Identifying VARs with sign restrictions
Re: Identifying VARs with sign restrictions
Thanks. This question was motivated from the variance decomposition numbers I got after running these codes, SEQUENTIALLY. I understand when shocks are not orthogonal, the variance decomposition is not strictly valid. However, what I get and surprises me is that the variance decompositions yield a more or less the same number (say 15%) for all variables due to a given shock. The impulse responses however look good. Any thoughts? I was looking for coding errors, but found none.
Not strictly valid is an understatement. There's no real justification for using the standard FEVD calculation on a set of non-orthogonal shocks. You can compute the fraction of variance for any one shock in isolation, using any generic method of completing a factorization. If that's what you think you're doing, and are getting odd results, you'll have to send the code and data to support@estima.com so we can look at it.
Could you give me some reference on the factorization so that I can look it up? I think this wasn't what I did. I just applied the variance operator which is incorrect. Thanks again!!!
That's what the ForcedFactor procedure does---it completes a factorization holding one or more columns fixed (up to scale). It's used extensively in the various Uhlig programs.
I have modified your Uhlig(2005)'s sign restriction code with historical decomposition for 4shocks
It works but since I'm a beginner, I might make some mistakes.
If I could have your instruction or checking, I will be very grateful.
Thank you very much.
OPEN DATA uhligdata.xls
CALENDAR 1965 1 12
compute missc=1.0e+32
data(format=xlS,org=columns) 1965:1 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
set cprindex = log(cprindex)*100.0
set totresns = log(totresns)*100.0
set bognonbr = log(bognonbr)*100.0
system(model=varmodel)
variables gdpc1 gdpdef cprindex fedfunds bognonbr totresns
lags 1 to 6
deterministic constant
estimate(noprint,resid=resids)
dec vect[strings] vl(6)
compute vl=||'Consumer Prices','Real GDP','Interest Rates',$
'Market Index Real Stock Prices','Financial Sector Index Real Stock Prices','Real Exchange Rates'||
compute n1=1000
compute n2=1000
compute nvar=6
compute nstep=20
compute KMAX=5
compute hstart = 1995:1
compute hend = 2003:12
compute nhor = hend-hstart+1
dec vect[series] upaths(nvar) u(nvar) onesteps(nvar) base(nvar) baseplus(nvar)
dec vect[series] upathsa(nvar) baseplusa(nvar)
dec vect[series] upathsaa(nvar) baseplusaa(nvar)
dec vect[series] upathsaaa(nvar) baseplusaaa(nvar)
clear upaths
clear upathsa
clear upathsaa
clear upathsaaa
* This is the standard setup for MC integration of an OLS VAR
dec symm s(6,6)
dec vect v1(6) ;* For the unit vector on the 1st draw
dec vect v2(5) ;* For the unit vector on the 2nd draw
dec vect v3(4)
dec vect v4(3)
dec vect v(6) ;* Working impulse vector
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
* Most draws are going to get rejected. We allow for up to 1000
* good ones. The variable accept will count the number of accepted
* draws. GOODRESP will be a RECT(nsteps,nvar) at each accepted
* draw.
declare vect[rect] goodresp(1000) goodfevd(1000)
declare vect[rect] goodrespa(1000) goodfevda(1000)
declare vect[rect] goodrespaa(1000) goodfevdaa(1000)
declare vect[rect] goodrespaaa(1000) goodfevdaaa(1000)
declare vector ik a(nvar) ones(nvar)
declare series[rect] irfsquared
compute ones=%const(1.0)
source forcedfactor.src
declare vector hk(nvar)
declare vect[rect] goodhist(1000) goodhista(1000) goodhistaa(1000) goodhistaaa(1000)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) 'Monte Carlo Integration'
do draws=1,n1
* Make a draw from the posterior for the VAR and compute its impulse
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute p =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(p)
* Use static forecasts over the period for historical decomposition to get the
* residuals. Use dynamic forecasts over the same period to get the base forecast
* series for the historical decomposition.
forecast(model=varmodel,from=hstart,to=hend,results=onesteps,errors=u,static)
forecast(model=varmodel,from=hstart,to=hend,results=base)
* This is changed to unit shocks rather than orthogonalized shocks.
impulse(noprint,model=varmodel,decomp=p,results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
gset irfsquared 2 nstep = irfsquared{1}+%xt(impulses,t).^2
* Do the subdraws over the unit sphere. These give the weights on the
* orthogonal components.
do subdraws=1,n2
* First Set of Restrictions - Unique Impulse Vector
compute v1=%ransphere(6)
compute i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v1
if ik(1)>0.or.ik(2)>0.or.ik(3)<0.or.ik(6)>0
branch 105
end do k
* Meets the first restriction
* Draw from the orthogonal complement of i1 (last five columns of the
* factor "f").
@forcedfactor(force=column) sigmad i1 f
compute v2=%ransphere(5)
compute i2=%xsubmat(f,1,6,2,6)*v2
compute v2=inv(p)*i2
* Second Set of Restrictions - 2nd Shock
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v2
if ik(1)<0.or.ik(2)<0
branch 105
end do k
@forcedfactor(force=column) sigmad i1~i2 f
compute v3=%ransphere(4)
compute i3=%xsubmat(f,1,6,3,6)*v3
compute v3=inv(p)*i3
* third Set of Restrictions - 3rd Shock
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v3
if ik(1)<0
branch 105
end do k
@forcedfactor(force=column) sigmad i1~i2~i3 f
compute v4=%ransphere(3)
compute i4=%xsubmat(f,1,6,4,6)*v4
compute v4=inv(p)*i4
* Forth Set of Restrictions - 4th Shock
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v4
if ik(1)>0
branch 105
end do k
* Meets both restrictions
compute accept=accept+1
dim goodrespa(accept)(nstep,nvar) goodfevda(accept)(nstep,nvar)
dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
dim goodrespaa(accept)(nstep,nvar) goodfevdaa(accept)(nstep,nvar)
dim goodrespaaa(accept)(nstep,nvar) goodfevdaaa(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*v1),ik(j)
ewise goodfevd(accept)(i,j)=(ik=(irfsquared(i)*(v1.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*v2),ik(j)
ewise goodfevda(accept)(i,j)=(ik=(irfsquared(i)*(v2.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodrespaa(accept)(i,j)=(ik=%xt(impulses,i)*v3),ik(j)
ewise goodfevdaa(accept)(i,j)=(ik=(irfsquared(i)*(v3.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodrespaaa(accept)(i,j)=(ik=%xt(impulses,i)*v4),ik(j)
ewise goodfevdaaa(accept)(i,j)=(ik=(irfsquared(i)*(v4.^2))./(irfsquared(i)*ones)),ik(j)
* Compute the historical paths of shocks to the system corresponding to the
* <<a>> weights on the Choleski factor.
dim goodhist(accept)(nhor,nvar) goodhista(accept)(nhor,nvar) goodhistaa(accept)(nhor,nvar) goodhistaaa(accept)(nhor,nvar)
compute remap=p*v1*tr(v1)*inv(p)
do t=hstart,hend
compute %pt(upaths,t,remap*%xt(u,t))
end do t
compute remap=p*v2*tr(v2)*inv(p)
do t=hstart,hend
compute %pt(upathsa,t,remap*%xt(u,t))
end do t
compute remap=p*v3*tr(v3)*inv(p)
do t=hstart,hend
compute %pt(upathsaa,t,remap*%xt(u,t))
end do t
compute remap=p*v4*tr(v4)*inv(p)
do t=hstart,hend
compute %pt(upathsaaa,t,remap*%xt(u,t))
end do t
* Forecast over the decomposition period with those added shocks
forecast(model=varmodel,from=hstart,to=hend,results=baseplus,paths)
# upaths
forecast(model=varmodel,from=hstart,to=hend,results=baseplusa,paths)
# upathsa
forecast(model=varmodel,from=hstart,to=hend,results=baseplusaa,paths)
# upathsaa
forecast(model=varmodel,from=hstart,to=hend,results=baseplusaaa,paths)
# upathsaaa
* Save the difference between the forecasts with and without and added shocks
* (and shift them into the slots 1,...,nhor) of <<goodhist>>.
ewise goodhist(accept)(i,j)=baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
ewise goodhista(accept)(i,j)=baseplusa(j)(i+hstart-1)-base(j)(i+hstart-1)
ewise goodhistaa(accept)(i,j)=baseplusaa(j)(i+hstart-1)-base(j)(i+hstart-1)
ewise goodhistaaa(accept)(i,j)=baseplusaaa(j)(i+hstart-1)-base(j)(i+hstart-1)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
infobox(current=draws)
end do draws
infobox(action=remove)
* Post-processing. Graph the mean of the responses along with the 16% and 84%-iles
clear upper lower resp
spgraph(vfields=6,hfields=4,subhea='Impluse Response')
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodresp(t)(k,i)
compute frac=%fractiles(work,||.16,.84||)
compute lower(k)=frac(1)
compute upper(k)=frac(2)
compute resp(k)=%avg(work)
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,picture='##.##',header=+vl(i)) 3
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespa(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespaa(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespaaa(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevd(t)(k,i)
compute frac=%fractiles(work,||.16,.50,.84||)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
display resp(k)
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevda(t)(k,i)
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevdaa(t)(k,i)
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevdaaa(t)(k,i)
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
declare series upperH lowerH respH
spgraph(vfields=3,hfields=2,hlabel="Figure X. Historical Decomposition with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
clear upperH lowerH respH
do k=hstart,hend
set work 1 accept = goodhist(t)(k-hstart+1,i)
compute lowerH(k)=frac(1)
compute upperH(k)=frac(3)
compute respH(k)=frac(2)
end do k
* compute maxupper=%max(maxupper,%maxvalue(upper)) ,min=minlower,max=maxupper
* compute minlower=%min(minlower,%minvalue(lower))
display 'contributions to variable' +vl(i)
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of 1st shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
smpl
do i=1,nvar
smpl 1 accept
do k=hstart,hend
set work 1 accept = goodhista(t)(k-hstart+1,i)
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of 2nd shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
do i=1,nvar
smpl 1 accept
do k=hstart,hend
set work 1 accept = goodhistaa(t)(k-hstart+1,i)
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of 3rd shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
spgraph(vfields=3,hfields=2,hlabel="Figure y. Historical Decomposition with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
do k=hstart,hend
set work 1 accept = goodhistaaa(t)(k-hstart+1,i)
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of 4th shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
YS
That looks correct.shugo wrote:Dear Tom,
I use code for four shocks from the forum.I am not quite sure whether the code is correct. Could you please give me some suggestions and feedbacks whether my code is correct?
Thank you very much for your help and kindness.
pei
pei
- shockdata.xls
- (62.5 KiB) Downloaded 1130 times
- code1.txt
- (20.37 KiB) Downloaded 1261 times
First off, do not start with a NOPRINT option on your ESTIMATE. Look at the output and see if there are problems. Once you're sure that the VAR itself is OK, you can put NOPRINT back on. In your case, it's not OK. ST is the difference between FIRON and PIRON, so you can't include all three in a VAR. You also aren't including a CONSTANT in the system, so the residuals appear to be much more correlated that they are. Offhand, it also appears that you're including in levels data series which would ordinarily be modeled in logs.pei wrote:Dear Tom,
pei
Your HSTART is also wrong; it needs to be the start of the estimation period (1986:7 with six lags), rather than the start of the data.
Finally, don't start with four shocks. Start with one. See if you can get that to work successfully. As it is, you're not even getting successful draws for the first shock.
Thank you very much for your suggestions.
I am a beginner, so there will be many problems cannot understand. Thank you for your patience to answer my questions.
I modified the sample,it works partially. But I don’t know what is worry with it, and how can I correct the mistakes.
Please give me some suggestions.
Sincerely,
pei
Sincerely,
pei
- ratsshock.RAT
- (16.75 KiB) Downloaded 1216 times
- shock.PRG
- (15.5 KiB) Downloaded 1249 times
The above is my code, I have modified the code for three shocks and four variables. Nevertheless, results do not appear.
I might do something wrong. Could you please give me some suggestions?
pei
pei
FRegensburg
Re: Mountford and Uhlig impact multipliers
Dear Mr Doan,
I need to calculate a statistic, presented by Mountford and Uhlig in their 2009 article, that allows one to arrive at the impact multipliers of the three policy experiments (as in pages 983-985 in the original paper)
the authors calculate, at different horizons, the impact multipliers, according to this formula:
Multiplier for GDP=(GDP response/initial -lag zero- fiscal shock)/(average fiscal variable share of GDP).
The last ratio is from the raw data, so that's not a problem. But what lines of code do I need add to the replication file code to extract the hard numbers to compute the first ratio?
I also need to calculate the maximum and minimum multipliers of the policy experiments, with confidence intervals (16th and 84th quantiles), with the same formula.
I look forward to hear from you, as I don't know how to do this.
Those are already being generated at the end of the mu2009x1.rpf and mu2009b1.rpf programs. They are being graphed by @MCGRAPHIRF. If you want the values to put into a table, use @MCPROCESSIRF instead (or in addition).
I am wondering is there any possibilities that in Uhlig code, realizing restriction like following:
Sign restrictions on impulse response functions
It is like for a specific shock, giving different restrictions on different lags. i tried with uhligaccept but seems it is not working.
thank you for your help! Also thanks for your advices about my historical decomposition problem.
cheers.
cheers.
You would have to modify UhligAccept (it would probably make sense to call it something else) to take a VECT[VECT[INT]] where the outer VECT is over steps and the inner over variables. For instance, the loan supply shock would have an input of ||||+1,+2,-4||,||+1,+2,+3,-4||,||+1,+2,+3,-4,+5||||
