* Bayesian Econometrics Workbook, Example 6.8
* Gibbs sampling on a Bayesian VAR with a "Minnesota" prior
compute lags=4 ;*Number of lags
compute nstep=16 ;*Number of response steps
compute nburn=500 ;*Number of burn-in draws
compute ndraws=2500 ;*Number of keeper draws
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc = log(cbhm)
* These are the controlling parameters for the symmetric "Minnesota"
* prior - the own lag tightness and the relative tightness on the other
* lags.
compute tight=.1
compute other=.5
* First, estimate the system with a prior via mixed estimation, to see if
* we come up with something similar via Gibbs sampling.
system(model=varmodel)
variables loggdp loginv logc ftb3
lags 1 to lags
specify(type=symmetric,tight=tight) other
* Estimate with a prior
estimate
compute nvar=%nvar
source bvarbuildprior.src
@BVARBuildPriorMN(model=varmodel,tight=.1,other=.5) hbpriors hpriors
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
dec vect[series] forecast(nvar)
dec vect[series] forestderr(nvar)
* Range to forecast
compute fstart=%regend()+1
compute fend =fstart+nstep-1
dec series[rect] forecasts
gset forecasts fstart fend = %zeros(nvar,ndraws)
infobox(action=define,progress,lower=-nburn,upper=ndraws) "Gibbs Sampler"
do draw=-nburn,ndraws
infobox(current=draw)
* Draw b given sigma
compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
compute rssmat=%sigmacmom(%cmom,bdraw)
* Draw sigma given b
compute sigmad=%ranwisharti(%decomp(inv(rssmat)),%nobs)
if draw<=0
next
compute %modelsetcoeffs(varmodel,bdraw)
simulate(model=varmodel,cv=sigmad,results=simresults,steps=nstep)
gset forecasts fstart fend = %psubmat(forecasts(t),1,draw,%xt(simresults,t))
end do draw
infobox(action=remove)
dec vect[series] faninput(7)
do i=1,7
set faninput(i) fstart fend = 0.0
dec vect fjt percent
do j=1,nvar
do time=fstart,fend
compute fjt=%xrow(forecasts(time),j)
compute percent=%fractiles(fjt,||.005,.05,.25,.50,.75,.95,.995||)
compute %pt(faninput,time,percent)
end do time
graph(style=line,overlay=fan,ovcount=6,ovsame,$
header="Forecasts of "+%l(%modeldepvars(varmodel)(j))) 7
# faninput(4)
# faninput(1)
# faninput(2)
# faninput(3)
# faninput(5)
# faninput(6)
# faninput(7)
end do jReturn to VARs (Vector Autoregression Models)
