General F testing
bearlotus
General F testing
Unread post by bearlotus »
Using the F ratio '= [(R^2unrestricted - R^2restricted)/m]/[(1-R^2unrestricted)/(n-k)]' to test B4=B5=0.
How do I finish my code?
linreg lny
# constant lx2 lx3 lx4 lx5
Re: General F testing
I assume that you are doing this for illustrative purposes. If you just want the result, the simplest thing to do is
linreg lny
exclude
# lx4 lx5
Doing this by restricted and unrestricted:
linreg lny
# constant lx2 lx3
compute rssr=%rss,ndfr=%ndf
linreg lny
compute fstat=(rssr-%rss)/(2*%seesq)
cdf(title="Exclusion Restriction") ftest fstat 2 %ndf
bearlotus
Thank you. You are correct I am doing this for illustrative purposes.
Here is the code I was using, wasn't sure if it was the same test.
linreg lny
TEST(ZEROS)
# 4 5
When I run both test they have the same output for the F test, but it does not agree with my book.
F = 1.1224
All R^2 values agree, is the difference rounding error?
If the sum of squares in the book calculations are heavily rounded (to, say, three significant digits), then it's quite possible that the results will differ fairly substantially.
