IRF minimum distance estimator
chaveslima
Unread post by chaveslima »
I would like to calculate the Minimum Distance Estimation between empirical and theoretical impulse response functions based on Huelsewig, Mayer and Wollmershaeuser (2005). I appreciate anyone sending me some tips on how to do this on RATS.
Re: IRF minimum distance estimator
This shows the general structure of the calculation. Without the data, you obviously can't fully demonstrate it, but this shows how to set up and get the IRF's for the theoretical model.
* (First run at) Replication file for Hulsewig, Mayer &
* Wollmershauser(2006),  "Bank loan supply and monetary policy
* transmission in Germany: An assessment based on matching impulse
* responses," Journal of Banking & Finance, vol. 30, no 10, 2893-2910.
declare real b1 b2 nai delta1 delta2 gamma1 gamma2 gamma3
declare series y l rl rm eta
* Set up the DSGE. This uses the original optimization equation from the
* appendix rather than the partially substituted one in the main text.
frml(identity) eqna6 = beta*l{-1}-(1+beta)*l+l{1}+nai*(rl-rm)
frml(identity) eqn14 = b2*rl - (b1*y - l)
frml(identity) eqn15 = y - (gamma1*y{1}+gamma2*rl{1}+gamma3*rl{2})
frml(identity) eqn16 = rm - (delta1*rm{1}+delta2*rm{2}+eta)
frml s1 = eta
compute nsteps=20
compute beta=.99
compute b1=2.1887,b2=.0142,nai=.0010,delta1=1.4665,delta2=-.5204
compute gamma1=.9985,gamma2=.0009,gamma3=-.0026
group loanmodel eqna6 eqn14 eqn15 eqn16 s1
dsge(a=a,f=f,model=loanmodel) y rm l rl eta
* They don't report the standard error of the shock, but it appears to
* be roughly .2.
@dlmirf(a=a,f=f*.2,steps=nsteps,varlabels=||"GDP","RM","LOAN","RL"||,page=byshock)
* You need the estimated IRF's from the VAR and their variances in order
* to do the optimization. This assumes that the estimated IRF's to the
* rate shock are in the series estimated(i,1) and the corresponding
* variances are in estvar(i,1).
nonlin(parmset=dsgeparms) b1 b2 nai delta1 delta2 gamma1 gamma2 gamma3
declare real ceemetric
find(parmset=dsgeparms) minimum ceemetric
   * Solve the DSGE given the current values
   @dlmirf(a=a,f=f*.2,steps=nsteps,results=theoretical)
   compute ceemetric=0.0
   do h=1,nsteps
      do i=1,4
         compute ceemetric=ceemetric+(theoretical(i,1)(h)-estimated(i,1)(h))^2/estvar(i,1)(h)
   end do h
end find
chaveslima
Dear Sr.
I am trying to replicate the paper "Minimum Distance Estimation between empirical and theoretical impulse response
functions based on Huelsewig, Mayer and Wollmershaeuser (2005)". You've already sent me part of the procedure,
but I still need the VAR program and database to run. In the procedure I've got from you it says:
* variances are in estvar(i,1).[/i][/i]
So, I would appreciate you sending me this part of the program.
thanks
Ricardo
If you get the data from the authors, I could show you how to do that.
chaveslima
Tomm
I have similar data from Brazil. If you send me the whole program I can plug in
my data and run it. Would it be easier for you if I send you my data? How can I attach an
excel file to this message?
chaveslima
If you tell me how to produce the estimated IRF's to the rate shock [estimated(i,1)] and its corresponding
corresponding variances [estvar(i,1)] in the VAR model, I could plug in the program you've sent me.
regards
Ricardo
chaveslima wrote:Dear Tom
regards
Ricardo
Those are just the standard Monte Carlo IRF means and variances.
chaveslima
Tom, I am running this model, but a couple of bugs have come up
open data credsin3.xls
calendar(q) 1995:1
data(format=xls,org=columns) 1995:1 2012:1 pibr dpib selic cred
x11(multiplicative,adjusted=apibr) pibr
x11(multiplicative,adjusted=adpib) dpib
x11(multiplicative,adjusted=acred) cred
set lpibr = log(apibr)
set lcred = log(acred)
*print / lpibr dpib selic lcred
system(model=varmodel)
variables lpibr adpib selic lcred
lags 1 to 1
*compute [vect[strings]] implabel=||"lpibr","adpib","selic","lcred"||
estimate(noprint)
@MCVARDoDraws(model=varmodel,DRAWS=1000)
@MCGraphIRF(model=varmodel)
impulse(model=varmodel,noprint,result=estimated,steps=24,cv=%sigma)
do i = 1,4
print / estimated(i,1)
end do
declare real beta b1 b2 nai delta1 delta2 gamma1 gamma2 gamma3
frml s1 = eta
compute nsteps=20
compute beta=.99
* be roughly .2.
@dlmirf(a=a,f=f*.2,steps=nsteps,varlabels=||"GDP","RM","LOAN","RL"||,page=byshock,results=theoretical)
after this point it stops working
find minimum ceemetric
   do h=1,nsteps
      do i=1,4
         compute ceemetric=ceemetric+(theoretical(i,1)(h)-estimated(i,1)(h))^2/%sigma(i,1)(h)
   end do h
end find
question: can I use %sigma(i,1) to represent IRF variance?
you can see that I am mixing my data with Huelsewigs theoretical IRF. It is
just to run the model. Once I run it and produce the CEEMETRIC statistics, I will
redo my model using correct theoretical IRF. Thanks a lot for any help
Site Admin
Unread post by moderator »
Ricardo,
Looking at the code, I assume this command
is giving you an error like this
## SX17. Missing Operator or Adjacent Operands
>>>>(h))^2/%sigma(i,1)(<<<<
The %SIGMA array is just a regular two-dimensional symmetric array, so the reference to element (h) after the (i,1) reference doesn't make any sense. In Tom Doan's original code, the (h) reference a given step (horizon) for the IRF and variances. I'm not sure what you had in mind there, but if you just wanted to refer the fixed (i.e. unchanging over the IRF horizon) variances stored in %sigma, you could do
I'm not sure that really makes sense though?
Tom Maycock
Estima
chaveslima
Hello Tom
My minimum distance estimator model is working, but I would be very thankful you helping me with a couple of things:
1) The model sets up the parameters (b1=2.1887, b2=0.0142, nai=0.0010, and so on) to do a DSGE and calculate the minimum distance estimator. In the Huelsewig paper, however, the same parameters values are found as a product of the minimum distance estimator calculation. Why set up b1, b2, etc. using those velue?;
2) When I finish running my model, after the last line on the program bellow, it gives me the following message:
FIND Optimization - Estimation by Simplex
Function Value 93.0423
NO ESTIMATED COEFFICIENTS
Variable Coeff
How can I get the variables coefficients? Are those coefficients on the PARMSET=DGSEPARMS option of the nonlin?
calendar(q) 1995:1
lags 1 to 1
estimate(noprint)
@MCVARDoDraws(model=varmodel,DRAWS=1000,step=24)
@MCprocessIRF(model=varmodel,center=mean,stddev=1,IRF=results,upper=ub,lower=lb)
do i=1,4
print / lb(i,1) results(i,1) ub(i,1)
end i
dec rect[series] sd(4,4)
do i=1,4
do j=1,4
set sd(i,j) = ub(i,j) - results(i,j)
do h=1,4
print / sd(h,1)
end do h
spgraph(vfields=2,hfields=2,header="estimated irfs")
do i=1,4
graph(key=upleft) 3
# results(i,1)
# ub(i,1) / 2
# lb(i,1) / 2
do i = 1,4
end do
frml s1 = eta
compute nsteps=24
compute beta=.99
* be roughly .2.
@dlmirf(a=a,f=f*.2,steps=24,varlabels=||"GDP","RM","LOAN","RL"||,page=byshock,results=theoretical)
do j = 1,4
print / theoretical(j,1) results(j,1)
end do
spgraph(vfields=2,hfields=3,header="theoretical irfs")
do i=1,4
graph 4
# theoretical(i,1)
# results(i,1)
# ub(i,1) / 3
# lb(i,1) / 3
do h=1,nsteps
do i=1,4
compute ceemetric=ceemetric+(theoretical(i,1)(h)-results(i,1)(h))^2/sd(i,1)(h)
end do h
end find
Although you can back the variances of the responses out of the upper bounds and mean, I've added a VAR option to @MCPROCESSIRF to get those directly. What you want is
@MCprocessIRF(model=varmodel,center=mean,irf=estimated,var=estvar)
The FIND needs the PARMSET
chaveslima
Tom
When I do
it starts printing the last set of graphs indefinitely. That is, it prints the same graph (last graph) all over again.
Any idea of what is happening?
You need a NOGRAPH on the DLMIRF procedure call. Please note that I didn't have any data to actually run this so there will be some minor glitches.
chaveslima
Thanks Tom, It did work.
chaveslima
Hello Tom
My estimation worked all right using find(parmset=dsgeparms), and I am getting the value function and
variables coefficients. A final question is: how can I get the coefficient estimate standard errors?
regards
Ricardo
