Graph with series differentiate by colors and symbols
PostPosted: Wed Jan 25, 2012 3:55 pm
by Aktar
I don't find the code needed for differentiate series with symbol and in the same time with color on a same graph. The style symbols give the same output.
Thank You.
Re: Graph with series differentiate by colors and symbols
PostPosted: Wed Jan 25, 2012 4:43 pm
by moderator
If you want series to have both different colors and different symbols, you can use the Graph Style Sheet feature. This allows you to create your own style definitions, saved in a text file, which you read in using OPEN and GRPARM(IMPORT=...) instructions.
If you have version 8, see the Introduction (Section 3.16 in particular) for details.
Tom Maycock
Estima
PostPosted: Tue May 14, 2013 4:38 pm
by randerson
Might someone post the 6-digit hex codes for the line default line colors? I did not see these in the manual. These appear to be needed when using graph style sheets to add symbols to colored lines.
PostPosted: Tue May 14, 2013 9:21 pm
These are the colors of the first nine:
  1. RGB_BLACK 000000
  2. RGB_BLUE 0000FF
  3. RGB_GREEN 00FF00
  4. RGB_RED FF0000
  5. RGB_CYAN 00FFFF
  6. RGB_MAGENTA FF00FF
  7. RGB_YELLOW FFFF
  8. RGB_ORANGE FF8000
  9. RGB_BROWN 804000
