Impulse response functions for conditional variances
Postby user_123 » Tue Jan 04, 2011 9:06 am
Dear users,
I am relatively new in RATS, and have a problem in generating impulse response functions in a structural- form GARCH model.
I need graphs that show the responses of conditional variances of the three variables in the model to a one standard deviation shock to each of the three structural-form innovations.
here is the code i am replicating:
system(model=var)
variables dgs3mo spret curve
lags 1 to 5
estimate(resids=rvar)
compute gend   = %regend()
compute gstart = %regstart()
dec series[symm] h uu
gset h  * gend = %sigma
gset uu * gend = %sigma
* The covariance matrix is modelled in vec form as
* vec(H)=BL x Psi + BL x Gamma x B**-2 diag(H(t-1)) +
*     BL x Lambda x B**-2 diag (UU'(t-1))
* where Psi, Gamma, Lambda, and B are to be estimated, with B being the
* inverse of a matrix A with unit diagonal. BL is a matrix of squared
* interactions of members of B. The free coefficients are listed as
*    psi    n vector
*    gamma  n x n matrix
*    lambda n x n matrix
*    ap     n x n-1 matrix with the n-1 elements in each row
*            giving the non-diagonal elements of A.
compute n=3
compute nstack=n*(n+1)/2
dec vect psi(n)
dec rect gamma(n,n) lambda(n,n)
dec rect ap(n,n-1)
dec vect gammav(n) lambdav(n)
dec vect garchc
dec rect garcha garchb
* The function initrf is called as an initialization function for
* MAXIMIZE to compute the time-invariant matrices in the formula for
* vectorized covariance. Those matrices are called GARCHA, GARCHB and
* GARCHC.
function initrf
local integer i j k fill
dec rect a b bl
dim a(n,n)
dim bl(nstack,n)
ewise a(i,j)=%if(i==j,1.0,ap(i,j-(j>i)))
compute b=inv(a)
do k=1,n
   compute fill=0
   do i=1,n
      do j=1,i
         compute fill=fill+1
         compute bl(fill,k)=b(i,k)*b(j,k)
end do k
compute garchc=bl*psi
compute garcha=bl*gamma*a*a
compute garchb=bl*lambda*a*a
dec frml[symm] hf
frml hf = %vectosymm(garchc+garcha*%xdiag(h{1})+garchb*%xdiag(uu{1}),n)
frml logl = $
    hx = hf(t) , $
    ux = %xt(rvar,t), $
    %logdensity(hx,ux)
* Initial guess values
compute psi=%xdiag(%sigma)*.10
compute ap=%const(0.0)
compute gammav=%const(.80)
compute lambdav=%const(.10)
compute gamma=%diag(gammav)
compute lambda=%diag(lambdav)
* Estimate the restricted model with only diagonal elements in gamma and
* lambda.
nonlin(parmset=garchparms) psi gammav lambdav ap
maximize(trace,start=%(gamma=%diag(gammav),lambda=%diag(lambdav),initrf()),$
  parmset=garchparms,pmethod=simplex,piters=5,method=bfgs,iters=200) logl gstart gend
* Free up lambda
nonlin(parmset=garchparms) psi gammav lambda ap
maximize(trace,start=%(gamma=%diag(gammav),initrf()),$
* Convert from conditional variances of the non-orthogonalized
* residuals, to the structural ones.
set hi gstart gend = aha=(a*h*tr(a)),aha(1,1)
set hs gstart gend = aha=(a*h*tr(a)),aha(2,2)
set hy gstart gend = aha=(a*h*tr(a)),aha(3,3)
spgraph(footer="Conditional Variances of Structural Innovations",vfields=3)
graph(header="Innovation to Short Rate")
# hi
graph(header="Innovation to Stock Prices")
# hs
graph(header="Innovation to Yield Curve Slope")
# hy
* conditional correlations
set rho12 = h(t)(1,2)/sqrt(h(t)(1,1)*h(t)(2,2))
set rho13 = h(t)(1,3)/sqrt(h(t)(1,1)*h(t)(3,3))
set rho23 = h(t)(2,3)/sqrt(h(t)(2,2)*h(t)(3,3))
spgraph(footer="Conditional Correlations between financial variables",vfields=3)
graph(header="Short Rate and Stock Prices")
# rho12
graph(header="Short Rate and Yield Curve Slope")
# rho13
graph(header="Yield Curve Slope and Stock Prices")
# rho23
So now i need the impulse response functions, and I'm not sure how to do that for the conditonal variance and covariance. Can anyone please give me a hint?
Thank you very much!
user_123
user_123
Re: Impulse response functions for conditional variances
Postby TomDoan » Tue Jan 04, 2011 10:40 am
The impulse responses can be computed using IMPULSE; the only question is what shocks you want. Because you have a GARCH model, the covariance matrix changes from period to period. Is this the Rigobon and Sack model?
Postby user_123 » Tue Jan 04, 2011 5:15 pm
thank you very much for replying! yes this is the rigobon and sack model (2003) that im trying to replicate, and the shocks are those to the structural-form innovations.
Do you know how to do that?
regards,
user_123
Postby TomDoan » Thu Jan 06, 2011 8:04 am
You would use IMPULSE with the option FACTOR=INV(A). That would give you unit variance structural shocks. Note, however, that the unit variance is not a "natural" scale for the structural shocks in this model because the normalization is the 1's on the diagonal of the A matrix, not the identity matrix for the variances (since the variances are time-varying anyway).
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
