Puzzle for speculative bubbles using state space
xiangyu71
Unread post by xiangyu71 »
i'm try to code for speculative bubbles using state space, but i don't know how to organize the data and how to perform the program.
In model the state variable "dt" is observed and state variable "bt" is unobserved. the model is the attached paper
thanks in advanced!
best regards.
Re: Puzzle for speculative bubbles using state space
The A matrix is set up with:
dec frml[rect] af
frml af = ||phi1,phi2,phi3,0,0,0|$
1,0,0,0,0,0|$
0,1,0,0,0,0|$
0,0,1,0,0,0|$
0,0,0,0,1/psi,0|$
0,0,0,0,1,0||
The "F" matrix is the fixed matrix
dec rect f(6,2)
input f
1 0
0 0
0 0
0 0
0 1
0 0
The "C" matrix (which is the transpose of the matrix in 12.24 is represented with
dec frml cf
frml cf = ||(1+m1),1|$
m2-m1,0|$
m3-m2,0|$
-m3,0|$
1,0|$
-1,0||
You don't have an SV, since the measurement equation has no error. SW is a diagonal matrix. It looks as if the m's are a function of other parameters, you so need to define a function which computes them and include it as a START option, that is:
function CalcM
stuff to compute m1,m2,m3
end CalcM
The DLM instruction will then be:
dlm(start=CalcM(),a=af,c=cf,f=f,sw=%diag(||sigdeltasq,sigetasq||),y=||dp,dd||,other options)
xiangyu71
thanks very much!!
xiangyu71 wrote:i understand some about it . but i still have some question as fellows:
(1) the parameter M=c(m1,m2,m3) is obtained by the parameters PHI and psi. should i give the initiated value c(phi1,phi2,phi3,psi) to calculated M=c(m1,m2,m3) firstly? Must I give a loop to update m=c(m1,m2,m3) and how can i ?
(2)Whether should the data (△dt △dt-1 △dt-2 △dt-3 △bt △bt-1) in state equation and measure equation be setting(should the data △dt △dt-1 △dt-2 △dt-3 be stacked?) or not? is the data organized by formulation or program automatically?
my programm
dec frml[rect] af
1,0,0,0,0,0|$
0,1,0,0,0,0|$
0,0,1,0,0,0|$
0,0,0,0,1/psi,0|$
0,0,0,0,1,0||
dec rect f(6,2)
input f
1 0
0 0
0 0
0 0
0 1
0 0
dec frml cf
m2-m1,0|$
m3-m2,0|$
-m3,0|$
1,0|$
-1,0||
dec frml[rect] phi
frml phi = ||phi1,phi2,phi3|$
1,0,0|$
0,1,0|$
0,0,1||
decl frml [vect] CalcM
com CalcM = ee*psi*INV(%identity(3)-psi*phi))
nonlin m1 m2 m3
frml m1 = CalcM(1,1)
frml m2 = CalcM(1,2)
frml m3 = CalcM(1,3)
dec vect ee
ee = ||1,0,0||
compute phi1=phi2=phi3=0.1
dlm(start=CalcM(),method=bfgs,a=af,c=cf,f=f,sw=%diag
(||sigdeltasq,sigetasq||),y=||dlnrsi,dlnrgl||,TYPE=FILTER)
the error message :
## I2. Expected Instruction Here
the closed is full paper
thanks very much!!
First: your definition of phi has the wrong dimensions. It should be 3 x3 , not 4 x 3. You want to get rid of that last row.
dec frml[rect] phi
1,0,0|$
0,1,0||
Your m1, m2 and m3 aren't part of your parameter set since they're derived from the phi's and psi, so you don't want them in the nonlin. The following will calculate the m vector and define the m1, m2 and m3.
function CalcM
dec vector CalcM
com CalcM = %xcol(psi*INV(%identity(3)-psi*phi(1)),1)
compute m1=CalcM(1)
compute m2=CalcM(2)
compute m3=CalcM(3)
end CalcM
Your nonlin should be
nonlin phi1 phi2 phi3 sigdeltasq sigetasq (and psi as well if that's a free parameter)
You'll have to give guess values to the variances.
That final error, though seems to be because the DLM instruction wrapped to the next line without a continuation. It should read like:
dlm(start=CalcM(),method=bfgs,a=af,c=cf,f=f,$
  sw=%diag(||sigdeltasq,sigetasq||),y=||dlnrsi,dlnrgl||,TYPE=FILTER)
I don't see any simple way to reduce the number of states in the model.
xiangyu71
TomDoan wrote:
xiangyu71 wrote: I don't see any simple way to reduce the number of states in the model.
states determinated by lags of VAR, isn't it? how can i reduce the number of states?
Re: continue to Puzzle for speculative bubbles using state space
That's not a particularly large model, so I wouldn't worry about it taking too long to run. While it's certainly possible to generalize it to n lags rather than hard coding it for 3, I would recommend getting it to work for the fixed number of lags first, then worry about generalizing later.
xiangyu71 wrote:
nonlin phi1 phi2 phi3 sigdeltasq sigetasq psi
compute phi1= phi2= phi3= sigdeltasq =sigetasq =psi=0.1
That last line shouldn't be there.
xiangyu71
TomDoan wrote:That's not a particularly large model, so I wouldn't worry about it taking too long to run. While it's certainly possible to generalize it to n lags rather than hard coding it for 3, I would recommend getting it to work for the fixed number of lags first, then worry about generalizing later.
thanks for your recommend to me!
there are still some question about program
when i run the prog as fellows:
thanks very much!
Re: [Urgency] Puzzle for speculative bubbles using state space
Please send the program and data to support@estima.com. At this point, your problems are too specific to your particular situation to keep trying to answer them on the forum.
xiangyu71
TomDoan wrote:Please send the program and data to support@estima.com. At this point, your problems are too specific to your particular situation to keep trying to answer them on the forum.
i have sent the program and data to support@estima.com
i'm really thanks for your patients
xiangyu71
OPEN DATA "C:\data\133.xls"
CALENDAR(M) 1991:4
ALL 2010:03
DATA(FORMAT=XLS,ORG=COLUMNS) 1991:04 2010:03 rsi rgl date lnrsi lnrgl dlnrsi dlnrgl
nonlin phi1 phi2 phi3 psi
compute phi1=0.1, phi2=0.1, phi3= 0.1,psi=0.1
dec frml[rect] af
1,0,0,0,0,0|$
0,1,0,0,0,0|$
0,0,1,0,0,0|$
0,0,0,0,1/psi,0|$
0,0,0,0,1,0||
dec rect f(6,2)
input f
1 0
0 0
0 0
0 0
0 1
0 0
function CalcM1
dec vector CalcM1
compute CalcM1 = %xcol(psi*INV(%identity(3)-psi*phi(1)),1)
compute m1=CalcM1(1)
compute m2=CalcM1(2)
compute m3=CalcM1(3)
end CalcM1
dec frml cf
m2-m1,0|$
m3-m2,0|$
-m3,0|$
1,0|$
-1,0||
dec frml[rect] phi
1,0,0|$
0,1,0||
compute sigdeltasq =0.1,sigetasq =0.1,psi=0.1,$
dlm(start=CalcM1(),method=bfgs,a=af,c=cf,f=f, $
sw=%diag(||sigdeltasq,sigetasq||), y=||dlnrsi,dlnrgl||,TYPE=FILTER)
when i run it ,the error message :
## SX1. Identifier CALCM1 is Already in use as a(n) User Function
i want to know what problem will be exist in my programm!
thanks
Site Admin
Unread post by moderator »
We're already handling this via email--let's not waste other people's time posting the same question here, OK?
Tom Maycock
xiangyu71
moderator wrote:We're already handling this via email--let's not waste other people's time posting the same question here, OK?
Tom Maycock
sorry,thanks!
