Generalized Impulse Responses
Postby guillaume » Thu Jul 02, 2009 4:36 am
Hi
Is there a procedure to obtain directly GIR and their confidence intervals in a VAR? I can not find any example with the procedure and example browser on estima website.
guillaume
Re: Impulse response function
Postby TomDoan » Thu Jul 02, 2009 9:48 am
guillaume wrote:Hi
This is from the July 2002 RATS newsletter
<<quote>>
Generalized Impulse Responses (Pesaran and Shin, (1998), “Generalized Impulse Response Analysis in Linear Multivariate
Models”, Economics Letters, 58, 17-29) are an attempt to avoid the difficulties of identifying orthogonal shocks in VAR models. This is not a particularly complicated idea; in fact, all these do is compute the shocks with each variable in turn being first in a Choleski order. These can be done quite easily using RATS; the following:
declare rect f(n,n)
ewise f(i,j)=sigma(i,j)/sqrt(sigma(j,j))
impulse(decomp=f) etc.
will give you the GIR.
However, while these can, quite easily, be done in RATS, we do not recommend them. While coming up with an orthogonalizing model can, in practice, be somewhat difficult, it is a necessary step. A set of responses to highly correlated
shocks are almost impossible to interpret sensibly. For instance, you can’t run an ERRORS instruction to assess the
economic significance of the responses, since that requires an orthogonal decomposition of the covariance matrix.
<<end quote>>
You can actually do this in-line with
impulse(decomp=sigmad*inv(%diag(%sqrt(%xdiag(sigmad))),etc.)
If you replace the decomp=swish in montevar with that, you'll get what you want.
Postby luxu1983 » Tue Aug 18, 2009 12:22 pm
TomDoan wrote:
guillaume wrote:Hi
<<quote>>
declare rect f(n,n)
<<end quote>>
dear TomDoan
declare rect f(n,n)
sigma in the code stands for what ?? it is variance-covariance matrix of the VAR model ?
thanks
luxu1983
Postby TomDoan » Tue Aug 18, 2009 12:51 pm
luxu1983 wrote:dear TomDoan
declare rect f(n,n)
thanks
Yes. It's the covariance matrix for the VAR.
Re: Generalized Impulse Responses
Postby nazif » Fri Jan 06, 2012 6:43 am
Dear Doan,
I wrote this simple code to measure the oil pass-through under different inflationary environments. Could you please help me to modify this code to produce generalized irfs with 1 standard deviation error bands?
Thanks for your help.
Nazif
open data oil_output_rats_level_en_eco.xls
calendar(m) 1987
data(format=xls,org=columns) 1987:1 2011:3
compute [vect[strings]] implabel=|| "dlind","dlcoil", "dlner", "dlgasr", "dlcpi"||
compute  nsteps = 18
compute  p = 3
set low =  DLCPI{1}< 0.01746
set high = DLCPI{1}>=0.01746
graph(shading=high) 1
# DLCPI
*********High Inflation Regime********************************************************
system(model=poilmodel1)
variables DLINDTR DLROIL DLNER DLgaSCPI DLcPI
lags 1 to p
estimate(resids=varresids, smpl=high)
errors(model=poilmodel1,window="Variance Decomposition(High)", steps=nsteps)
impulse(model=poilmodel1, window="Impulse Responses", steps=nsteps, result=impulseshigh)
@MCVARDoDraws(model=poilmodel1, steps=nsteps)
@MCGraphIRF(model=poilmodel1,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=all,HEADER='High Inflation',STDDEV=1.0,INCLUDE=||4,5||)
*******Linear VAR******************************************************************************
system(model=poilmodel2)
lags 1 to p
estimate(resids=varresids)
errors(model=poilmodel2,window="Variance Decomposition(linear)", steps=nsteps)
impulse(model=poilmodel2, window="Impulse Responses", steps=nsteps, result=impulses)
@MCVARDoDraws(model=poilmodel2, steps=nsteps)
@MCGraphIRF(model=poilmodel2,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=all,HEADER='Linear VAR',STDDEV=1.0,INCLUDE=||4,5|| )
******Low inflation Regime************************************************
system(model=poilmodel3)
lags 1 to 4
estimate(resids=varresids, smpl=low, noprint)
errors(model=poilmodel3,window="Variance Decomposition(Low)", steps=nsteps)
impulse(model=poilmodel3,window="Impulse Responses", steps=nsteps, result=impulseslow)
@MCVARDoDraws(model=poilmodel3, steps=nsteps)
@MCGraphIRF(model=poilmodel3,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=all,HEADER='Low Inflation',STDDEV=1.0,INCLUDE=||4,5||)
nazif
Postby TomDoan » Fri Jan 06, 2012 8:34 am
Make a copy of MCVARDoDraws (renamed both the procedure file and the procedure itself) and modify it for GIRF by following the directions in
http://www.estima.com/forum/viewtopic.php?f=7&t=333
It's a one-line change.
Return to VARs (Vector Autoregression Models)
Who is online
Users browsing this forum: No registered users and 2 guests
