Fitted Values from ARMA
Postby John_Val » Thu Apr 01, 2010 11:46 am
I am trying to compute fitted values from an estimated ARMA model, but my results are not correct.
boxjenk(constant,ar=1,ma=1,inputs=0,iter=1000,define=equation) dsp 1995:1 2008:12 res1
set fitted = 0.0
do t=1995:3,2008:12
com fitted(t)= %beta(1) + %beta(2)*dsp(t-1) + %beta(3)*res1(t-1)
end do
set fit = dsp-res1
The difference between fitted and fit is always equal to -1.42, starting from 1995:3 onwards.
Am I computing fitted wrong?
John_Val
Re: Fitted Values from ARMA
Postby TomDoan » Thu Apr 01, 2010 12:56 pm
The constant in the BOXJENK formulation is the process mean, not the intercept in an ARMA equation. To convert that into the form you're using, the equivalent representation is:
y-%beta(1) = %beta(2)*(y{1}-%beta(1))+eps+%beta(3)*eps{1}
or
y = %beta(1)*(1-%beta(2))+%beta(2)*y{1}+eps+%beta(3)*eps{1}
So instead of using %beta(1) as the intercept, use %beta(1)*(1-%beta(2)).
BTW, the PRJ instruction will work after a BOXJENK. You could just do
prj fitted 1995:3 2008:12
instead of the loop.
Who is online
Users browsing this forum: Google [Bot] and 2 guests
cron
