)
comp minnprec = %zeros(ncoef,nvar)
** computing OLS univariate and VAR estimates, to get info needed in BVAR calcs
do i = 1,nvar
linreg(noprint) y(i)
# constant y(i){1 to lags}
compute univar(i)=sqrt(%rss/%nobs)
do i=1,nvar
do j=1,nvar
do l=1,lags
compute minnmean((j-1)*lags+l,i)=(i==j.and.l==1)*bvarprior(i)
compute minnprec((j-1)*lags+l,i)=univar(j)/univar(i)*%if(i==j,float(l)**lambda3/tight,float(l)**lambda3/(other*tight))
end do l
compute minnmean(ncoef,i)=0.0,minnprec(ncoef,i)=1./(1000.*univar(i))
* This works better with everything in vec form, rather than as an KxN matrix.
ewise minnprec(i,j)=minnprec(i,j)**2
compute hprior=%diag(%vec(minnprec))
compute bprior=%vec(minnmean)
* Except that there's one spot where the KxN form is more convenient, so we
* create bover and bdiff as overlayed copies of each other.
dim bmean(nvar*ncoef) bdiff(nvar*ncoef) ux(nvar*ncoef)
overlay bdiff(1) with bover(ncoef,nvar)
* The loop below does the Gibbs sampler. All I'm doing here is accumulating the means of
* the coefficients. However, the same basic code could easily be adapted for doing
* Monte Carlo integration for impulse response functions or forecasts.
do draws=1,ndraws
* Draw b given sigma. The draw for the coefficients is in bdraw as a vector.
compute hb=%kroneker(inv(sigma),xx)
compute hx=inv(hb+hprior)
compute bmean=hx*(hprior*bprior+hb*bhat)
compute fx=%decomp(hx)
compute bdraw=bmean+fx*(ux=%ran(1.0))
comp beta_draw = %vectorect(bdraw,ncoef)
* Draw sigma given b
compute bdiff=bdraw-bhat
compute wparm=olssigma+(1.0/%nobs)*%mqform(xx,bover)
compute sigma=%mqform(%nobs*inv(%ranwishart(nvar,%nobs-ncoef)),tr(%decomp(wparm)))
compute %modelsetcoeffs(varmodel,beta_draw)
simulate(model=varmodel,results=forecasts) * maxh endpt+1 sigma
if draws>burnindraws
end do ftime
do i = 1,nvar
comp fcy1(mod,i) = fcy1(mod,i) + forecasts(i)(time)
comp fcy2(mod,i) = fcy2(mod,i) + forecasts(i)(time+1)
if i==nvar
comp fcy4(mod,i) = fcy4(mod,i) + forecasts(i)(time+3)
comp fcy8(mod,i) = fcy4(mod,i) + forecasts(i)(time+7)
else
comp fcy4(mod,i) = fcy4(mod,i) + (forecasts(i)(time)+forecasts(i)(time+1)+forecasts(i)(time+2)+forecasts(i)(time+3))/4.
comp fcy8(mod,i) = fcy4(mod,i) + (forecasts(i)(time+4)+forecasts(i)(time+5)+forecasts(i)(time+6)+forecasts(i)(time+7))/4.
*** storing for density calculations
do i = 1,nvar
comp bfc1(mod)(draws,i) = forecasts(i)(time)
comp bfc2(mod)(draws,i) = forecasts(i)(time+1)
if i==nvar
comp bfc4(mod)(draws,i) = forecasts(i)(time+3)
comp bfc8(mod)(draws,i) = forecasts(i)(time+7)
else
comp bfc4(mod)(draws,i) = (forecasts(i)(time)+forecasts(i)(time+1)+forecasts(i)(time+2)+forecasts(i)(time+3))/4.
comp bfc8(mod)(draws,i) = (forecasts(i)(time+4)+forecasts(i)(time+5)+forecasts(i)(time+6)+forecasts(i)(time+7))/4.
end do draws
do i = 1,nvar
comp fcy1(mod,i) = (1./draws_burn)*fcy1(mod,i)
comp fcy2(mod,i) = (1./draws_burn)*fcy2(mod,i)
comp fcy4(mod,i) = (1./draws_burn)*fcy4(mod,i)
comp fcy8(mod,i) = (1./draws_burn)*fcy8(mod,i)
********************* ROLLING VAR
*** first changing sample for rolling estimation
smpl %imax(stpt,endpt-rolln+1) endpt
comp mod = mod+1
comp methlabels(mod) = 'Rolling VAR('+%string(fixlags)+')'
****** ROLLING (OLS) estimates of VAR
variables y
lags 1 to fixlags
kfset xxxols
estimate(print)
compute T = %nobs
end do ftime
do i = 1,nvar
if i==nvar
else
********************* ROLLING BVAR, Minnesota prior (using Gibbs sampling to get proper posterior mean of multi-step forecasts,
comp mod = mod+1
comp methlabels(mod) = 'Rolling Minnesota BVAR('+%string(fixlags)+')'
do i = 1,nvar
* prior).
comp lags = fixlags
do i = 1,nvar
do i=1,nvar
do j=1,nvar
do l=1,lags
end do l
do draws=1,ndraws
end do ftime
do i = 1,nvar
if i==nvar
else
do i = 1,nvar
if i==nvar
else
end do draws
do i = 1,nvar
********************** Uhlig BVAR
********************** General setup for Uhlig's procedure.
comp mod = mod+1
comp methlabels(mod) = 'Uhlig BVAR'
do i = 1,nvar
smpl stpt endpt
comp nobs = endpt - stpt + 1
do vtime=1,nobs
do i=1,nvar
comp yser(vtime)(i,1) = y(i)(stpt + vtime - 1)
do j=1,fixlags
comp test = y(i)(stpt+ vtime -j - 1)
comp xser(vtime)(1 + nvar*(j-1) + i,1) = test
end do vtime
********************** Specify the parameters for prior distribution of h(1)
** setting prior mean for intercept of growth, int. rate equation
dofor i = 1 nvar
stats(noprint) y(i) stpt endpt
comp bhatser(1)(i,1) = %mean*(1.-bvarprior(i))
do i=1,nvar
linreg(noprint) y(i) stpt endpt
# constant y(i){1 to fixlags}
comp sser(1)(i,i) = %rss/%nobs
do i=1,nvar
do j=1,fixlags
comp nser(1)(1+nvar*(j-1)+i,1+nvar*(j-1)+i) = (y(i)((stpt-fixlags))**2.)*zeta1*(j**zeta2)
comp invnser(1) = inv(nser(1))
do vtime=2,nobs+1
comp eser(vtime) = yser(vtime-1) - bhatser(vtime-1)*xser(vtime-1)
comp nser(vtime) = lambda*nser(vtime-1) + %outerxx(xser(vtime-1))
comp check1 = %mqform(%identity(1),(tr(xser(vtime-1))*invnser(vtime-1)))
comp check2 = %mqform(invnser(vtime-1),xser(vtime-1)) + lambda
comp invnser(vtime) = (invnser(vtime-1) - check1/check2(1,1))/lambda
comp bhatser(vtime) = (lambda*(bhatser(vtime-1)*nser(vtime-1)) + yser(vtime-1)*tr(xser(vtime-1)))*invnser(vtime)
comp [symm] xnx = %mqform(invnser(vtime),xser(vtime-1))
comp sser(vtime) = lambda*sser(vtime-1) + (lambda/v)*%outerxx(eser(vtime))*(1. - xnx(1,1))
end do vtime
******************** We want to find an appropriate importance function.
******* (1) Find "bmax", using modified Newton-Raphson method
*** (1-1) Calculate jstar(nvar*ncoef -by- nvar*ncoef)
comp jstar = %zeros(nvar*ncoef,nvar*ncoef)
do vtime=2,nobs
comp jstar = jstar - 0.5*%kroneker(nser(vtime),inv(v/lambda*sser(vtime)))
end do vtime
comp jstar = jstar - 0.5*(v+ncoef+1.)*%kroneker(nser(nobs +1),inv((v/lambda)*sser(nobs+1)))
comp invjstar = inv(jstar)
*** (1-2) Calculate a sequence of "B(n)" starting with B(1) = bhatser(T)
comp bseq(1) = bhatser(nobs+1)
comp test1 = %vectorect(%vec(bseq(1)),nvar)
do ni=2,niterate
comp bseq(ni) = %zeros(nvar,ncoef)
comp badj = %zeros(nvar,ncoef)
comp badjv = %zeros(nvar,ncoef)
comp gradvec= %zeros(nvar*ncoef,1)
do vtime=2,nobs+1
comp ae = inv( %mqform(nser(vtime),tr(bseq(ni-1)-bhatser(vtime))) + (v/lambda)*sser(vtime))
comp aevec = %zeros(1,nvar*nvar)
comp aevec = %vec(ae)
do i=1,nvar
do j=1,ncoef
comp entryij = (j-1)*nvar + i
comp eij = %zeros(nvar,ncoef)
comp eij(i,j)=1.
comp cij = eij*nser(vtime)*tr(bseq(ni-1)-bhatser(vtime)) + (bseq(ni-1)-bhatser(vtime))*nser(vtime)*tr(eij)
comp cijvec = %zeros(nvar*nvar,1)
comp cijvec = %vec(cij)
comp lltest = tr(aevec)*cijvec
if vtime<nobs+1
comp gradvec(entryij) = gradvec(entryij) - 0.5*lltest(1,1)
else
comp gradvec(entryij) = gradvec(entryij) - 0.5*(v+ncoef+1.)*lltest(1,1)
end do vtime
comp badjv = invjstar*gradvec
comp badj = %vectorect(badjv,nvar)
comp bseq(ni) = bseq(ni-1) - badj
end do ni
****** (1-3) We take bseq(ni) as the posterior mode.
comp bmax = bseq(ni)
dis ''
dis '********** Uhlig coef estimate = '
dis #####.### bmax
variables y
lags 1 to 4
kfset invzz
estimate(noprint)
dis ''
dis '********** OLS coef estimate ='
dis #####.### %modelgetcoeffs(varmodel) ;*In comparing this with betadrawave, do not forget that the elements are orgnized differently.
;* They look roughly similar. Here, the intercept is in the last row.
;* Here, the matrix are blocked into different variables, and within each block,
;* you will see different lag length. In "bmax", the intercept is in the first column,
;* and the matrix are blocked into different lags, and futher into different variables.
comp secderiv=%zeros(nvar*ncoef,nvar*ncoef)
*** (2) Evaluate the Hessian of the marginal posterior (another parameter in the importance function)
do vtime=2,nobs+1
if vtime<nobs>= entryij
comp ekl = %zeros(nvar,ncoef)
comp ekl(k,l) = 1
comp ckl = ekl*nser(vtime)*tr(bmax-bhatser(vtime)) + (bmax-bhatser(vtime))*nser(vtime)*tr(ekl)
comp eneijkl = eij*nser(vtime)*tr(ekl) + ekl*nser(vtime)*tr(eij)
comp cklvec = %vec(ckl)
comp eneijklvec = %vec(eneijkl)
comp term1 = powerfactor*tr(aevec)*eneijklvec
comp term2 = powerfactor*tr(acavec)*cklvec
comp secderiv(entryij,entrykl) = secderiv(entryij,entrykl) + term1(1,1) - term2(1,1)
comp secderiv(entrykl,entryij) = secderiv(entryij,entrykl)
end do l
end do k
end do vtime
***** (3) Calculate adjustment factor for the weight and do remaining setup for importance sampling
comp vstar = fix(0.98*(nobs+v+ncoef-nvar*ncoef)) ;* the degrees of freedom in the importance function.
comp mp_add = 0.
comp mpbeta_bmax = 0.
do vtime=2,nobs+1
comp mp_add = 0.5*log( %det( %mqform(nser(vtime),tr(bmax-bhatser(vtime))) + (v/lambda)*sser(vtime) ) )
comp mpbeta_bmax = mpbeta_bmax + mp_add
end do vtime
comp mpbeta_bmax = mpbeta_bmax + 0.5*(v + ncoef)*log( %det( %mqform(nser(nobs+1),tr(bmax-bhatser(nobs+1))) + (v/lambda)*sser(nobs+1)) )
comp adj = 0.5*(vstar + nvar*ncoef)*log(1) - mpbeta_bmax;* the adjustment factor for weights
* ;* (includes the constant part of the marginal posterior of beta)
comp wbeta = 0.
comp beta = 0.
comp h = 0.
comp wh = 0.
comp wsum = 0.
comp invs = inv(secderiv)
comp invs_sqrt = %decomp(invs)
dim udraw(%rows(secderiv))
comp betadrawsum = %zeros(nvar,ncoef)
comp hdrawsum = %zeros(nvar,nvar)
comp wbetadrawsum = %zeros(nvar,ncoef)
comp whdrawsum = %zeros(nvar,nvar)
******* (4) Importance Sampling
do draws=1,ndraws_uhlig
******** Draw "betadraw" from t-distribution with mean=bmax, variance=jstar, and degree of freedom=vstar
comp betadrawv_demeaned = (0.5*vstar/%rangamma(0.5*vstar))*invs_sqrt*(udraw=%ran(1.0))
comp betadraw_demeaned = %vectorect(betadrawv_demeaned,nvar)
comp betadraw = bmax + betadraw_demeaned
******** Draw "hdraw" from Wishart-distribution with variance=sigma and shape parameter v + ncoef
comp invsigma = inv(lambda*%mqform(nser(nobs+1),tr(betadraw - bhatser(nobs+1))) + v*sser(nobs+1) )
comp cholinvsigma = tr(%decomp(invsigma))
comp hdraw = %mqform(%ranwishart(nvar,ncoef+v),cholinvsigma )
******** Generate forecast based on beta and H drawn (treating H as fixed over forecast horizon)
do ii=1,maxh
comp yser(nobs+ii) = %zeros(nvar,1)
comp xser(nobs+ii) = %zeros(ncoef,1)
comp xser(nobs+ii)(1,1) = 1.
do jj=2,1+nvar
comp xser(nobs+ii)(jj,1) = yser(nobs+ii-1)(jj-1,1)
end do jj
do jj=1+nvar+1,ncoef
comp xser(nobs+ii)(jj,1) = xser(nobs+ii-1)(jj-nvar,1)
end do jj
comp shocks = %ranmvnormal(%decomp(inv(hdraw)))
comp yser(nobs+ii) = betadraw*xser(nobs+ii) + shocks ;*%ranmvnormal(%identity(nvar))
end do ii
do ii = 1,nvar
set forecasts(ii) endpt+1 endpt+maxh = yser(nobs+t-endpt)(ii,1)
end do ii
end do ftime
***** Calculate weights
comp w_add = 0.
comp w_betadraw = 0.
do vtime=2,nobs+1
comp w_add = - 0.5*log( %det( %mqform(nser(vtime),tr(betadraw-bhatser(vtime))) + (v/lambda)*sser(vtime)) )
comp w_betadraw = w_betadraw + w_add
end do vtime
comp ttlg = (v + ncoef)*w_add
comp w_betadraw = w_betadraw + ttlg
comp term3 = %mqform(secderiv,%vec(betadraw_demeaned))
comp precimplg = 0.5*(vstar + nvar*ncoef)*log(1. + term3(1,1)/(vstar + nvar*ncoef))
comp w_betadraw = w_betadraw + precimplg
comp w_betadraw = w_betadraw - adj
comp w_betadraw = exp(w_betadraw)
comp wsum = wsum + w_betadraw
***** Weighted sum
comp wbetadrawsum = wbetadrawsum + betadraw*w_betadraw
comp whdrawsum = whdrawsum + hdraw*w_betadraw
do i = 1,nvar
comp fcy1(mod,i) = fcy1(mod,i) + w_betadraw*forecasts(i)(time)
comp fcy2(mod,i) = fcy2(mod,i) + w_betadraw*forecasts(i)(time+1)
if i==nvar
comp fcy4(mod,i) = fcy4(mod,i) + w_betadraw*forecasts(i)(time+3)
comp fcy8(mod,i) = fcy4(mod,i) + w_betadraw*forecasts(i)(time+7)
else
comp fcy4(mod,i) = fcy4(mod,i) + w_betadraw*(forecasts(i)(time)+forecasts(i)(time+1)+forecasts(i)(time+2)+forecasts(i)(time+3))/4.
comp fcy8(mod,i) = fcy4(mod,i) + w_betadraw*(forecasts(i)(time+4)+forecasts(i)(time+5)+forecasts(i)(time+6)+forecasts(i)(time+7))/4.
do i = 1,nvar
if i==nvar
else
comp w_store(draws) = w_betadraw
end do draws
comp wbetadrawave = wbetadrawsum/wsum
comp whdrawave = whdrawsum/wsum
dis 'posterior mean of H = '
dis #####.### whdrawave
dis 'inverse of posterior mean of H = '
comp invH = inv(whdrawave)
dis #####.### invH
dis 'posterior mean of coefs = '
dis #####.### wbetadrawave
do i = 1,nvar
comp fcy1(mod,i) = (1./wsum)*fcy1(mod,i)
comp fcy2(mod,i) = (1./wsum)*fcy2(mod,i)
comp fcy4(mod,i) = (1./wsum)*fcy4(mod,i)
comp fcy8(mod,i) = (1./wsum)*fcy8(mod,i)
******************************** displaying forecasts as of the end of the sample
** 1-quarter ahead
do i = 1,nvar
if i==1
dis ''
dis '*********************** horizon = 1Q'
dis ''
dis '*************' %l(y(i))
dofor m = 1 to nmeth
dis methlabels(m) @48 ###.## fcy1(m,i)
end do m
** 2-quarter ahead
do i = 1,nvar
if i==1
dis ''
dis '*********************** horizon = 2Q'
dis ''
dis methlabels(m) @48 ###.## fcy2(m,i)
end do m
** 4-quarter ahead
do i = 1,nvar
if i==1
dis ''
dis '*********************** horizon = 1Y'
dis ''
dis methlabels(m) @48 ###.## fcy4(m,i)
end do m
** 8-quarter ahead
do i = 1,nvar
if i==1
dis ''
dis '*********************** horizon = 2Y'
dis ''
dis methlabels(m) @48 ###.## fcy8(m,i)
end do m
******************************** plotting posterior densities
grparm(portrait) header 18 subheader 18 keylabeling 16
env noshowgraphs gsave="BVARdens*.eps" gformat=landscape
set weightser 1 ndraws_uhlig = w_store(t)
*print 1 ndraws_uhlig weightser
***** 1-quarter ahead
spgraph(vfields=3,hfields=1,header='Posterior densities of 1Q-ahead forecasts')
do i = 1,nvar
if i==1
dis ''
dis '*************************************** horizon = 1Q'
dis ''
dis '*********************' %l(y(i))
dis '**** Minnesota prior, recursive:'
smpl burnindraws+1 ndraws
set statser = bfc1(3)(t,i)
stats(print,fractiles) statser
comp bw = (2.7*%nobs**(-.2))*%min(sqrt(%variance),((%fract75-%fract25)/1.34))
comp bwint = (%fract99-%fract01)/99.
density(bandwidth=bw,type=EPANECHNIKOV) statser / xvals3 yvals3
dis '**** Minnesota prior, rolling:'
set statser = bfc1(5)(t,i)
density(bandwidth=bw,type=EPANECHNIKOV) statser / xvals2 yvals2
dis '**** Uhlig'
smpl 1 ndraws_uhlig
set statser = bfc1(6)(t,i)
density(bandwidth=bw,type=EPANECHNIKOV,weight=weightser) statser / xvals yvals
*density(bandwidth=bw,type=EPANECHNIKOV) statser / xvals yvals
comp [string] header = %l(y(i))
scatter(style=line,nopatterns,header=header,key=below,klab=||'Uhlig','Minn-rolling','Minn-recursive'||) 3
# xvals yvals 1 100
# xvals2 yvals2 1 100
# xvals3 yvals3 1 100
***** 2-quarter ahead
spgraph(vfields=3,hfields=1,header='Posterior densities of 2Q-ahead forecasts')
do i = 1,nvar
if i==1
dis ''
dis '*************************************** horizon = 2Q'
dis ''
set statser = bfc2(3)(t,i)
set statser = bfc2(5)(t,i)
dis '**** Uhlig'
smpl 1 ndraws_uhlig
set statser = bfc2(6)(t,i)
# xvals yvals 1 100
***** 1-year ahead
spgraph(vfields=3,hfields=1,header='Posterior densities of 1Y-ahead forecasts')
do i = 1,nvar
if i==1
dis ''
dis '*************************************** horizon = 1Y'
dis ''
set statser = bfc4(3)(t,i)
set statser = bfc4(5)(t,i)
dis '**** Uhlig'
smpl 1 ndraws_uhlig
set statser = bfc4(6)(t,i)
# xvals yvals 1 100
***** 2-year ahead
spgraph(vfields=3,hfields=1,header='Posterior densities of 2Y-ahead forecasts')
do i = 1,nvar
if i==1
dis ''
dis '*************************************** horizon = 2Y'
dis ''
set statser = bfc8(3)(t,i)
set statser = bfc8(5)(t,i)
dis '**** Uhlig'
smpl 1 ndraws_uhlig
set statser = bfc8(6)(t,i)
# xvals yvals 1 100
