Re: Dynamic Latent Factor Model
econometrics wrote:Hi Tom,
I have a problem with the estimated betas. I’ve run the program on my data and plotted the estimated factors with the empirical ones and it didn’t look good, the gap is too big especially the level. I thought to plot also the Diebold estimated betas with the empirical ones and see if are ok, the same behaviour. I must be doing something wrong and I can’t figure it out. The estimated level should be positive and starts at 5-6 percent in Diebold’s paper and the level that I’ve estimated is negative. I will attach the excel file just to see what betas I’ve got.
Thank you Tom.
Rosa
Have you allowed for the fact that the model includes a separate mean parameter. The data is modelled as Y(t)=mu+Lambda F(t) + noise. The factors are supposed to be mean zero.
