PERRONBREAKS - Unit Roots with Structural Breaks
Updated 24 September 2011 to save additional information.
Attached is a procedure for a very general approach to handling unit root tests allowing for structural breaks. It is based upon the set of models in Perron(2006), "Dealing with Structural Breaks," in Palgrave Handbook of Econometrics, Vol. 1, pp 278-352, but with extension to allow more than one break. An example of its use with one and two breaks is provided at http://www.estima.com/forum/viewtopic.php?f=8&t=1215.
@PerronBreaks(options) series start end
The main options for choosing the type of structural breaks are:
AO=[NONE]/MEAN/CRASH/JOIN/BREAK
IO=[NONE]/MEAN/CRASH/BREAK
BREAKS=Number of breaks [1]
Number of breaks (allows for any positive number)
AO are for "additive outliers" which change immediately the level (trend) of the series. IO are for "innovational outliers" which add a shift to the error term and thus affect the series more gradually.
The augmenting lags are selected separately for each test value(s) of the breaks. These are controlled by the following options:
LAGS=number of lags on the auxiliary regression [1]
METHOD=[FIXED]/GTOS/AIC/SBC
SLSTAY=significance level to keep lag in model with METHOD=GTOS [.10]
If METHOD=FIXED, the number of lags on the LAGS option is included in all regressions. If METHOD=GTOS (general-to-specific), lags are dropped from the end so long as the significance level of the t-statistic is greater than the SLSTAY value.
