Saving after using dedit
Postby arian » Tue Sep 25, 2012 12:00 pm
I am unable to save changes to series names while using dedit in RATS 8.1. I am able to execute the code sucessfully in RATS 7.1.
The code is:
dedit data.rat
rename x xyz
save
close dedit
When I open the dataset, the variable remains named "x". Running the exact same lines in version 7.1 executes perfectly. I have not been able to find any changes to the dedit instruction in the documentation, so it seems like I am using the correct commands. Does anyone have any input or possible solutions to this problem?
arian
Re: Saving after using dedit
Postby moderator » Wed Sep 26, 2012 11:30 am
You need to use the QUIT instruction, not CLOSE, to close a file that has been opened using DEDIT. So, try using QUIT instead. If it still doesn't seem to work, email us at support@estima.com with your full contact information and we'll take a look.
Tom Maycock
Site Admin
Who is online
