VARMAX-GARCH-BEKK
VARMAX-GARCH-BEKK
Postby hashem » Sun Jan 16, 2011 1:57 pm
I used your varma-bekk code to turn it into a varmax bekk(2,2) code. could you please check that i have done it correctly. I also added the commands to compute the standerdized residuals and the rho but i am not sure that this is correct because you define the varma residuals(residv) differently. and how do i get the conditional variances for each equation?
if i want to add another ar lag do i just creat a new artwo(n,n) matrix and add to to the mean nonlin command line and add artwo*yv{2} term to the frml residv equation?
last question, if i want the bekk to be lower triangular i can add the restrictions manually using the nonlin command and set each component (1,2) in the arch and garch term to zero?
VARMAX(1,1)-BEKK(2,2)
smpl 2002:12:30 2010:10:5
set x1 = 100.0*usa
set x2 = 100.0*arg
set xoil = 100.0*oil
set xcus3t = 100.0*cus3t
compute n=2
compute gstart=2003:1:20,gend=2010:10:5
dec series[vect] yv eg
dec frml[vect] residv
dec vect[series] u(n)
* SERIES[SYMM] named H and UU. UX and HX are used for the current values
* of the residual vector and H matrices
declare series[symm] h uu
declare symm hx(n,n)
declare vect ux(n)
* These will be the parameters for the mean equations. These are adjusted to add
* variance or covariance terms as needed.
dec vect b(n)
dec rect ar(n,n) ma(n,n) exo(n,n)
nonlin(parmset=meanparms) b ar ma exo
* Mean model = VARMA(1,1)
frml residv = yv-b-ar*yv{1}-ma*%xt(u,t-1)-exo*eg
gset yv = ||x1,x2||
gset eg = ||xoil,xcus3t||
* Run preliminary VAR(4) to get estimates of residuals
linreg x1 / u(1)
# constant x1{1 to 4} x2{1 to 4} xoil xcus3t
linreg x2 / u(2)
linreg x1
# constant x1{1} x2{1} u(1){1} u(2){1} xoil xcus3t
compute b(1)=%beta(1),ar(1,1)=%beta(2),ar(1,2)=%beta(3),$
                      ma(1,1)=%beta(4),ma(1,2)=%beta(5),$
                      exo(1,1)=%beta(6),exo(1,2)=%beta(7)
linreg x2
compute b(2)=%beta(1),ar(2,1)=%beta(2),ar(2,2)=%beta(3),$
                      ma(2,1)=%beta(4),ma(2,2)=%beta(5),$
                      exo(2,1)=%beta(6),exo(2,2)=%beta(7)
vcv(matrix=rr,noprint)
# u
gset h  * gend = rr
gset uu * gend = rr
set u(1) = 0.0
set u(2) = 0.0
declare frml[symm] hf
frml logl = $
    hx    = hf(t) , $
    h(t)  = hx, $
    ux    = residv , $
    uu(t) = %outerxx(ux), $
    %pt(u,t,ux),$
    %logdensity(hx,ux)
* This does a simple GARCH(1,1) model for the variance.
dec symm vcs(n,n) vas(n,n) vbs(n,n) vastwo(n,n) vbstwo(n,n)
compute vcs=rr,vbs=%const(0.50),vas=%const(0.05),vastwo=%const(0.05),vbstwo=%const(0.5)
nonlin(parmset=garchparms) vcs vas vbs vastwo vabtwo
frml hf = vcs+vbs.*h{1}+vas.*uu{1}+vbstwo*h{2}+vastwo*uu{2}
maximize(trace,parmset=meanparms+garchparms,pmethod=simplex,piters=10,method=bfgs,iters=400) logl gstart gend
* This does a BEKK model for the variance
dec rect vab(n,n) vbb(n,n) vabtwo(n,n) vbbtwo(n,n)
compute vab=.05*%identity(n),vbb=.50*%identity(n),vabtwo=0.05*%identity(n),vbbtwo=0.05*%identity(n)
nonlin(parmset=garchparms) vcs vab vbb vabtwo vbbtwo
compute vcs=%decomp(rr)
frml hf = vcs*tr(vcs)+vbb*h{1}*tr(vbb)+vab*uu{1}*tr(vab)+vbbtwo*h{2}*tr(vbbtwo)+vabtwo*uu{2}*tr(vabtwo)
set x1sd = u(1)/sqrt(h(t)(1,1))
set x2sd = u(2)/sqrt(h(t)(2,2))
set x1sdsq = x1sd**2
set x2sdsq = x2sd**2
set rho12 = h(t)(1,2)/sqrt(h(t)(1,1)*h(t)(2,2))
set rho21 = h(t)(2,1)/sqrt(h(t)(1,1)*h(t)(2,2))
graph
# rho12
@mvqstat(lags=8,dfc=4)
# x1sd x2sd
@mvqstat(lags=8,dfc=6)
# x1sdsq x2sdsq
regards
Hashem
hashem
Re: VARMAX-GARCH-BEKK
Postby TomDoan » Mon Jan 17, 2011 5:38 pm
EXO is really not n x n; it's n x the number of exogenous variables. Here, they're the same, but it would be a good idea to create a separate variable for the number of exogenous variables and use that for the second dimension.
Your formula for the standard GARCH isn't correct. The operator on the last two terms needs to be .* not the simple *. The .* is the Hadamard (or element by element) product rather than the standard matrix multiply.
Regarding the specification tests, first off, you're going to need the GSTART and GEND range parameters on these SET instructions.
However, the simple standardized residuals (like x1sd) are only good for certain types of diagnostics. This is addressed in the version 8 User's Guide:
The HH in that is your H, and the RD(TIME) would be %XT(U,TIME).
Even with the properly standardized residuals, the MVQSTAT procedure applied to the squares is probably not the best way to test for residual GARCH effects. There's a new procedure for doing a multivariate ARCH test posted at:
http://www.estima.com/forum/viewtopic.php?f=7&t=928
In your case, you would execute it with something like:
@mvarchtest(lags=2)
# zu
Postby hashem » Tue Jan 18, 2011 2:13 pm
Thank you Tom you are absolutely right I guess i got luck with the first topic and i wasnt really interested in the normal garch part.
i have a couple more questions:
does the MVarchtest work with rats version 7.1?
how to i input intial values for the parameters and restrictions when i use the normal garch command?
hashem
Postby TomDoan » Tue Jan 18, 2011 2:54 pm
hashem wrote:Thank you Tom you are absolutely right I guess i got luck with the first topic and i wasnt really interested in the normal garch part.
If you take the TITLE option off the first REPORT instruction, it will.
hashem wrote:how to i input intial values for the parameters and restrictions when i use the normal garch command?
With the INITIAL option. However, you can't do any "restrictions" on a standard GARCH except those that are hardcoded into the parameterization (such as BEKK or CC restrictions).
Users browsing this forum: Google [Bot] and 1 guest
