Double Precision Variable
tmiller
Unread post by tmiller »
Is there a way to create double precision variables when programming in WinRats?
Re: Double Precision Variable
All reals and matrix elements are already double precision (64 bit IEEE on all machines that we currently use). What you can't get is single precision, though I believe I have a RATS function somewhere that will take a single precision real (read into an integer) and convert it to a double.
Integers are 32 bit on the standard WinRATS and MacRATS, and 64 bit on the Pro 64 or on 64-bit UNIX versions.
