Sign Restrictions-Decomposition of Variance
This adds the calculation of the fraction of variance explained to the Uhlig JME paper code (replacing uhlig2.prg). Note that the graph here is different from the one in the published paper. That graphed the decomposition of the forecast error revision, not the more standard forecast error itself. (The forecast error revisions are single terms rather than cumulated).
Tom Doan
Estima
* Replication File for Uhlig (2005), "What are the effects of monetary policy on
* output? Results from an agnostic identification procedure." Journal of Monetary
* Economics, 52, pp 381-419. Pure sign restriction approach
open data uhligdata.xls
calendar 1965 1 12
data(format=xls,org=columns) 1965:01 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1    = log(gdpc1)*100.0
set gdpdef   = log(gdpdef)*100.0
set cprindex = log(cprindex)*100.0
set totresns = log(totresns)*100.0
set bognonbr = log(bognonbr)*100.0
system(model=varmodel)
variables gdpc1 gdpdef cprindex fedfunds bognonbr totresns
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.","Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n1=200
compute n2=200
compute nkeep=1000
compute nvar=6
compute nstep=60
compute KMAX=5
* This is the standard setup for MC integration of an OLS VAR
compute sxx    =%decomp(%xx)
compute svt    =%decomp(inv(%nobs*%sigma))
compute ncoef  =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
* Most draws are going to get rejected. We allow for up to nkeep good ones. The
* variable accept will count the number of accepted draws. GOODRESP will be a
* RECT(nsteps,nvar) at each accepted draw.
declare vect[rect] goodresp(nkeep) goodfevd(nkeep)
declare vector ik a(nvar) ones(nvar)
declare series[rect] irfsquared
compute ones=%const(1.0)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) "Monte Carlo Integration"
do draws=1,n1
   * Make a draw from the posterior for the VAR and compute its impulse
   * responses.
   compute sigmad  =%ranwisharti(svt,wishdof)
   compute swish   =%decomp(sigmad)
   compute ranc    =%ran(1.0)
   compute betau   =sxx*ranc*tr(swish)
   impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
   gset irfsquared 1 1     = %xt(impulses,t).^2
   gset irfsquared 2 nstep = irfsquared{1}+%xt(impulses,t).^2
   * Do the subdraws over the unit sphere. These give the weights on the
   * orthogonal components.
   do subdraws=1,n2
      compute a=%ran(1.0),a=a/sqrt(%normsqr(a))
      * Check that the responses have the correct signs for steps 1 to KMAX+1
      * (+1 because in the paper, the steps used 0-based subscripts, rather than
      * the 1 based subscripts used by RATS).
      do k=1,KMAX+1
         compute ik=%xt(impulses,k)*a
         if ik(4)<0.or.ik(3)>0.or.ik(2)>0.or.ik(5)>0
            branch 105
      end do k
      * This is an accepted draw. Copy the information out. If we have enough
      * good ones, drop out of the overall loop.
      compute accept=accept+1
      dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
      ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
      ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
      if accept>=nkeep
         break
   :105
   end do subdraws
   if accept>=nkeep
      break
   infobox(current=draws)
end do draws
infobox(action=remove)
* Post-processing. Graph the mean of the responses along with the 16% and 84%-iles
clear upper lower resp
spgraph(vfields=3,hfields=2,footer="Figure 6. Impulse Responses with Pure-Sign Approach")
do i=1,nvar
   smpl 1 accept
   do k=1,nstep
      set work = goodresp(t)(k,i)
      compute frac=%fractiles(work,||.16,.84||)
      compute lower(k)=frac(1)
      compute upper(k)=frac(2)
      compute resp(k)=%avg(work)
   end do k
   smpl 1 nstep
   graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
   # resp
   # upper / 2
   # lower / 2
spgraph(vfields=3,hfields=2,footer="Figure 8. Fraction of Variance Explained with Pure-Sign Approach")
do i=1,nvar
   compute minlower=maxupper=0.0
   smpl 1 accept
   do k=1,nstep
      set work = goodfevd(t)(k,i)
      compute frac=%fractiles(work,||.16,.50,.84||)
      compute upper(k)=frac(3)
      compute resp(k)=frac(2)
   end do k
   smpl 1 nstep
   graph(ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
   # resp
   # upper / 2
   # lower / 2
Alberto
minor correction
Unread post by Alberto »
Very useful, thanks.
Just a minor correction:
after "if ik(4)<0" there is a ".or.ik(3)" missing.
Alberto
Thanks for pointing that out. We have to be really careful about posting code because lines with <....> can get interpreted as HTML. I've corrected the code posted above.
jeremy25
Question
Unread post by jeremy25 »
I have a small question in respect to this code. Where exactly in this code you impose the specific "sign restrictions"?
Also when i try to run the code --- it gives me an error message as such
## SX14. Ill-formatted number
>>>>= %xt(impulses,t).^<<<<
i am using a version 6.0 of RATS...is this an incompatibility (synatx) error?
I would appreciate any help on that issue. Thanks
econdawg
Re: Sign Restrictions-Decomposition of Variance
Unread post by econdawg »
Tom,
The code here allows for the identification of one shock. i am using the identifying sign restrictions in a paper i am working on and i was thinking about identifying more than one shock at the same time (say 2 shocks). i am kinda puzzled as to how to incorporate that in the code. Would identifying a second shock implies doing a second inner-loop subdraw for another vector over the unit sphere? That is i would still draw initially from the posterior of the VAR then compute impulse responses, but instead of doing one subdraw (and compute a) for each draw from the posterior, i would do two subdraws (and compute a and another vector--say b). then i would be essentially be constructing 2 impulse vectors simultaneously and go from there to check sign restrictions to identify the two shocks of interests. am i thinking right about this? it would be very helpful (if you have time) to maybe guide me as to how i would modify the code in order to identify that second shock. Thanks.
