PANELTHRESH: testing for threshold with panel model
Postby tavera » Wed Feb 03, 2010 9:00 am
I would like to test for threshold effects and estimate the threshold in a non dynamic panel as decribed in "Threshold effects in non dynamic panels: estimation, testing and inference" by Bruce Hansen, Journal of Econometrics, 93 (1999) p. 345-368. It seems to me that the procedure threshtest.src cannot be used in the case of a panel. Is there another procedure that permits to perform the adequate test ? Or, is it possible to use the threshtest.src by changing some codes ?
Thanks in advance
tavera
Re: testing for threshold with panel model
Postby TomDoan » Wed Feb 03, 2010 6:18 pm
Actually, you can't use THRESHTEST for several reasons: first, it is testing for a complete sample split, while the Hansen 1999 paper is using a set of non-breaking variables as well. Also, THRESHTEST doesn't allow for fixed effects.
The following does the estimation of the one and two threshold models from the Hansen paper (without the bootstrapping for the F-tests). This is actually a correction to Hansen's Gauss and Matlab code which have a slight error. (They drop the final data point in each cross section).
panelthresh.prg
(2.68 KiB) Downloaded 515 times
invest.txt
(579.34 KiB) Downloaded 659 times
Postby tavera » Thu Feb 04, 2010 11:01 am
Than you very much for this efficient and helpful response
tavera
Return to Panel Data
Who is online
