Forecasting problem
Hello guys!
I just started using rats and don't fully understand it. Basically, that's what I need to do:
3. The task: take the estimation data set as the complete data set except for the last four years (referred to as the forecast period).
o On the estimation data set estimate your chosen model and interpret the coefficients.
o Use PRJ to project the data over the forecast period.
o Print and graph the actual and forecasts.
4. Evaluation
o Obtain the forecast error defined as: actual minus forecast.
o Square the forecast errors.
o Obtain the mean of the squared forecast errors (hint: use STATISTICS).
o Obtain the square root of the mean of the squared forecast errors (the root mean squared error).
I put this for the evaluation question:
# ydetrend 2005:1 2008:1
smpl 2005:1 2008:1
set ferrory = ydetrend
print / ferrory
set ferrory = ferrory^2
statistics ferrorysq
compute meansqerrory = %mean
compute rmse = %mean^0.5
display 'root mean squared error is' rmse
but I keep getting error, I'm not sure what I'm doing wrong. Hope you can help me! Thank you
4. Evaluation
smpl 2005:1 2008:1
print / ferrory
