Volatility Spillovers with Bivariate BEKK
Many thanks for your help and support.
I'm trying to execute a bivariate model of (oil/equity returns) Volatility spillover.
I've got a paper I'm trying to reproduce, just to ensure that my estimation methods for an up to date dataset mathces the author's; I'm repeating the analysis with his dataset.
I've not been able to get the exact dataset used by the author, but have (hopefully) downloaded the very same myself. (Descriptives match)
There is no mention of anything extra in the paper interms of the model, other than it's a BEKK model with BFGS algorithm.
I've attached the summary of data and the paper.
Now, my questions:
1- When I run the analysis using
I get very different results and neither match the autours.
Would you say I'm executing the model differently or my dataset does not match?
How do I bring the two as close as possible?
Alos, I was hoping you could tell me how to obtain a Ljung–Box statistic for serial correlation for my data?
Many Thanks
Now, my questions:
- Code: Select all
garch(p=1,q=1,mv=bek,method=bfgs) / xoil xhealth
garch(p=1,q=1,mv=bek,method=bfgs,iters=200,pmethod=simplex,piters=10) / xoil xhealth
Convergence in 69 Iterations. Final criterion was 0.0000013 <= 0.0000100
Weekly Data From 1992:01:08 To 2008:04:30
Usable Observations 852
Log Likelihood 3461.6956
1. Mean(1) 0.002090746 0.001593417 1.31211 0.18948148
2. Mean(2) 0.001726831 0.000745034 2.31779 0.02046089
3. C(1,1) 0.008817796 0.002553867 3.45272 0.00055496
4. C(2,1) -0.001048472 0.001613817 -0.64968 0.51589605
5. C(2,2) -0.002347804 0.000803534 -2.92185 0.00347960
6. A(1,1) -0.221519390 0.041868875 -5.29079 0.00000012
7. A(1,2) -0.021152662 0.019613492 -1.07848 0.28082182
8. A(2,1) 0.081336204 0.066591889 1.22141 0.22192966
9. A(2,2) -0.250079660 0.038994711 -6.41317 0.00000000
10. B(1,1) 0.956635720 0.017735128 53.94016 0.00000000
11. B(1,2) -0.002970195 0.009949480 -0.29853 0.76530050
12. B(2,1) 0.025768393 0.028568335 0.90199 0.36706143
13. B(2,2) 0.962394976 0.012044865 79.90085 0.00000000
Convergence in 77 Iterations. Final criterion was 0.0000000 <= 0.0000100
1. Mean(1) 0.002090891 0.001522827 1.37303 0.16974228
2. Mean(2) 0.001726786 0.000709147 2.43502 0.01489099
3. C(1,1) 0.008817420 0.002478359 3.55777 0.00037402
4. C(2,1) -0.001048361 0.001536697 -0.68222 0.49510147
5. C(2,2) -0.002347789 0.000869196 -2.70111 0.00691094
6. A(1,1) 0.221506698 0.045047721 4.91716 0.00000088
7. A(1,2) 0.021157518 0.020016119 1.05702 0.29050063
8. A(2,1) -0.081345990 0.069290842 -1.17398 0.24040346
9. A(2,2) 0.250075672 0.041868681 5.97286 0.00000000
10. B(1,1) 0.956639791 0.017589268 54.38770 0.00000000
11. B(1,2) -0.002973061 0.008713917 -0.34119 0.73296403
12. B(2,1) 0.025776046 0.028494835 0.90459 0.36568443
13. B(2,2) 0.962395291 0.013489873 71.34206 0.00000000
Many Thanks
