Neural Network Dynamic Forecast
Postby TomDoan » Thu Mar 25, 2010 10:28 am
The following is an example of using a neural net model to do dynamic multiple step forecasts. The NNTEST instruction only does "static" forecasts, so dynamic forecasts require looping over the horizons and feeding the forecasts back in as the inputs. This is most conveniently done by making a copy of the endogenous variable and using the copy for the inputs.
* NNDynFore.prg
* Example of dynamic forecasting with neural networks
cal(q) 1959:3
open data nnetdat.rat
data(format=rats,ver) * 1996:3
set logy = log(gdpq)
set trend = t
compute fstart=1990:1
* For comparison, do an OLS fit through 1989:4 and dynamic forecast from
* there through the end of sample.
linreg logy * fstart-1
# constant logy{1 2}
uforecast olsdynamic fstart 1996:3
* Now fit a neural net model, using data through 1989:4. We use 5 hidden
* nodes and train to an R^2 of .999 (it doesn't quite make that in
* 500000 iterations). We need to allow the range to expand quite a bit
* to accomodate the trending data, hence the pad=.9 option. Even with
* that, the multiple step forecasts tend to trail off below trend as a
* result of the "squashing" function. With a smaller value of pad, this
* will be even more pronounced.
nnlearn(pad=.90,save=mv, $
  hidden=5,rsquared=.999,iters=500000,trace) * fstart-1
# logy{1 2}
# logy
* Compute static forecasts during the hold-back period.
nntest fstart 1996:3 mv
# logy{1 2}
# nnstatic
* Compute dynamic forecasts. In order to do dynamic forecasts, we have
* to loop over a set of one-step forecasts, feeding the forecasts back
* into the calculation. We'll create a copy of logy and use that as the
* input for NNTEST. This allows us to update the input series after each
* step without changing the values of our original logy series.
clear nndynamic
set logydyn = logy
do time = fstart,1996:3
   nntest time time mv
   # logydyn{1 2}
   # logydyn
   * Store the dynamic forecast
   compute nndynamic(time) = logydyn(time)
end do time
graph(key=upleft) 4
# logy
# nnstatic
# nndynamic
# olsdynamic
Data file:
NNETDAT.RAT
(3.25 KiB) Downloaded 234 times
Re: Neural Network Dynamic Forecast
Postby basher » Tue Nov 20, 2012 7:43 am
I tried to run the program using your data, I get the following error message. FYI, I am using Rats 8.0.
## SR5. Writing Range -32766 to 149 of Series GCQ. (Incorrect start,end or SMPL)
basher
Postby TomDoan » Tue Nov 20, 2012 11:43 pm
change the data instruction to
data(format=rats,ver) 1959:3 1996:3
Return to Other Time Series Analysis
Who is online
Users browsing this forum: No registered users and 2 guests
cron
