3-state Dueker(1997) MS-GARCH
nikosant
Unread post by nikosant »
I am trying to extend the 2-state model of Dueker(1997), "Markov Switching in GARCH Processes and Mean-Reverting Stock-Market Volatility," J of Business & Economic Statistics, vol. 15, no 1, 26-34, specifically the "dueker_swgarch_nf.rpf" (GARCH model with switching variance) code given below to 3-state:
* Replication file for Dueker(1997),  "Markov Switching in GARCH
* Processes and Mean-Reverting Stock-Market Volatility," J of Business &
* Economic Statistics, vol. 15, no 1, 26-34.
* Data set is a reconstruction.
* SW-GARCH-NF model with switching normalization factors and means with
* conditionally t distributed errors.
open data sp500.xls
data(format=xls,org=columns,top=17,left=2,nolabels) 1 2529 spchange
* Copy the data over to y to make it easier to change the program.
set y = spchange
* This sets the number of regimes. The analysis requires one lagged
* regime.
@MSSetup(states=2,lags=1)
* GV will be the relative variances in the regimes.
dec vect gv(nstates)
* This will be the vector of GARCH parameters. The constant in the GARCH
* equation is fixed at 1 as the normalization.
dec vect msg(2)
dec real nu
* We have three parts of the parameter set: the mean equation parameters
* (separate mu's for each regime), the GARCH model parameters, and the
* Markov switching parameters.
dec vect mu(nstates)
nonlin(parmset=meanparms)  mu
nonlin(parmset=garchparms) msg gv nu
nonlin(parmset=msparms)    p
* uu and u are used for the series of squared residuals and the series of
* residuals needed to compute the GARCH variances.
clear uu u h
* These are used for the lagged variance for each regime.
compute DFFilterSize=nstates^nlags
dec vect[series] hs(DFFilterSize)
* These for the lagged residuals and lagged squared residuals, which are
* regime-dependent because of the regime-dependent means.
dec vect[series] uus(nstates) us(nstates)
* GARCHRegimeH returns the VECTOR of the H values across augmented
* regime settings.
function GARCHRegimeH time
type vector GARCHRegimeH
type integer time
local integer i
dim GARCHRegimeH(nexpand)
do i=1,nexpand
   compute GARCHRegimeH(i)=1.0+msg(2)*hs(%MSLagState(i,1))(time-1)+$
       msg(1)*uus(%MSLagState(i,1))(time-1)/gv(%MSLagState(i,1))
function GARCHRegimeResids time
type vector 	GARCHRegimeResids
type integer	time
* Compute the residuals for each current regime
local integer i
dim GARCHRegimeResids(nstates)
do i=1,nstates
   compute GARCHRegimeResids(i)=y(time)-mu(i)
* Do a GARCH model to get initial guess values and matrices for random
* walk M-H.
linreg y
# constant y{1}
set u  = %resids
set uu = %sigmasq
do i=1,nstates
   set uus(i) = %sigmasq
   set us(i)  = %resids
* We'll start this at entry 2 to match the MS model
garch(p=1,q=1,distrib=t) 2 * y
ewise mu(i)=%beta(1)
compute msg=%xsubvec(%beta,3,4)
compute nu=%beta(5)
* The "H" series used in the Hamilton-Susmel formulation need scaling by
* the normalization factor to become variances. So we scale the
* pre-sample values down to match.
set h  = %sigmasq/%beta(2)
do i=1,nstates
   set hs(i) = %sigmasq/%beta(2)
* Start with guess values for GV that scale the original constant down
* and up.
compute gv(1)=%beta(3)/2.0
compute gv(2)=%beta(3)*2.0
compute p=||.9,.1||
* This does a single step of the Dueker (approximate) filter
function DuekerFilter time
type integer 		time
local real       	e
local vector      fvec evec hvec ph
dim fvec(nexpand) evec(nstates)
* Compute the "H" matrices for each expanded regime
compute hvec=GARCHRegimeH(time)
compute evec=GARCHRegimeResids(time)
* Compute the likelihood for each expanded regime.
do i=1,nexpand
   compute e=evec(MSLagState(i,1))
   compute fvec(i)=%if(hvec(i)>0,exp(%logtdensity(hvec(i)*gv(%MSLagState(i,0)),e,nu)),0.0)
* Do a filter step to update the probabilities. The log likelihood
* element is returned in the LOGF option.
@MSFilterStep(logf=DuekerFilter) time fvec
* Take probability weighted averages of the h's for each regime.
compute ph=pt_t(time).*hvec
compute pdiv  =%sumc(%reshape(pt_t(time),nstates,DFFilterSize))
compute phstar=%sumc(%reshape(ph,nstates,DFFilterSize))./pdiv
* Push them out into the HS vector
compute %pt(hs,t,phstar)
compute %pt(uus,t,evec.^2)
compute %pt(us,t,evec)
function DFStart
@MSFilterInit
frml LogDFFilter = DuekerFilter(t)
@MSFilterSetup(noem)
maximize(start=DFStart(),parmset=meanparms+garchparms+msparms,$
  pmethod=simplex,piters=5,method=bfgs) logDFFilter gstart gend
@MSSmoothed gstart gend psmooth
set p1 = psmooth(t)(1)
set p2 = psmooth(t)(2)
graph(max=1.0,footer="Probabilities of Regimes in Two-Regime GARCH-NF model",$
  style=stacked) 2
# p1
# p2
* Same model with means not switching
nonlin(parmset=nomeans) mu(2)=mu(1)
compute p=||.8,.2||
maximize(start=DFStart(),parmset=meanparms+garchparms+msparms+nomeans,$
graph(max=1.0,footer="Probabilities of Regimes in Two-Regime GARCH-NF model with fixed means",$
  style=stacked) 2
# p1
# p2
I would like to ask your help on which parameters in the above code need to be changed in order to estimate a 3-regime instead of a 2-regime.
Thank you very much in advance.
Best regards,
Nik
Re: 3-state Dueker(1997) MS-GARCH
Obvious change to:
This needs to initialize gv for 1 to 3. Probably want to spread those out more. Maybe /4, *1 and *4 in order.
Change this to give the top two rows of a 3 x 3 matrix of transitions.
compute p=||.9,.1||
The graphics are fairly specific to two states.
nikosant
Many thanks for your prompt response.
I changed the code according to your suggestions to the following:
open data sp500.xls
set y = spchange
* regime.
@MSSetup(states=3,lags=1)
dec vect msg(2)
dec real nu
clear uu u h
* regime settings.
type integer time
local integer i
do i=1,nexpand
type integer	time
local integer i
do i=1,nstates
* walk M-H.
linreg y
# constant y{1}
set u  = %resids
set uu = %sigmasq
do i=1,nstates
   set us(i)  = %resids
compute nu=%beta(5)
do i=1,nstates
* and up.
compute gv(1)=%beta(3)/4.0
compute gv(2)=%beta(3)*1.0
compute gv(3)=%beta(3)*4.0
compute p=|| .4,.2,.1 | .1,.2,.4 ||
type integer 		time
local real       	e
do i=1,nexpand
   compute e=evec(%MSLagState(i,1))
function DFStart
@MSFilterInit
set p3 = psmooth(t)(3)
  style=stacked) 3
# p1
# p2
# p3
which runs perfectly fine but the results are dubious. Specifically, using the data provided here:
http://www.estima.com/forum/viewtopic.php?f=8&t=1190
I get the following results:
1.  MU(1)                         0.042105278  0.081061000      0.51943  0.60346295
2.  MU(2)                         0.068270121  0.048009604      1.42201  0.15502345
3.  MU(3)                         0.056200900  0.033263509      1.68957  0.09111098
4.  MSG(1)                       0.041850534  0.002716916    15.40369  0.00000000
5.  MSG(2)                       0.893396446  0.003275907   272.71724 0.00000000
6.  GV(1)                         0.023086475  0.005840585      3.95277  0.00007725
7.  GV(2)                         0.083183166  0.010420948      7.98230  0.00000000
8.  GV(3)                         0.047956776  0.004598765     10.42819  0.00000000
9.  NU                             6.419945642  0.564231852     11.37820  0.00000000
10. P(1,1)                       -0.000010000  0.003678399     -0.00272  0.99783089
11. P(2,1)                        0.017597064  0.418682882      0.04203  0.96647512
12. P(1,2)                        0.288007594  0.137790592      2.09018  0.03660134
13. P(2,2)                        0.002260262  0.235553809      0.00960  0.99234400
14. P(1,3)                        0.089021276  0.090389649      0.98486  0.32469216
15. P(2,3)                        0.339809062  0.180221421      1.88551  0.05936119
Are the values that I used above, which I also indicate below, for the top two rows of the 3 x 3 matrix of transitions reasonable?:
And/or do I need to amend something else in addition to the above code?
Again, many thanks for your support. Your help is highly appreciated!
Nik
Do you have any strong reason to believe that three states are necessary? If two are adequate, then (effectively all) the parameters in three aren't identified. The only ones that would be identified are the two GARCH lag parameters, which look fine.
The one obvious problem is your initial P's.
That has very low persistence for the regimes - your probability of 1-->3 is higher than 1-->1. Something more like
compute p=|| .8,.2,.1 | .1,.6,.1 ||
would be more reasonable. It could be that those guess values are forcing the earlier iterations to scramble the regimes.
If that doesn't fix it, I assume that you've successfully estimated a two-regime model. Take the GV's that you get off of that, figure out a reasonable set of 3 values in a similar scale to those and try re-estimating the model with those out of the parameter set. You'll at least be able to see whether you can get the transition probabilities to converge.
nikosant
Many thanks for your response.
After many trials, according to your suggestions, the problem seems to be resolved.
Thanks again.
Nik
