Bai-Perron test for structural change
Postby alvarezcc » Thu Aug 27, 2009 2:02 pm
I wonder if someone could provide me an example of the application of these test. I checked in the manual and the user guide but I find nothing. The main doubt is about the list of regressors that should be provided to perform the test. It woul also be very helpfull to know if there is some kind of considerations to take account for. Thanks in advance for your attention!!
Christian
alvarezcc
Re: Bai-Perron test for structural change
Postby TomDoan » Thu Aug 27, 2009 6:05 pm
You just run it on the regression of interest. Your main concern is that the critical values aren't valid for non-stationary data. The calculation is correct regardless (in terms of finding the optimal break points), but the critical values aren't in the presence of unit roots.
Postby alvarezcc » Thu Aug 27, 2009 11:00 pm
Is there a way to know which of the break dates is significant or better? Depending on the test specification one could get many break dates. In my case, I don´t have enough criteria to select the number of breaks other than that sugested by watching the graph. So how to choose the best break dates?
Christian
alvarezcc
Postby TomDoan » Fri Aug 28, 2009 9:33 am
As I mentioned in a different thread, the point of these multiple break point tests, whether Bai-Perron or Zivot-Andrews or Lee-Strazicich, or ..., is to check a specification of a fixed coefficient model. If the change point analysis shows a break in the specification, it is highly unlikely that you would respond to that information by replacing your original model with the same specification estimated in two subsamples. Instead, you would look for a change in specification, maybe finding a different proxy, or transformation of a variable, or addition of some regressor which would somehow model the break.
Return to Structural Breaks and Switching Models
Who is online
Users browsing this forum: No registered users and 0 guests
