Multivariate Ljung-Box tests
PostPosted: Tue Mar 19, 2013 12:36 pm
by yli725
I use a BEKK model in my research, after estimating, I want to make sure my model was proper specified, so I applied multivariate Ljung-Box tests for both residuals for mean equation and squared residuals for variance equation. My codes are
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
end do time
set z1s = (zu(1))**2
set z2s = (zu(2))**2
set z3s = (zu(3))**2
@mvqstat(lags=6)
# z1s z2s z3s
Since the entire residual vector needs to be standardized, I want to make sure that I make it right.
Also, the user guide says that the results will be different if I choose a different facrorization. I want to know what other facrorizations I can choose.
I appreciate that your kindly help.
Re: Multivariate Ljung-Box tests
PostPosted: Wed Mar 20, 2013 10:07 am
What you want is to do is @MVARCHTEST applied to the standardized residuals:
end do time
@MVARCHTest(lags=6)
# zu
The two (Q test applied to the squares and the ARCH test) will do similar things to the diagonals, but the ARCH test treats the interactions correctly.
PostPosted: Wed Mar 20, 2013 4:07 pm
by yli725
TomDoan wrote:What you want is to do is @MVARCHTEST applied to the standardized residuals:
end do time
@MVARCHTest(lags=6)
# zu
Thank you very much, Tom.
When I appiled @mvarchtest, I noticed the degrees is 864, if my subsample's observation is only 800, does this test still valid?
PostPosted: Wed Mar 20, 2013 4:44 pm
end do time
@MVARCHTest(lags=6)
# zu
LAGS=6 may be a bit much, but it's still OK. It's a multiple regression on cross products of the residuals, so the potential degrees of freedom is 6 (=n(n+1)/2) x 800.
PostPosted: Thu Mar 21, 2013 1:49 pm
by yli725
I still confused about how to choose the lag number for both arch test and LB test.
For LB test, I saw most literature choose 6, 12,24 and even 36.
How about the arch test, usually I choose 1 to 3 up to most.
Here is my arch test result:
@mvarchtest(lags=1)
# zu
Test for Multivariate ARCH
Statistic Degrees Signif
    70.31      36 0.00054
@mvarchtest(lags=2)
# zu
    90.24      72 0.07181
@mvarchtest(lags=3)
# zu
   107.60     108 0.49270
When I choose Lags=1, still have arch effect, but choose lags=3, arch effect is no long exist.
Does it mean I much include q=3 in the multivariate garch model to avoid the arch effect?
