UFORERRORS - Analysis of (univariate) forecast errors
Postby TomDoan » Sun Jun 03, 2012 9:58 am
UForeErrors computes error statistics on a series of in-sample one-step forecasts. You supply the series of actual data and forecasts and it computes statistics such as the mean and root mean square errors.
uforeerrors.src
Procedure file (requires RATS 7.3 or later)
(4.33 KiB) Downloaded 84 times
@UForeErrors( options ) actual forecast start end
Parameters
actual series of actual values
forecast series of forecasts
start end range of forecasts to analyze (by default, the range of the series forecast)
Options
[print]/noprint
title=descriptive title for forecasts
theildecomp/[notheildecomp]
window=title for report window [not used]
Variables Defined
%%FERRMEAN mean forecast error
%%FERRMAE mean absolute error
%%FERRMSE root mean square error
%%FERRMPE mean percentage error
%%FERRMAPE mean absolute percentage error
%%FERRMSPE root mean square percentage error
Example
* Makridakis et al, Forecasting Methods and Applications, 3rd edition
* Example of moving average smoothing, pp 143-145
data(unit=input) 1 11 shipments
 200 135 195 197.5 310 175 155 130 220 277.5 235
* The filter instruction with TYPE=LAGGING computes the average of the
* input data for periods t,t-1,...,t-span+1
filter(type=lagging,span=3) shipments / ma3
filter(type=lagging,span=5) shipments / ma5
* The forecast values for t is just the smoothed value for t-1. This
* instruction handles that.
set ma3fore = ma3{1}
set ma5fore = ma5{1}
* This analyzes the forecasts errors
@uforeerrors(title="MA(3) forecasts") shipments ma3fore
@uforeerrors(title="MA(5) forecasts") shipments ma5fore
graph(footer="Figure 4-4 Shipments of Electric Can Openers with Moving Average Forecasts",$
 key=attached,klabels=||"Observed values","MA(3)","MA(5)"||) 3
# shipments
# ma3fore
# ma5fore
Sample Output
MA(3) forecasts
From 4 to 11
Mean Error                  17.7083333
Mean Absolute Error         71.4583333
Root Mean Square Error      79.9728687
Mean Square Error          6395.659722
Theil's U                     1.064827
Mean Pct Error               -0.012779
Mean Abs Pct Error            0.348937
Root Mean Square Pct Error    0.387478
Theil's Relative U            1.150330
Return to RATS Procedures
Who is online
Users browsing this forum: No registered users and 2 guests
