Dueker (1997) + TVTP
PostPosted: Mon Dec 10, 2012 4:30 am
by g_defi
I am trying to extend the MS-GARCH-NF Dueker (1997) to allow time varying transition probabilities.
Unfortunately, I failed to modify correctly the following function:
* This does a single step of the Dueker (approximate) filter
function DuekerFilter time
type integer       time
local real          e
local vector      fvec evec hvec ph
dim fvec(nexpand) evec(nstates)
* Compute the "H" matrices for each expanded regime
compute hvec=GARCHRegimeH(time)
* Compute the residuals for each current regime
compute evec=GARCHRegimeResids(time)
* Compute the likelihood for each expanded regime.
do i=1,nexpand
   compute e=evec(%MSLagState(i,1))
   compute fvec(i)=%if(hvec(i)>0,exp(%logtdensity(hvec(i)*gv(%MSLagState(i,0)),e,nu)),0.0)
* Do a filter step to update the probabilities. The log likelihood
* element is returned in the LOGF option.
@MSFilterStep(logf=DuekerFilter) time fvec
* Take probability weighted averages of the h's for each regime.
compute ph=pt_t(time).*hvec
compute pdiv  =%sumc(%reshape(pt_t(time),nstates,DFFilterSize))
compute phstar=%sumc(%reshape(ph,nstates,DFFilterSize))./pdiv
* Push them out into the HS vector
compute %pt(hs,t,phstar)
compute %pt(uus,t,evec.^2)
compute %pt(us,t,evec)
Thank you for any help offered.
