Page 3 of 3
Re: TVTP Markov Regime switching model
Posted:
Thu Apr 19, 2012 4:06 pm
by moderator
I'd suggest that you email the code and data set to us at
support@estima.comThat will be easier than trying to cut and paste code out of the forum post.
Please include your full name and RATS serial number in the email.
Tom Maycock
Estima
Posted:
Wed May 02, 2012 10:56 am
This will estimate the model using logistic index transitions using EM with a BHHH polishing.
- Code: Select all
cal(d) 2006:03:24
open data "one_sample_ap.xls"
data(format=xls,org=cols) 2006:03:24 2012:03:05 apexcess aprm aprmsq logvix
sample(smpl=%valid(apexcess)) apexcess / apexcess_nomissing
sample(smpl=%valid(aprm)) aprm / aprm_nomissing
sample(smpl=%valid(aprmsq)) aprmsq / aprmsq_nomissing
sample(smpl=%valid(logvix)) logvix / logvix_nomissing
calendar(irregular)
compute gstart=1,gend=%nobs
@msregression(states=2,switch=ch) apexcess_nomissing
# constant aprm_nomissing aprmsq_nomissing
@msreginitial gstart gend
@MSFilterSetup(em)
nonlin(parmset=common) betas sigsqv
dec equation p1eq p2eq
dec vector v1 v2
dec vector p1mean p2mean
nonlin(parmset=tv) v1 v2
* Define the logistic index for the transitions
equation p1eq *
# constant
equation p2eq *
# constant
dim p1mean(1) p2mean(1)
compute p1mean(1)=1.0,p2mean(1)=1.0
* Function to compute the transition probability matrix
function %MSPmat time
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
compute %MSInitTransition()
if nexpand==nstates {
compute %MSPmat=pexpand*p
ewise %MSPmat(i,j)=%if(i==nstates,1.0+%MSPmat(i,j),%MSPmat(i,j))
else {
dim %MSPmat(nexpand,nexpand)
ewise %MSPmat(i,j)=MSTransProbs(MSTransLookup(i,j))
* Initialize the probabilities using only the means
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
compute p(1,1)=%(z=exp(%dot(p1mean,v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(p2mean,v2)),1/(1+z))
compute TVPInit=%MSInit()
compute p=%MSPExpand(p)
procedure MSTVPEMEstimate start end
type integer start end
option integer iters 100
option real cvcrit 1.e-6
local integer emits time k
local series l11 l22 w11 w22
local vector baseparms testparms
local rect thisEntry
dim thisEntry(nstates,nstates)
compute baseparms=v1~~v2
do emits=1,iters
compute %eqnsetcoeffs(p1eq,v1)
compute %eqnsetcoeffs(p2eq,v2)
compute TVPInit()
@MSRegestep start end
compute %emlogl=%logl
@MSRegmstep(nodop,nodobeta,dosigma) start end
set l11 start end = 0.0
set l22 start end = 0.0
set w11 start end = 0.0
set w22 start end = 0.0
compute tvemlogl=0.0
do time=start,end
compute p=%MSPMat(time)
compute thisEntry=%zeros(nstates,nstates)
do k=1,MSEMSize
compute thisEntry(MSEMLagRegime(k,1),MSEMLagRegime(k,2))+=MSEMpt_sm(time)(k)
compute tvemlogl+=log(p(MSEMLagRegime(k,1),MSEMLagRegime(k,2)))*MSEMpt_sm(time)(k)
end do k
compute w11(time)=p(1,1)*(1-p(1,1))*(thisEntry(1,1)+thisEntry(2,1))
compute w22(time)=p(1,2)*(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2))
compute l11(time)=(thisEntry(1,1)- p(1,1)*(thisEntry(1,1)+thisEntry(2,1)))/w11(time)
compute l22(time)=(thisEntry(2,2)-(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2)))/w22(time)
end do time
* Update the coefficients
linreg(noprint,weight=w11,equation=p1eq) l11 start end
compute v1=v1+%beta
linreg(noprint,weight=w22,equation=p2eq) l22 start end
compute v2=v2+%beta
do time=start,end
do k=1,MSEMSize
end do k
end do time
* Check for convergence
compute testparms=v1~~v2
compute %cvcrit=%testdiff(baseparms,testparms)
if %cvcrit<cvcrit
break
compute baseparms=testparms
disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSTVPEMEstimate
compute v1=log(.7/.3)
compute v2=log(.95/.05)
@MSTVPEMEstimate(cvcrit=.0001) gstart gend
equation p1eq *
# constant logvix{1}
equation p2eq *
dim p1mean(%eqnsize(p1eq)) p2mean(%eqnsize(p2eq))
do i=1,%eqnsize(p1eq)
sstats(mean) gstart gend %eqnxvector(p1eq,t)(i)>>p1mean(i)
do i=1,%eqnsize(p2eq)
sstats(mean) gstart gend %eqnxvector(p2eq,t)(i)>>p2mean(i)
compute v1=v1~~0.0
compute v2=v2~~0.0
@MSTVPEMEstimate(cvcrit=.0001,iters=50) gstart gend
* Polish estimates using BHHH
frml logltvtp = p=%MSPMat(t),log(%MSRegProb(t))
@MSFilterInit
maximize(parmset=tv+common,start=(pstar=TVPInit()),method=bhhh,iters=10) logltvtp gstart gend
Posted:
Wed May 02, 2012 3:11 pm
by superper2008
Dear Tom:
Appreciate you very much for your help.
Sincerely,
Feiyu
Posted:
Fri May 25, 2012 4:07 pm
by superper2008
Hello Tom:
Now I have got all the results by means of the code you help me figure out. Thanks again. However, when I am analyzing the model, I still need to know which state of two states in my model is recession or expansion period. In the code, you use p(1.1) and p(1.2), I am not sure if I can modify into p(1.1) and p(2,2) to identify which state is recession or expansion period. If I only get the result shown below, I can't determine the recession or expansion according to the signs of V1(1), V2(1) and V1(2), V2(2). If I can write the code P(1,1) and P(2.2), then I can identify the recession or expansion period according to the signs of them.
Sincerely,
Feiyu
MAXIMIZE - Estimation by BHHH
Convergence in 29 Iterations. Final criterion was 0.0000081 <= 0.0000100
Usable Observations 1493
Function Value 4818.4560
1. V1(1) 33.09651919 7.41884567 4.46114 0.00000815
2. V1(2) -20.10919941 5.01057196 -4.01335 0.00005986
3. V2(1) 9.48357495 4.25329673 2.22970 0.02576738
4. V2(2) -4.71040158 2.78992367 -1.68836 0.09134173
5. BETAS(1)(1) 0.00022131 0.00024208 0.91420 0.36061336
6. BETAS(1)(2) 0.96252328 0.00499307 192.77178 0.00000000
7. BETAS(1)(3) -0.08981680 0.02266712 -3.96243 0.00007419
8. BETAS(2)(1) 0.00146803 0.00175547 0.83626 0.40301048
9. BETAS(2)(2) 0.98587491 0.01025490 96.13696 0.00000000
10. BETAS(2)(3) -0.04525605 0.02520002 -1.79587 0.07251454
11. SIGSQV(1) 0.00006727 0.00000265 25.37280 0.00000000
12. SIGSQV(2) 0.00041067 0.00004017 10.22425 0.00000000
Posted:
Fri May 25, 2012 4:32 pm
by superper2008
Hello Tom:
I have solved the problem. I made one mistake previously.
Feiyu
Posted:
Fri May 25, 2012 4:41 pm
In more complicated models, you may not be able to define the regimes with simple labels like "recession" and "expansion". In the case of Hamilton's original model, the only thing that switched was the process mean for the growth rate---no matter what, one would be bigger than the other, so you could distinguish higher growth from lower growth. Instead, you have a 3 coefficient linear regression and variances which switch, so there is not necessarily any simple ordering for the two. If you're fortunate, you'll get readily identifiable regimes, but you can't count on it. (Krolzig's VAR's often have two or more local modes which are quite different in properties, but have almost identical log likelihoods).
Posted:
Tue May 29, 2012 9:25 am
by superper2008
Hello Tom;
Appreciate very much for your help.
Sincerely,
Feiyu
