RATS output and LaTeX
PostPosted: Fri Sep 18, 2009 1:54 pm
by Anna
I did not find an appropriate thread so I post this here. Sorry if this is misplaced.
I know that other software (e.g. Stata) have packages enabling the user to "translate" regression output into LaTeX tables. Is there any equivalent package for RATS? If not, did you ever think of inventing such a module? It might be very useful since many economists use RATS and they normally write documents with LaTeX.
Re: RATS output and LaTeX
PostPosted: Mon Oct 12, 2009 5:13 am
by jonasdovern
Hallo Anna,
I once wrote a little procedure that produces Latex-Code to display a data matrix as a Latex-Table. This is not able to display regression output as you asked for. But it might be a starting point for you - or others - to write your own procedure. Best, Jonas
procedure textable datamat
type rec[real]      datamat
option vec[str]   rowlabels
option vec[str]   collabels
option string      header
option choice      hposition 1 above below
option string      texlabel 'tRATStable'
option string      format '*.##'
option rec[real]   tstat
option switch      lines 0
option choice      position 1 none here top bottom
option switch      stars 0
local integer      nrows ncols c r
local string      coldesign temp pos starstring
* Check inputs
if (%defined(collabels).and..not.%defined(rowlabels)).or.(%defined(rowlabels).and..not.%defined(collabels)) {
   disp 'Please define either labels for rows AND columns or do not specify any labels at all!'
   return
if (%defined(collabels)).and.((%rows(collabels)<>%cols(datamat)).or.(%rows(rowlabels)<>%rows(datamat))) {
   disp 'The dimension of at least one of your vectors with labels does not match the dimension of your data matrix!'
   return
if %defined(tstat).and.(%rows(tstat)<>%rows(datamat).or.%cols(tstat)<>%cols(datamat)) {
   disp 'Data matrix and matrix with t-statistics do not have the same dimension!'
   return
* Get relevant information and construct help-objects
comp nrows = %rows(datamat), ncols = %cols(datamat)
if %defined(rowlabels) {
   if lines
      comp coldesign = 'l|'+%strrep('c',ncols)
   else
      comp coldesign = 'l'+%strrep('c',ncols)
else
   comp coldesign = %strrep('c',ncols)
if position==1
   comp pos = ''
if position==2
   comp pos ='[!h]'
if position==3
   comp pos ='[!t]'
if position==4
   comp pos ='[!b]'
* Write TeX-Code to a separate window
open(window) codewin 'Code for TeX-Table'
change output codewin
disp    '\begin{table}'+pos
if hposition==1 {
   if %defined(header)
      disp   @@3 '\caption{'+header+'}'
disp      @@3 '\label{'+texlabel+'}'
disp       @@3 '\centering'
disp      @@3 '\begin{tabular}{'+coldesign+'}'
disp      @@6 '\hline'
disp      @@6 '\hline'
if %defined(collabels) {
   comp temp = ' '
   do c=1,ncols
      comp temp = temp+' & '+collabels(c)
   end do c
   comp temp = temp+' \\'
   disp    @@6 temp
if lines
   disp @@6 '\hline'
do r=1,nrows
   * Data rows
      comp temp = rowlabels(r)+' & '
   else
      comp temp = ''
   do c=1,ncols-1
      comp temp = temp+%strval(datamat(r,c),format)+' & '
   end do c
   comp temp = temp+%strval(datamat(r,ncols),format)+' \\'
   disp   @@6 temp
   * t-statistics
   if %defined(tstat) {
         comp temp = 't-stat & '
      else
         comp temp = ''
      do c=1,ncols-1
         if .not.stars
            comp temp = temp+'('+%strval(tstat(r,c),'*.#')+') & '
         else {
            if abs(tstat(r,c))<1.65
               comp starstring = ''
            else if abs(tstat(r,c))<1.96
               comp starstring = '*'
            else if abs(tstat(r,c))<2.58
               comp starstring = '**'
            else
               comp starstring = '***'
            comp temp = temp+'($'+%strval(tstat(r,c),'*.#')+'^{'+starstring+'}$) & '
      end do c
      if .not.stars
         comp temp = temp+'('+%strval(tstat(r,ncols),'*.#')+') \\'
      else {
         if abs(tstat(r,ncols))<1.65
         else if abs(tstat(r,ncols))<1.96
         else if abs(tstat(r,ncols))<2.58
         else
         comp temp = temp+'($'+%strval(tstat(r,ncols),'*.#')+'^{'+starstring+'}$) \\'
      disp   @@6 temp
end do r
disp      @@6 '\hline'
disp      @@6 '\hline'
disp      @@3 '\end{tabular}'
if hposition==2 {
   if %defined(header)
disp   '\end{table}'
change output screen
end procedure
PostPosted: Thu Feb 04, 2010 11:39 am
by moderator
With version 7.3, RATS now supports exporting the contents of any "report" window in TeX format.
For example, you can use the WINDOW option on instructions like FORECAST, PRINT, REPORT, STATISTICS, etc., to display the output to a report window. You can then use File-Export... to export the information to a file in a variety of formats, with TeX now being among the supported formats.
PostPosted: Thu Jan 20, 2011 2:00 pm
moderator wrote:With version 7.3, RATS now supports exporting the contents of any "report" window in TeX format.
This has been further enhanced with version 8. For one thing, there's now a Copy-->TeX on the Edit menu (and a corresponding toolbar icon) which copies a TeX tabular environment to the clipboard. This makes it quite a bit easier to get the information into a TeX editor since the "Paste" operation in the editor will usually grab the standard delimited text copy in the clipboard. By copying only the Tex version out of RATS, you get the proper behavior. This is what you get by copying the regression table produced out of the adaptive.prg (now adaptive.rpf) example file.
\newcolumntype{.}{D{.}{.}{-1}}
\begin{tabular}{. . . . . . }
\multicolumn{1}{c}{} & \multicolumn{1}{l}{Variable} & \multicolumn{1}{c}{Coeff} & \multicolumn{1}{c}{Std Error} & \multicolumn{1}{c}{ T-Stat} & \multicolumn{1}{c}{Signif}\\
\multicolumn{1}{l}{1.} & \multicolumn{1}{l}{SQFT} & \multicolumn{1}{r}{    0.242854} & \multicolumn{1}{r}{    0.077900} & \multicolumn{1}{r}{     3.11750} & \multicolumn{1}{r}{0.00182390}\\
\multicolumn{1}{l}{2.} & \multicolumn{1}{l}{YARD} & \multicolumn{1}{r}{    0.007773} & \multicolumn{1}{r}{    0.002060} & \multicolumn{1}{r}{     3.77285} & \multicolumn{1}{r}{0.00016139}\\
\multicolumn{1}{l}{3.} & \multicolumn{1}{l}{POOL} & \multicolumn{1}{r}{   31.014472} & \multicolumn{1}{r}{   17.314004} & \multicolumn{1}{r}{     1.79129} & \multicolumn{1}{r}{0.07324611}\\
\multicolumn{1}{l}{4.} & \multicolumn{1}{l}{LAJOLLA} & \multicolumn{1}{r}{  102.256649} & \multicolumn{1}{r}{   15.846660} & \multicolumn{1}{r}{     6.45288} & \multicolumn{1}{r}{0.00000000}\\
\multicolumn{1}{l}{5.} & \multicolumn{1}{l}{BATHS} & \multicolumn{1}{r}{   25.893292} & \multicolumn{1}{r}{   22.196190} & \multicolumn{1}{r}{     1.16656} & \multicolumn{1}{r}{0.24338619}\\
\multicolumn{1}{l}{6.} & \multicolumn{1}{l}{FIREPL} & \multicolumn{1}{r}{   28.777792} & \multicolumn{1}{r}{   18.100197} & \multicolumn{1}{r}{     1.58992} & \multicolumn{1}{r}{0.11185376}\\
\multicolumn{1}{l}{7.} & \multicolumn{1}{l}{IRREG} & \multicolumn{1}{r}{   45.311789} & \multicolumn{1}{r}{   20.222589} & \multicolumn{1}{r}{     2.24065} & \multicolumn{1}{r}{0.02504861}\\
\multicolumn{1}{l}{8.} & \multicolumn{1}{l}{SPRINK} & \multicolumn{1}{r}{   48.618835} & \multicolumn{1}{r}{   14.870864} & \multicolumn{1}{r}{     3.26940} & \multicolumn{1}{r}{0.00107775}\\
\multicolumn{1}{l}{9.} & \multicolumn{1}{l}{VIEW} & \multicolumn{1}{r}{   28.937609} & \multicolumn{1}{r}{   15.991109} & \multicolumn{1}{r}{     1.80961} & \multicolumn{1}{r}{0.07035688}\\
\multicolumn{1}{l}{10.} & \multicolumn{1}{l}{LSQFT} & \multicolumn{1}{r}{ -964.002131} & \multicolumn{1}{r}{  394.273886} & \multicolumn{1}{r}{    -2.44501} & \multicolumn{1}{r}{0.01448496}\\
\multicolumn{1}{l}{11.} & \multicolumn{1}{l}{LYARD} & \multicolumn{1}{r}{  -95.490573} & \multicolumn{1}{r}{   47.917554} & \multicolumn{1}{r}{    -1.99281} & \multicolumn{1}{r}{0.04628227}\\
\multicolumn{1}{l}{12.} & \multicolumn{1}{l}{Constant} & \multicolumn{1}{r}{ 2997.279347} & \multicolumn{1}{r}{ 1168.200087} & \multicolumn{1}{r}{     2.56572} & \multicolumn{1}{r}{0.01029606}\\
\end{tabular}
If that's showing too many decimals, you can use the Edit-Change Layout operation first before doing the copy to TeX. This reduces it to three decimals.
\multicolumn{1}{l}{1.} & \multicolumn{1}{l}{SQFT} & \multicolumn{1}{r}{       0.243} & \multicolumn{1}{r}{       0.078} & \multicolumn{1}{r}{       3.118} & \multicolumn{1}{r}{       0.002}\\
\multicolumn{1}{l}{2.} & \multicolumn{1}{l}{YARD} & \multicolumn{1}{r}{       0.008} & \multicolumn{1}{r}{       0.002} & \multicolumn{1}{r}{       3.773} & \multicolumn{1}{r}{       0.000}\\
\multicolumn{1}{l}{3.} & \multicolumn{1}{l}{POOL} & \multicolumn{1}{r}{      31.014} & \multicolumn{1}{r}{      17.314} & \multicolumn{1}{r}{       1.791} & \multicolumn{1}{r}{       0.073}\\
\multicolumn{1}{l}{4.} & \multicolumn{1}{l}{LAJOLLA} & \multicolumn{1}{r}{     102.257} & \multicolumn{1}{r}{      15.847} & \multicolumn{1}{r}{       6.453} & \multicolumn{1}{r}{       0.000}\\
\multicolumn{1}{l}{5.} & \multicolumn{1}{l}{BATHS} & \multicolumn{1}{r}{      25.893} & \multicolumn{1}{r}{      22.196} & \multicolumn{1}{r}{       1.167} & \multicolumn{1}{r}{       0.243}\\
\multicolumn{1}{l}{6.} & \multicolumn{1}{l}{FIREPL} & \multicolumn{1}{r}{      28.778} & \multicolumn{1}{r}{      18.100} & \multicolumn{1}{r}{       1.590} & \multicolumn{1}{r}{       0.112}\\
\multicolumn{1}{l}{7.} & \multicolumn{1}{l}{IRREG} & \multicolumn{1}{r}{      45.312} & \multicolumn{1}{r}{      20.223} & \multicolumn{1}{r}{       2.241} & \multicolumn{1}{r}{       0.025}\\
\multicolumn{1}{l}{8.} & \multicolumn{1}{l}{SPRINK} & \multicolumn{1}{r}{      48.619} & \multicolumn{1}{r}{      14.871} & \multicolumn{1}{r}{       3.269} & \multicolumn{1}{r}{       0.001}\\
\multicolumn{1}{l}{9.} & \multicolumn{1}{l}{VIEW} & \multicolumn{1}{r}{      28.938} & \multicolumn{1}{r}{      15.991} & \multicolumn{1}{r}{       1.810} & \multicolumn{1}{r}{       0.070}\\
\multicolumn{1}{l}{10.} & \multicolumn{1}{l}{LSQFT} & \multicolumn{1}{r}{    -964.002} & \multicolumn{1}{r}{     394.274} & \multicolumn{1}{r}{      -2.445} & \multicolumn{1}{r}{       0.014}\\
\multicolumn{1}{l}{11.} & \multicolumn{1}{l}{LYARD} & \multicolumn{1}{r}{     -95.491} & \multicolumn{1}{r}{      47.918} & \multicolumn{1}{r}{      -1.993} & \multicolumn{1}{r}{       0.046}\\
\multicolumn{1}{l}{12.} & \multicolumn{1}{l}{Constant} & \multicolumn{1}{r}{    2997.279} & \multicolumn{1}{r}{    1168.200} & \multicolumn{1}{r}{       2.566} & \multicolumn{1}{r}{       0.010}\\
\end{tabular}
