Hello Tom
I am using a program based on something I’ve gotten on RATS forum for IRF minimum distance estimator. Program is running OK, but the CEEMETRIC statistic comes out with different values in successive runs. Also, there is message of no convergence in the output. Can you give some tips on how to have convergence and get same results on successive runs. Anyway, I am reproducing the CEEMETRIC and parameters statistics bellow, and attaching program and data base. Thanks in advance for any help.
Regards
Ricardo
FIND Optimization - Estimation by BFGS
NO CONVERGENCE IN 5 ITERATIONS
LAST CRITERION WAS 0.0000000
SUBITERATIONS LIMIT EXCEEDED.
Function Value 86.4611
1. B1 2.748322354 0.128584639 21.37364 0.00000000
2. B2 -0.925984923 0.082945827 -11.16373 0.00000000
3. NAI -0.003601027 0.000149905 -24.02206 0.00000000
4. DELTA1 0.650786109 0.006989063 93.11493 0.00000000
5. DELTA2 0.112792811 0.006621920 17.03325 0.00000000
6. GAMMA1 0.999929710 0.000269758 3706.76539 0.00000000
7. GAMMA2 -0.628030752 0.008050925 -78.00728 0.00000000
8. GAMMA3 0.627869315 0.007114150 88.25641 0.00000000
Function Value 83.5506
1. B1 2.746996538 0.136081191 20.18645 0.00000000
2. B2 -0.926644714 0.086361256 -10.72987 0.00000000
3. NAI -0.003600207 0.000154567 -23.29213 0.00000000
4. DELTA1 0.650803519 0.007494003 86.84325 0.00000000
5. DELTA2 0.112808882 0.007143159 15.79258 0.00000000
6. GAMMA1 0.999914098 0.000301787 3313.30841 0.00000000
7. GAMMA2 -0.628032278 0.008344817 -75.26016 0.00000000
8. GAMMA3 0.627869592 0.007405665 84.78234 0.00000000
program:
OPEN DATA "/RATS 8.0/examples/dadosm.xlsx"
calendar(m) 2000:6
DATA(FORMAT=XLSX,ORG=COLUMNS) 2000:6 2012:12 selic igp pig pit credito juros
*print / selic igp pig pit credito juros
* Transformando Vari·veis
set lig = log(pig)
set lit = log(pit)
set lip = log(igp)
set lcre = log(credito)
set lcrer = lcre - lip
set dp = 100*(lip - lip{1})
set selr = selic - dp
set jur = juros**1/12 - dp
X11(multiplicative,adjust=slig) lig
*****VEC-CATS
set d812 = t==2008:12; set d83 = t==2008:3;* dummies para slig
set d012 = t==2001:2; set d0112 = t==2001:12; set d028 = t==2002:8;
set d029 = t==2002:9; set d0210 = t==2002:10;set d032 = t==2003:2;
set d0311 = t==2003:11; set dp0112 = t==2001:12
SET TREND = T
SET D200810 = t > 2008:10
***********VEC-RATS***********
set CV1 = SLIG{1} - 0.263*SELR{1} - 0.124*LCRER{1} + 0.18*JUR{1} + 0.117*2008:10 - 0.002*TREND
EQUATION(COEFFS=||1,-0.263,-0.124,0.18,0.117,-0.002||) CVEQ1 CV1
# SLIG{1} SELR{1} LCRER{1} JUR{1} D200810 TREND
set CV2 = -14.160*SLIG{1} + SELR{1} + 0.334*LCRER{1} - 1.630*JUR{1} + 0.171*2008:10 + 0.014*TREND
EQUATION(COEFFS=||-14.160,1,0.334,-1.630,0.171,0.014||) CVEQ2 CV2
*GRAPH 1
*# CV1
*GRAPH 1
*# CV2
******VAR*****
system(model=varmodel)
variables slig selr lcrer jur
lags 1 to 9
det constant D200810 d812 d83 d028 d029 d032 d0311 dp0112
ect cveq1 cveq2
estimate(NOprint)
compute nsteps=30
source(noecho) "/RATS 8.0/Procedures/MCVARDoDraws.src"
@MCVARDoDraws(model=varmodel,DRAWS=1000,step=nsteps)
source(noecho) "/RATS 8.0/Procedures/mcprocessirf.src"
@MCprocessIRF(model=varmodel,center=mean,STDDEV=1.0,IRF=results,var=estvar,lower=lb,upper=ub)
*print / results
dec vect[strings] sl(4)
compute sl=|| "SLIG", "SELR", "LCRER", "JUR" ||
*spgraph(vfields=2,hfields=2,header="Estimated IRFs")
*do i=1,4
*graph(nodates,header=sl(i)) 3
*# results(i,2)
*# ub(i,2) / 2
*# lb(i,2) / 2
*end do i
*spgraph(done)
*do i=1,4
*print / estvar(i,2)
*end do
* (First run at) Replication file for Hulsewig, Mayer &
* Wollmershauser(2006), "Bank loan supply and monetary policy
* transmission in Germany: An assessment based on matching impulse
* responses," Journal of Banking & Finance, vol. 30, no 10, 2893-2910.
declare real beta b1 b2 nai delta1 delta2 gamma1 gamma2 gamma3
declare series y l rl rm eta
* Set up the DSGE. This uses the original optimization equation from the
* appendix rather than the partially substituted one in the main text.
frml(identity) eqna6 = beta*l{-1}-(1+beta)*l+l{1}+nai*(rl-rm)
frml(identity) eqn14 = b2*rl - (b1*y - l)
frml(identity) eqn15 = y - (gamma1*y{1}+gamma2*rl{1}+gamma3*rl{2})
frml(identity) eqn16 = rm - (delta1*rm{1}+delta2*rm{2}+3*eta)
frml s1 = eta
compute beta=.99
*compute b1=2.1887,b2=.0142,nai=.0010,delta1=1.4665,delta2=-.5204
*compute gamma1=.9985,gamma2=.0009,gamma3=-.0026
compute b1=2.7475
compute b2=-0.9266
compute nai=-0.0036
compute delta1=0.6508
compute delta2=0.1128
compute gamma1=0.9999
compute gamma2=-0.6280
compute gamma3=0.6279
group loanmodel eqna6 eqn14 eqn15 eqn16 s1
dsge(a=a,f=f,model=loanmodel) y rm l rl eta
* They don't report the standard error of the shock, but it appears to
* be roughly .2.
source(noecho) "/RATS 8.0/Procedures/dlmirf.src"
@dlmirf(a=a,f=f*.2,steps=nsteps,varlabels=||"GDP","RM","LOAN","RL"||,page=byshock,results=theoretical)
*do j=1,4
*print / theoretical(j,1) results(j,2)
*end do
spgraph(vfields=2,hfields=2,header="theoretical irfs")
do i=1,4
graph(header=sl(i),key=below,nodate) 4
# theoretical(i,1)
# results(i,2)
# ub(i,2) / 3
# lb(i,2) / 3
* You need the estimated IRF's from the VAR and their variances in order
* to do the optimization. This assumes that the estimated IRF's to the
* rate shock are in the series estimated(i,1) and the corresponding
* variances are in estvar(i,1).
nonlin(parmset=dsgeparms) b1 b2 nai delta1 delta2 gamma1 gamma2 gamma3
declare real ceemetric
find(parmset=dsgeparms,method=bfgs,stderrs) minimum ceemetric
@dlmirf(a=a,f=f*.2,steps=nsteps,results=theoretical,nograph)
compute ceemetric=0.0
do h=2,nsteps
do i=1,4
compute ceemetric=ceemetric+((theoretical(i,1)(h)-results(i,2)(h))^2)/estvar(i,2)(h)
end do h
end find
