STARTEST - LM test for ESTAR/LSTAR effects
PostPosted: Mon Aug 20, 2012 11:11 am
This does an does an LM test for linearity vs an alternative of LSTAR or ESTAR (smooth transition autoregression) in a univariate autoregression. This was proposed by Terasvirta(1994), "Specification, Estimation and Evaluation of Smooth Transition Autoregressive Models", JASA, vol 89, no. 425, pp 208-218 (viewtopic.php?f=8&t=1586). A similar test which can be used in more general situations than an autoregression is @RegSTRTest (viewtopic.php?f=7&t=1807).
startest.src
Procedure file - requires RATS 7.3 or later
(4.18 KiB) Downloaded 214 times
@StarTest( options ) y start end
Options
D=delay on threshold variable [1]
P=lags in the autoregression [1]
TITLE=title for output ["Test for STAR in series ..."]
WEIGHTS=series of observation weights [equally weighted]
[PRINT]/NOPRINT
The WEIGHTS option can be used to adjust for outliers (viewtopic.php?f=8&t=1587).
Sample Output
Test         F-stat    Signif
Linearity    1.3304417 0.2536
H01          0.9515415 0.4650
H02          1.6445252 0.1777
H03          1.3025990 0.2846
H12          1.5318647 0.1751
This is a table of tests of interaction terms between the regressors and powers (1, 2 and 3) of the threshold lag.
Linearity is the joint test of all the interaction terms
H01 is a test of the first order interaction terms only
H02 is a test of the second order interaction terms only
H03 is a test of the third order interaction terms only
H12 is a test of the first and second order interactions terms only
Either an LSTAR or ESTAR should cause rejection of linearity and rejection of H12. H12 is the appropriate statistic if ESTAR is the main hypothesis of interest. If, H12 is rejected, but H03 is accepted, that points towards an ESTAR model, as opposed to an LSTAR.
Re: STARTEST - LM test for ESTAR/LSTAR effects
PostPosted: Wed Dec 12, 2012 5:27 am
by nbcheikh
Can we use the StarTest procedure for the multivariate case as follow ?
@StarTest( options ) depvar start end
# list of explanatory variables
PostPosted: Wed Apr 17, 2013 1:57 pm
nbcheikh wrote:Hi Tom,
Depending upon what you're trying to do, that may be covered by @RegSTRTest (viewtopic.php?f=7&t=1807).
