Faust(1998) VAR Shock isolation
Postby TomDoan » Fri Jun 01, 2012 12:27 pm
This is a replication of Faust(1998), "The Robustness of Identified VAR Conclusions About Money", Carnegie-Rochester Conference Series on Public Policy, vol 49, 207-244, the six variable model. This is aimed at bounding the amount of the variance in GDP that can be explained by a monetary policy shock, by maximizing the FEVD share of a shock across all shocks that satisfy a set of sign constraints that could reasonably be produced by a (contractionary) monetary policy shock.
This uses a different method for solving the maximization problem than is proposed by Faust. It uses the existing constrained optimization capabilities of RATS rather than a specialized eigenvalue solution.
faust.rpf
Program file
(3.53 KiB) Downloaded 64 times
lsznew.txt
Data file
(949.34 KiB) Downloaded 54 times
