Page 1 of 3
Chan & Maheu, JBES 2002 (Jump GARCH model)
Posted: Fri Aug 10, 2012 10:17 am
These are replication files for Chan and Maheu(2002), "Conditional Jump Dynamics in Stock Market Returns", Journal of Business and Economic Statistics, vol 20, no. 3, 377-389. This estimates GARCH models with added Poisson jump processes with either fixed or "ARJI" Poisson probabilities. The ARJI-GARCH model was introduced in this paper to allow the jump probabilities to be time-varying using an ARMA-like model.
Zip file with programs data
Detailed description
Jump GARCH model
Posted: Sun Nov 24, 2013 10:57 am
by alberta123
Can you modify the program of Chan and Maheu (2002 JBES) to Maheu and McCurdy (2004 Journal of Finance "News Arrival, Jump Dynamics, and Volatility Components for Individual Stock Returns" Vol. 59, pp.755-793.
Ray
Re: Jump GARCH model
Posted: Tue Nov 26, 2013 11:28 am
Ray
The only new part of the calculation is that it requires the expected number of jumps given the data. In the calculation below, JP is the unconditional probability of K jumps (without the integrating constant), and %density((u-k*theta)/jsd)/jsd is the P[observed U|K jumps] so the sum of JP * %density(...) across K gives P[data]. The /wt is to allow for the fact that the truncation of the sum at KMAX means that the standard integrating constant (exp(-lambda)) on the Poisson isn't correct. The expected value of k given the data will be the sum of k x P(k|data) which will be the sum of k x P(data|k) x P(k) / P(data).
function jumpgarchx u h lambda deltasq theta ek
type real jumpgarchx u h lambda deltasq theta *ek
local   integer k
local   real    jsd wt jp
compute wt=0.0
compute ek=0.0
compute jumpgarchx=0.0
do k=0,kmax
   compute jsd=sqrt(h+k*deltasq)
   compute jp =exp(k*log(lambda)-%lngamma(k+1))
   compute wt =wt+jp
   compute jpu=jp*%density((u-k*theta)/jsd)/jsd
   compute jumpgarchx=jumpgarchx+jpu
   compute ek=ek+k*jpu
end do k
compute ek=ek*jumpgarchx
compute jumpgarchx=log(jumpgarchx/wt)
end jumpgarchx
You would have to save the value of EK into a series and use that in the coefficient on the lag squared residual.
Re: Chan & Maheu, JBES 2002 (Jump GARCH model)
Posted: Thu May 12, 2016 9:37 am
by Michelle
I would like to do some research using Chan&Maheu, JBES2002(Jump GARCH model) and I would like to do the out-of-sample analysis but don't know how to write the code. Could you please give me some advice.
Thanks a lot.
Posted: Thu May 12, 2016 12:17 pm
In this calculation:
set ustdsq = (u-lambda*theta)^2/(h+lambda*(theta^2+delta^2))
the one-step forecast of the series is lambda*theta and the one step forecast of the variance is the h+lambda*(theta^2+delta^2).
Posted: Thu May 12, 2016 9:34 pm
by Michelle
Thanks for your reply. I was wondering if it is possible to use the command "forecast(model=ARJI,...)" to do the one-step-ahead forecast of the Jump GARCH model.
Posted: Thu May 12, 2016 9:54 pm
No. It has a very specialized formula.
Posted: Thu Aug 10, 2017 8:43 am
by bb_poimot
Hi, Tom, I noticed that the differences between Chan and Maheau (2002) and Matheu&Mccurdy (2004, JF) also lie in the function g(.), the feedback coefficient from the past return innovations. In the 2004, JF paper, it allows the asymmetric effect from the past news(bad or good). Then how could we realize it in the coding? thanks.
Posted: Thu Aug 10, 2017 4:22 pm
There's an earlier post that shows how to compute the expected number of jumps:
https://estima.com/forum/viewtopic.php?p=7979#p7979
The change to the GARCH formula is relatively simple given that.
Posted: Wed Aug 30, 2017 9:37 am
by bb_poimot
TomDoan wrote:There's an earlier post that shows how to compute the expected number of jumps:
Hi, Tom, thanks for your reply. I am new to RATs. I can change the GARCH function but I am still not quite clear about how to put the value obtained from one user-defined function into the whole estimation process (particularly the frml hf=omega+alpha*u{1}^2+beta*h{1})? Should I save the jumpgarchx into one separate src or just insert it into the arjigarch.rpf ?
Do you have some link or reference from which I can learn how to use the user-defined function value in frml? Great thanks in advance.
Posted: Wed Aug 30, 2017 10:23 am
The use of the source file is to simplify the use of that function, which is needed in both of those programs. If you're just doing a single program, you may not need to strip that out.
The trickiest part about using a function inside a FRML is that, in most cases, it somehow depends upon time "T" information. If possible, it's usually simplest to make the time T references in the FRML rather than the function. For instance, in this:
frml logl = u=uf,h=hf,lambda_t=lambda0,deltasq_t=zeta0^2,theta_t=eta0,$
arjigarch(u,h,lambda_t,deltasq_t,theta_t,xi_t)
all six arguments actually refer to something that depends upon the entry number (U is the current residual, H the current GARCH process variance, etc.) which is what everything on that first line is computing. As long as you're still in the FRML definition, U (if U is a series) means U(T), and same for the other. Thus ARJIGARCH and JUMPGARCH and JUMPGARCHX don't actually need to know what time period they're computing.
Posted: Sun Mar 31, 2019 8:56 pm
by Max Resende
arjigarch_3_RBFin_TESTE.RPF
(11.38 KiB) Downloaded 2317 times
spot_1.txt
Data file
(33.35 KiB) Downloaded 2280 times
To all RATS users,
For quite a while i have been trying to replicate Chan & Maheu, JBES 2002 (ARJI-GARCH model) in order to lear more about extreme events and volatility.
I was able to replicate the model, but now I have been trying to expand it. I am trying to plot jump intensity (lambda_t) and its probability to all the 4 models to analyze then. But i am facing some mistakes that I don't how to corect it. So could you guys help me to graph theses two things for each model.
Thank you all.
Posted: Mon Apr 01, 2019 12:28 pm
First of all, because you have version 10, you can considerably simplify this by using mapped dates. This is out of a (modernized) version of the Chan-Maheu programs:
* The data are daily with holiday skips. This maps the year, month,
* day information to provide the dates.
cal(julian=%julianfromymd(year,month,day))
set r = 100.0*logret
* year:p gives entry <<p>> in the indicated year, so 1930:1 is the
* start of 1930, while 1985:1 is the first in 1985, so subtracting
* one from that gives the last entry in 1984.
compute start1930=1930:1,end1984=1985:1-1
For a specific date (rather than the above, which are for the first date and last date in a year), you can just use 2012:6:18 rather than having to find the entry with year(t)=2012..and.month(t)==6.and.day(t)==18.
If you are trying to graph the lambda_t from several different models, you'll have to copy the information to a unique series name for each after you're done with the estimation of it such as
set lambda_simple = lambda_t
after estimating the simple ARJI model.
You have a problem with this, as you are saying vfields=3, but you are including four graphs, so your first pane will be overwritten.
spgraph(vfields=3,footer="Figure 4")
scatter(header="(a) In Sample R",style=lines)
# codeddate r 4 end2014
scatter(header="(b) Lambda",style=lines)
# codeddate lambda_t 4 end2014
scatter(header="(c) Theta",style=lines)
# codeddate theta_t 4 end2014
scatter(header="(c) Delta",style=lines)
# codeddate deltasq_t 4 end2014
* set onestep = sqrt(h+lambda_t*(theta_t^2+deltasq_t))
* scatter(header="(c) One-step-ahead standard deviation",style=lines)
* # codeddate onestep 4 end2014
Use GRAPH rather than SCATTER with those (all the way through). The mapped dates will give you the year numbers on the axis.
Posted: Mon Apr 01, 2019 4:02 pm
by Max Resende
Thak you Tom....I was able to imporve my code.....
But i got another issue regardless of my Model ARJI-GARCH: Seems like my estimation has failed.
ARJI-R{1}^2 GARCH - Estimation by BFGS
NO CONVERGENCE IN 9 ITERATIONS. FINAL NORMED GRADIENT 4.22395
TRY DIFFERENT SETTING FOR EXACTLINE, DERIVES OR ALPHA ON NLPAR
RESTARTING ESTIMATION FROM LAST ESTIMATES OR DIFFERENT INITIAL GUESSES/PMETHOD OPTION MIGHT ALSO WORK
So, my estimation routine has failed to converge upon an optimum so the parameter estimates and their standard errors may be unreliable.
To solve that issue I tried changing my inicial non-linear parameters values, and that's what I got on my best model.
When I did that,my best results gave me this:
ARJI-GARCH - Estimation by BFGS
Convergence in 5 Iterations. Final criterion was 0.0000000 <= 0.0000100
LOW ITERATION COUNT ON BFGS MAY LEAD TO POOR ESTIMATES FOR STANDARD ERRORS
Then I used different algorithms (BHHH) , but none of that worked so far.
Could you guide me to solve that?
Thank you once again!!!
Max
Posted: Wed Apr 17, 2019 2:10 pm
Your estimates for the ARJI model are bumping into the time-varying lambda being zero (at which point the likelihood isn't computable). See the analysis in the paper around their equation (11). If you add their sufficient condition for forced positivity (rho>=gamma), it appears to work:
nonlin(parmset=poissonparms) lambda0 rho gamma rho>=gamma
