RATS output and LaTeX
Anna
Unread post by Anna »
I did not find an appropriate thread so I post this here. Sorry if this is misplaced.
I know that other software (e.g. Stata) have packages enabling the user to "translate" regression output into LaTeX tables. Is there any equivalent package for RATS? If not, did you ever think of inventing such a module? It might be very useful since many economists use RATS and they normally write documents with LaTeX.
jonasdovern
Re: RATS output and LaTeX
Unread post by jonasdovern »
Hallo Anna,
I once wrote a little procedure that produces Latex-Code to display a data matrix as a Latex-Table. This is not able to display regression output as you asked for. But it might be a starting point for you - or others - to write your own procedure. Best, Jonas
procedure textable datamat
type rec[real]		datamat
option vec[str]	rowlabels
option vec[str]	collabels
option string		header
option choice		hposition 1 above below
option string		texlabel 'tRATStable'
option string		format '*.##'
option rec[real]	tstat
option switch		lines 0
option choice		position 1 none here top bottom
option switch		stars 0
local integer		nrows ncols c r
local string		coldesign temp pos starstring
* Check inputs
if (%defined(collabels).and..not.%defined(rowlabels)).or.(%defined(rowlabels).and..not.%defined(collabels)) {
	disp 'Please define either labels for rows AND columns or do not specify any labels at all!'
	return
if (%defined(collabels)).and.((%rows(collabels)<>%cols(datamat)).or.(%rows(rowlabels)<>%rows(datamat))) {
	disp 'The dimension of at least one of your vectors with labels does not match the dimension of your data matrix!'
	return
if %defined(tstat).and.(%rows(tstat)<>%rows(datamat).or.%cols(tstat)<>%cols(datamat)) {
	disp 'Data matrix and matrix with t-statistics do not have the same dimension!'
	return
* Get relevant information and construct help-objects
comp nrows = %rows(datamat), ncols = %cols(datamat)
if %defined(rowlabels) {
	if lines
		comp coldesign = 'l|'+%strrep('c',ncols)
	else
		comp coldesign = 'l'+%strrep('c',ncols)
else
	comp coldesign = %strrep('c',ncols)
if position==1
	comp pos = ''
if position==2
	comp pos ='[!h]'
if position==3
	comp pos ='[!t]'
if position==4
	comp pos ='[!b]'
* Write TeX-Code to a separate window
open(window) codewin 'Code for TeX-Table'
change output codewin
disp 	'\begin{table}'+pos
if hposition==1 {
	if %defined(header)
		disp	@@3 '\caption{'+header+'}'
disp		@@3 '\label{'+texlabel+'}'
disp 		@@3 '\centering'
disp		@@3 '\begin{tabular}{'+coldesign+'}'
disp		@@6 '\hline'
disp		@@6 '\hline'
if %defined(collabels) {
	comp temp = ' '
	do c=1,ncols
		comp temp = temp+' & '+collabels(c)
	end do c
	comp temp = temp+' \\'
	disp 	@@6 temp
if lines
	disp @@6 '\hline'
do r=1,nrows
	* Data rows
		comp temp = rowlabels(r)+' & '
	else
		comp temp = ''
	do c=1,ncols-1
		comp temp = temp+%strval(datamat(r,c),format)+' & '
	end do c
	comp temp = temp+%strval(datamat(r,ncols),format)+' \\'
	disp	@@6 temp
	* t-statistics
	if %defined(tstat) {
			comp temp = 't-stat & '
		else
			comp temp = ''
		do c=1,ncols-1
			if .not.stars
				comp temp = temp+'('+%strval(tstat(r,c),'*.#')+') & '
			else {
				if abs(tstat(r,c))<1.65
					comp starstring = ''
				else if abs(tstat(r,c))<1.96
					comp starstring = '*'
				else if abs(tstat(r,c))<2.58
					comp starstring = '**'
				else
					comp starstring = '***'
				comp temp = temp+'($'+%strval(tstat(r,c),'*.#')+'^{'+starstring+'}$) & '
		end do c
		if .not.stars
			comp temp = temp+'('+%strval(tstat(r,ncols),'*.#')+') \\'
		else {
			if abs(tstat(r,ncols))<1.65
			else if abs(tstat(r,ncols))<1.96
			else if abs(tstat(r,ncols))<2.58
			else
			comp temp = temp+'($'+%strval(tstat(r,ncols),'*.#')+'^{'+starstring+'}$) \\'
		disp	@@6 temp
end do r
disp		@@6 '\hline'
disp		@@6 '\hline'
disp		@@3 '\end{tabular}'
if hposition==2 {
	if %defined(header)
disp	'\end{table}'
change output screen
end procedure
Site Admin
Unread post by moderator »
With version 7.3, RATS now supports exporting the contents of any "report" window in TeX format.
For example, you can use the WINDOW option on instructions like FORECAST, PRINT, REPORT, STATISTICS, etc., to display the output to a report window. You can then use File-Export... to export the information to a file in a variety of formats, with TeX now being among the supported formats.
moderator wrote:With version 7.3, RATS now supports exporting the contents of any "report" window in TeX format.
This has been further enhanced with version 8. For one thing, there's now a Copy-->TeX on the Edit menu (and a corresponding toolbar icon) which copies a TeX tabular environment to the clipboard. This makes it quite a bit easier to get the information into a TeX editor since the "Paste" operation in the editor will usually grab the standard delimited text copy in the clipboard. By copying only the Tex version out of RATS, you get the proper behavior. This is what you get by copying the regression table produced out of the adaptive.prg (now adaptive.rpf) example file.
\newcolumntype{.}{D{.}{.}{-1}}
\begin{tabular}{. . . . . . }
\multicolumn{1}{c}{} & \multicolumn{1}{l}{Variable} & \multicolumn{1}{c}{Coeff} & \multicolumn{1}{c}{Std Error} & \multicolumn{1}{c}{ T-Stat} & \multicolumn{1}{c}{Signif}\\
\multicolumn{1}{l}{1.} & \multicolumn{1}{l}{SQFT} & \multicolumn{1}{r}{    0.242854} & \multicolumn{1}{r}{    0.077900} & \multicolumn{1}{r}{     3.11750} & \multicolumn{1}{r}{0.00182390}\\
\multicolumn{1}{l}{2.} & \multicolumn{1}{l}{YARD} & \multicolumn{1}{r}{    0.007773} & \multicolumn{1}{r}{    0.002060} & \multicolumn{1}{r}{     3.77285} & \multicolumn{1}{r}{0.00016139}\\
\multicolumn{1}{l}{3.} & \multicolumn{1}{l}{POOL} & \multicolumn{1}{r}{   31.014472} & \multicolumn{1}{r}{   17.314004} & \multicolumn{1}{r}{     1.79129} & \multicolumn{1}{r}{0.07324611}\\
\multicolumn{1}{l}{4.} & \multicolumn{1}{l}{LAJOLLA} & \multicolumn{1}{r}{  102.256649} & \multicolumn{1}{r}{   15.846660} & \multicolumn{1}{r}{     6.45288} & \multicolumn{1}{r}{0.00000000}\\
\multicolumn{1}{l}{5.} & \multicolumn{1}{l}{BATHS} & \multicolumn{1}{r}{   25.893292} & \multicolumn{1}{r}{   22.196190} & \multicolumn{1}{r}{     1.16656} & \multicolumn{1}{r}{0.24338619}\\
\multicolumn{1}{l}{6.} & \multicolumn{1}{l}{FIREPL} & \multicolumn{1}{r}{   28.777792} & \multicolumn{1}{r}{   18.100197} & \multicolumn{1}{r}{     1.58992} & \multicolumn{1}{r}{0.11185376}\\
\multicolumn{1}{l}{7.} & \multicolumn{1}{l}{IRREG} & \multicolumn{1}{r}{   45.311789} & \multicolumn{1}{r}{   20.222589} & \multicolumn{1}{r}{     2.24065} & \multicolumn{1}{r}{0.02504861}\\
\multicolumn{1}{l}{8.} & \multicolumn{1}{l}{SPRINK} & \multicolumn{1}{r}{   48.618835} & \multicolumn{1}{r}{   14.870864} & \multicolumn{1}{r}{     3.26940} & \multicolumn{1}{r}{0.00107775}\\
\multicolumn{1}{l}{9.} & \multicolumn{1}{l}{VIEW} & \multicolumn{1}{r}{   28.937609} & \multicolumn{1}{r}{   15.991109} & \multicolumn{1}{r}{     1.80961} & \multicolumn{1}{r}{0.07035688}\\
\multicolumn{1}{l}{10.} & \multicolumn{1}{l}{LSQFT} & \multicolumn{1}{r}{ -964.002131} & \multicolumn{1}{r}{  394.273886} & \multicolumn{1}{r}{    -2.44501} & \multicolumn{1}{r}{0.01448496}\\
\multicolumn{1}{l}{11.} & \multicolumn{1}{l}{LYARD} & \multicolumn{1}{r}{  -95.490573} & \multicolumn{1}{r}{   47.917554} & \multicolumn{1}{r}{    -1.99281} & \multicolumn{1}{r}{0.04628227}\\
\multicolumn{1}{l}{12.} & \multicolumn{1}{l}{Constant} & \multicolumn{1}{r}{ 2997.279347} & \multicolumn{1}{r}{ 1168.200087} & \multicolumn{1}{r}{     2.56572} & \multicolumn{1}{r}{0.01029606}\\
\end{tabular}
If that's showing too many decimals, you can use the Edit-Change Layout operation first before doing the copy to TeX. This reduces it to three decimals.
\multicolumn{1}{l}{1.} & \multicolumn{1}{l}{SQFT} & \multicolumn{1}{r}{       0.243} & \multicolumn{1}{r}{       0.078} & \multicolumn{1}{r}{       3.118} & \multicolumn{1}{r}{       0.002}\\
\multicolumn{1}{l}{2.} & \multicolumn{1}{l}{YARD} & \multicolumn{1}{r}{       0.008} & \multicolumn{1}{r}{       0.002} & \multicolumn{1}{r}{       3.773} & \multicolumn{1}{r}{       0.000}\\
\multicolumn{1}{l}{3.} & \multicolumn{1}{l}{POOL} & \multicolumn{1}{r}{      31.014} & \multicolumn{1}{r}{      17.314} & \multicolumn{1}{r}{       1.791} & \multicolumn{1}{r}{       0.073}\\
\multicolumn{1}{l}{4.} & \multicolumn{1}{l}{LAJOLLA} & \multicolumn{1}{r}{     102.257} & \multicolumn{1}{r}{      15.847} & \multicolumn{1}{r}{       6.453} & \multicolumn{1}{r}{       0.000}\\
\multicolumn{1}{l}{5.} & \multicolumn{1}{l}{BATHS} & \multicolumn{1}{r}{      25.893} & \multicolumn{1}{r}{      22.196} & \multicolumn{1}{r}{       1.167} & \multicolumn{1}{r}{       0.243}\\
\multicolumn{1}{l}{6.} & \multicolumn{1}{l}{FIREPL} & \multicolumn{1}{r}{      28.778} & \multicolumn{1}{r}{      18.100} & \multicolumn{1}{r}{       1.590} & \multicolumn{1}{r}{       0.112}\\
\multicolumn{1}{l}{7.} & \multicolumn{1}{l}{IRREG} & \multicolumn{1}{r}{      45.312} & \multicolumn{1}{r}{      20.223} & \multicolumn{1}{r}{       2.241} & \multicolumn{1}{r}{       0.025}\\
\multicolumn{1}{l}{8.} & \multicolumn{1}{l}{SPRINK} & \multicolumn{1}{r}{      48.619} & \multicolumn{1}{r}{      14.871} & \multicolumn{1}{r}{       3.269} & \multicolumn{1}{r}{       0.001}\\
\multicolumn{1}{l}{9.} & \multicolumn{1}{l}{VIEW} & \multicolumn{1}{r}{      28.938} & \multicolumn{1}{r}{      15.991} & \multicolumn{1}{r}{       1.810} & \multicolumn{1}{r}{       0.070}\\
\multicolumn{1}{l}{10.} & \multicolumn{1}{l}{LSQFT} & \multicolumn{1}{r}{    -964.002} & \multicolumn{1}{r}{     394.274} & \multicolumn{1}{r}{      -2.445} & \multicolumn{1}{r}{       0.014}\\
\multicolumn{1}{l}{11.} & \multicolumn{1}{l}{LYARD} & \multicolumn{1}{r}{     -95.491} & \multicolumn{1}{r}{      47.918} & \multicolumn{1}{r}{      -1.993} & \multicolumn{1}{r}{       0.046}\\
\multicolumn{1}{l}{12.} & \multicolumn{1}{l}{Constant} & \multicolumn{1}{r}{    2997.279} & \multicolumn{1}{r}{    1168.200} & \multicolumn{1}{r}{       2.566} & \multicolumn{1}{r}{       0.010}\\
\end{tabular}
