BQDoDraws for more than 2 variables
Hello. I've been trying to adapt the BQDoDraw procedure for 4 variables and even though I've tried over and over, when I run it with MCFEVD, the graph that appears has only the OY axis and the rest is empty. I really don't understand what's going on, there is no message error so I have no clu what's going on. I suspect it may be the "accumulate" option in the BQDoDraw, maybe I haven't modified it properly.
Help would be greatly appreciated, especially since time is rather short.
Thank you very much.
This is the procedure:
option model model
option integer draws 1000
option integer steps 24
option vect[int] accum ||1, 2, 3, 4||
local integer nvar
local rect fxx fwish fsigmad factor
local integer wishdof
local rect betaols betau betadraw
local symm sigmad
local integer i j draw
compute fxx =%decomp(%xx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
compute betaols=%modelgetcoeffs(model)
local rect[series] impulses(nvar,nvar)
declare vect[rect] %%responses(draws)
infobox(action=define,progress,lower=1,upper=draws) "Monte Carlo Integration"
do draw=1,draws
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigmad =%decomp(sigmad)
compute betau =%ranmvkron(fsigmad,fxx)
else
compute %modelsetcoeffs(model,betadraw)
compute factor=%bqfactor(sigmad,%modellagsums(model))
impulse(noprint,model=model,factor=factor,results=impulses,steps=steps)
do i=1,%rows(accum)
acc impulses(accum(i),1) 1 steps
acc impulses(accum(i),2) 1 steps
acc impulses(accum(i),3) 1 steps
acc impulses(accum(i),4) 1 steps
dim %%responses(draw)(nvar*nvar,steps)
ewise %%responses(draw)(i,j)=impulses((i-1)/nvar+1,%clock(i,nvar))(j)
infobox(current=draw)
end do draw
infobox(action=remove)
compute %modelsetcoeffs(model,betaols)
end BQDoDraws_4
And this is my program:
calendar(q) 1998:3
allocate 2008:3
open data D:\date
data(format=xls, org=columns) / dlgdp dlgov dlcpi lrer
set difgdp = dlgdp - dlgdp{1}
set difrer = lrer-lrer{1}
print
system(model=rervar)
variables dlgov difgdp difrer dlcpi
lags 1 to 2
estimate(residuals=resids, coefficients=coeff) 1998:4 2008:3
display coeff
compute [vect[strings]] shocklabels=||"1","2","3","4"||
compute [vect[strings]] vlabels=||"a","b","c","d"||
source D:\BQDoDraws_4
@BQDoDraws_4(model=rervar)
option model model
local integer nvar
local symm sigmad
do draw=1,draws
else
do i=1,%rows(accum)
end do draw
end BQDoDraws_4
calendar(q) 1998:3
allocate 2008:3
open data D:\date
lags 1 to 2
display coeff
