Checking memory used by RATS
Postby jonasdovern » Tue Aug 24, 2010 6:31 am
I coundn't find (or better: remember) the command which allows to check how much memory RATS currently uses. (I am running a Gibbs sampler which would run without error with a small number of iterations, but which crashes RATS when increasing the number of iterations. I would like to check if memory problems are the problem...)
jonasdovern
Re: Checking memory used by RATS
Postby moderator » Tue Aug 24, 2010 10:25 am
You can do:
SHOW MEMORY
However, if the program is actually crashing (i.e. shutting down spontaneously), it is highly unlikely that it would be do running out of memory.
Tom Maycock
Site Admin
Postby jonasdovern » Wed Aug 25, 2010 2:21 am
Thanks. I'll check how the used memory evolves. The program is not actually shutting down - but rather stops working and displays (according to my translation, I have a German system): "Application does not react anymore".
jonasdovern
Who is online
Users browsing this forum: Google [Bot] and 1 guest
