VAR Forecast from Difference to Levels
rmvoller
Unread post by rmvoller »
I have ran the following VAR model on two differenced series:
System(model=dvar)
variables dx dy
lags 1 to 4
estimate  * 2011:1
forecast(model=dvar,from=2011:2,to=2012:3,result=forecast,stderrs=s,print)
When I restrict the time series by a few periods for the in sample forecast I am able to to convert the differenced forecast to levels with the following code:
set xforecast = forecast(1) + x{1}
But when I run the Var model on the full data series I am unable to convert the differenced forecasts by using the above formula. Below is the code for the Var over the full series. How could I convert my differenced forecast into levels?
System(model=dvar)
variables dx dy
lags 1 to 4
estimate
forecast(model=dvar,from=2012:3,to=2016:4,result=forecast,stderrs=s,print)
Thanks in advance
Re: VAR Forecast from Difference to Levels
There are many different ways to do that. The simplest is probably:
set(first=forecast(1)+x{1}) accx 2012:3 2016:4 = accx{1}+forecast(1)
Agty
Unread post by Agty »
Hello everybody,
I have exactly the same problem as the one rmvoller posted on december 28, 2012. I've tried thousands of times the solution gave by Tom Doan, unsuscessfully with any kind of message errors. My quaterly four variables of interest are VCREDITSEns, TxImmo, IndPrixAncien and RDB. I have made forecasts of those variables in first differences (with the following code) and I am unable to move from Differences to Levels. Can someone tell me how to adapt TomDoan code to achieve this? I thank in advance.
smpl de f
system(model=dvar)
variables dVCREDITSEns dTxImmo dIndPrixAncien dRDB
lags 1 to 2
estimate
errors(model=dvar,steps=8)
FORECAST(MODEL=dvar,FROM=2013:01,TO=2018:04,result=forecast,stderrs=s,PRINT)
Something like this:
cal(q) 2000:1
all 2012:4
set VCREDITSEns = %ran(1.0)
set TxImmo = %ran(1.0)
set IndPrixAncien = %ran(1.0)
set RDB = %ran(1.0)
dofor i = VCREDITSEns TxImmo IndPrixAncien RDB
   set %s("d"+%l(i)) = i{0}-i{1}
end dofor s
system(model=dvar)
lags 1 to 2
estimate
FORECAST(MODEL=dvar,FROM=2013:01,TO=2018:04,result=dforecast,stderrs=s,PRINT)
dec vect[series] forecast(4)
set(first=dforecast(1)+vcreditsens{1})   forecast(1) 2013:1 2018:4 = dforecast(1)+forecast(1){1}
set(first=dforecast(2)+tximmo{1})        forecast(2) 2013:1 2018:4 = dforecast(2)+forecast(2){1}
set(first=dforecast(3)+indprixancien{1}) forecast(3) 2013:1 2018:4 = dforecast(3)+forecast(3){1}
set(first=dforecast(4)+rdb{1})           forecast(4) 2013:1 2018:4 = dforecast(4)+forecast(4){1}
timduy
Unread post by timduy »
Is there by chance a simple way to do the same for the standard errors - to create confidence intervals in levels?
timduy wrote:Is there by chance a simple way to do the same for the standard errors - to create confidence intervals in levels?
See the ACCUMULATE option on MCVARDODraws:
* @MCVARDoDraws(model=VAR model to analyze,other options)
* Computes impulse response functions for a VAR using Monte Carlo
* simulation. This assumes the model is an OLS VAR estimated using the
* ESTIMATE instruction. This uses a Cholesky factorization, though it
* can be modified fairly easily to do any just-identified factorization.
* Options:
* MODEL=model to analyze [required]
* STEP=number of response steps[48]
* DRAWS=number of Monte Carlo draws[1000]
* ACCUMULATE=list of variables (by position) to accumulate [none]
timduy
Tom:
So, circling back to this and realizing that I am just not seeing the link between @MCVARDoDraws and building up the confidence intervals in levels. Simple VAR model:
CAL(M) 1947:1
DATA(FORMAT=FRED) * * USREC PCEPI PCEPILFE
ALL 2020:4
SOURCE "/Applications/RATS 8.3/Procedures/REGACTFIT.src"
SOURCE "/Applications/RATS 8.3/Procedures/VARIRF.src"
SOURCE "/Applications/RATS 8.3/Procedures/MCVARDoDraws.src"
SOURCE "/Applications/RATS 8.3/Procedures/MONTEVAR.src"
LOG PCEPI
LOG PCEPILFE
DIFF PCEPILFE / CORE
DIFF PCEPI / HEADLINE
*ESTIMATE PREFERRED MODEL***
SYSTEM(MODEL=COREVAR)
VARIABLES  CORE HEADLINE
LAGS 1 TO 6
DET CONSTANT
END(SYSTEM)
ESTIMATE 1984:1 *
FORECAST(MODEL=COREVAR,NOSTATIC, RESULTS=COREFOR, STDERRS=COREERRORS, FROM=2014:4,TO=2016:12)
That will forecast the differences for the two variables, which I can build into level forecasts. Then I use:
@MCVARDoDraws(model=COREVAR,ACCUMULATE=||1,2||)
Which yields 4 IRF's...but I am thinking in the background is the standard errors for the IRF's which can then be turned into the level forecasts standard errors? Or is that off base?
Thanks for the help!
To get the calculation of the standard errors of forecast of the accumulated data, you need to use "integrating" identities.
equation(identity,coeffs=||1.0,1.0||) icoreeq icore
# icore{1} core
equation(identity,coeffs=||1.0,1.0||) iheadeq iheadline
# iheadline{1} headline
FORECAST(MODEL=COREVAR+icoreeq+iheadeq,NOSTATIC, RESULTS=COREFOR, STDERRS=COREERRORS, FROM=2014:4,TO=2016:12)
That will forecast both the original and integrated series and compute standard errors of forecast for all of them. While the IRF's have all the information for computing the multiple step forecast standard errors, putting the information together isn't simple.
timduy
Thanks - it would have taken me awhile to get there.
I think I came up with another workaround. I defined a cointegrating vector as:
EQUATION(COEFFS=||0.0,0.0||) CIRELAT2
#PCEPI PCEPILFE
and then ran the error correction model:
VARIABLES PCEPI PCEPILFE
LAGS 1 TO 6
DET CONSTANT
ECT CIRELAT2
END(SYSTEM)
ESTIMATE 1984:1 *
which collapses to a VAR in differences but with level forecasts. Just need to make sure to set the lag length appropriately to match the initial VAR model.
Thanks. I believe just
ECT
by itself will do the same thing so you don't have to define the zeroed out equation. That, of course, doesn't give you the forecasts of the differenced variables in case you want both, but if you just want the integrated results, then the empty ECT will work fine.
ac_1
Unread post by ac_1 »
My aim is to estimate a VAR in DIFFERENCES and back out LEVELS forecasts and LEVELS standard errors, hence plot PI's for the forecasts of the ORIGINAL series.
From the above, which appears reasonable:
seed 13939
cal(q) 2000:1
all 2012:4
* generate ORIGINAL series in LEVELS
set RDB = %ran(1.0)
prin / VCREDITSEns TxImmo IndPrixAncien RDB
* calculate DIFFERENCE series
end dofor s
prin / dVCREDITSEns dTxImmo dIndPrixAncien dRDB
* estimate VAR for DIFFERENCE series
system(model=dvar)
lags 1 to 2
estimate
errors(model=dvar,steps=8); * decomposition of variance for VAR
prin / dforecast(1) dforecast(2) dforecast(3) dforecast(4)
prin / s(1) s(2) s(3) s(4)
* Back-out forecasts in LEVELS for ORIGINAL series in LEVELS, having estimated VAR for DIFFERENCE series
prin / forecast(1) forecast(2) forecast(3) forecast(4)
I want to back-out forecast SE's in LEVELS for ORIGINAL series in LEVELS, having estimated VAR for DIFFERENCE series, as follows
equation(identity,coeffs=||1.0,1.0||) idVCREDITSEnseq idVCREDITSEns
# idVCREDITSEns{1} dVCREDITSEns
equation(identity,coeffs=||1.0,1.0||) idTxImmoeq idTxImmo
# idTxImmo{1} dTxImmo
equation(identity,coeffs=||1.0,1.0||) idIndPrixAncieneq idIndPrixAncien
# idIndPrixAncien{1} dIndPrixAncien
equation(identity,coeffs=||1.0,1.0||) idRDBeq idRDB
# idRDB{1} dRDB
FORECAST(MODEL=dvar+idVCREDITSEnseq+idTxImmoeq+idIndPrixAncieneq+idRDBeq,NOSTATIC,RESULTS=COREFOR,STDERRS=COREERRORS,FROM=2013:1,TO=2018:04)
Equivalence's:
* forecast's of DIFFERENCE series, same as dforecast(1), dforecast(2), dforecast(3), dforecast(4)
prin / COREFOR(1) COREFOR(2) COREFOR(3) COREFOR(4)
There is nothing in. Why?
prin / COREFOR(5) COREFOR(6) COREFOR(7) COREFOR(8)
Are these the forecast SE's for the ORIGINAL series in LEVELS?
prin / COREERRORS(5) COREERRORS(6) COREERRORS(7) COREERRORS(8)
Or these?
prin / COREERRORS(1) COREERRORS(2) COREERRORS(3) COREERRORS(4)
However neither of these are equivalent to the forecast SE's for the DIFFERENCE series
thanks,
Amarjit
You have identities which say that (for instance) idRDB = idRDB{1}+dRDB. However, you don't define idRDB. Shouldn't that be RDB? That's the relationship isn't it?
ac_1
TomDoan wrote:You have identities which say that (for instance) idRDB = idRDB{1}+dRDB. However, you don't define idRDB. Shouldn't that be RDB? That's the relationship isn't it?
Thanks. I have changed the identities to:
equation(identity,coeffs=||1.0,1.0||) VCREDITSEnseq VCREDITSEns
# VCREDITSEns{1} VCREDITSEns
equation(identity,coeffs=||1.0,1.0||) TxImmoeq TxImmo
# TxImmo{1} TxImmo
equation(identity,coeffs=||1.0,1.0||) IndPrixAncieneq IndPrixAncien
# IndPrixAncien{1} IndPrixAncien
equation(identity,coeffs=||1.0,1.0||) RDBeq RDB
# RDB{1} RDB
FORECAST(MODEL=dvar+VCREDITSEnseq+TxImmoeq+IndPrixAncieneq+RDBeq,NOSTATIC,RESULTS=COREFOR,STDERRS=COREERRORS,FROM=2013:1,TO=2018:04)
There are values in:
There are zeroes in:
And forecast SE's in:
Which I think are for the ORIGINAL series in LEVELS. Right?
# TxImmo{1} TxImmo
# RDB{1} RDB
Those aren't right. What happened to the "D" series on the RHS?
Note, by the way, that with RATS v10 you can use FRML's for the identities. (This thread was started several years before version 10 was out).
ac_1
# TxImmo{1} TxImmo
# RDB{1} RDB
Apologies. Are these correct?
# VCREDITSEns{1} dVCREDITSEns
# TxImmo{1} dTxImmo
# IndPrixAncien{1} dIndPrixAncien
# RDB{1} dRDB
