M-GARCH-M in GARCH Wizard
Postby PERRY » Sat Jul 30, 2011 6:37 pm
How can I estimate a multivariate GARCH in the mean model within the GARCH Wizard?
PERRY
Re: M-GARCH-M in GARCH Wizard
Postby PERRY » Sun Jul 31, 2011 7:47 pm
I tried to follow the manual and wrote this code but it does not work I get the message:
Uploaded with ImageShack.us
PERRY
Postby moderator » Tue Aug 02, 2011 9:29 am
I don't think you can do that using the Wizard, at least currently. You need to define the equations, GROUP them into a MODEL, and supply that via the MODEL option. See page 301 of the RATS 8 User's Guide for details.
Tom Maycock
Estima
Site Admin
Postby PERRY » Tue Aug 02, 2011 11:26 am
Thank you Tom.
I was hopping to avoid that as I am new to RATS programming and I had already read page UG301 and I came up with the program
CALENDAR(M) 1973:11
OPEN DATA "C:\Users\User\Desktop\110722 Energy RATS\dataus.txt"
DATA(FORMAT=PRN,NOLABELS,ORG=COLUMNS,TOP=2,RIGHT=3) 1973:11 2007:10 DATES OIL IPI
/* PRE-ESTIMATION */
dec symm[series] hhs(2,2)
clear(zeros) hhs
equation oileq oil
# constant hhs(1,1) hhs(1,2)
equation ipieq ipi
# constant hhs(2,1) hhs(2,2)
group garchm oileq ipieq
garch(model=garchm,p=1,q=1,pmethod=simplex,piters=10,$
mvhseries=hhs)
/* ESTIMATION OF THE M-GARCH-M */
GARCH(P=1,Q=1,MV=BEKK,REGRESSORS) / OIL IPI
# Constant OIL IPI HHS(1,1) HHS(2,1) HHS(2,2)
PERRY
Postby TomDoan » Tue Aug 02, 2011 12:47 pm
The first of the two looks correct. Generally, you only include the "own" covariances in the mean model. The second one clearly is incorrect, because you're including current OIL in the equations---perhaps you mean OIL{1} which would put the lagged value in.
Postby PERRY » Tue Aug 02, 2011 12:55 pm
Running the above program I get the following output:
Convergence in   159 Iterations. Final criterion was  0.0000000 <=  0.0000100
Monthly Data From 1973:11 To 2007:10
Usable Observations        408
Log Likelihood        2090.6861
    Variable        Coeff      Std Error      T-Stat      Signif
1.  Constant        -4.0560e-003  7.6905e-004     -5.27400  0.00000013
2.  OIL        -0.6627       0.0960     -6.90462  0.00000000
3.  IPI        0.0000       0.0000      0.00000  0.00000000
4.  HHS(1,1)        0.0000       0.0000      0.00000  0.00000000
5.  HHS(2,1)        0.0000       0.0000      0.00000  0.00000000
6.  HHS(2,2)        0.0000       0.0000      0.00000  0.00000000
7.  ¾OYÃ\݇?øzøÂÚf»>nŸ)ÝHL¿Ã„Ô¤ô²¼?Ðõá0¼>{Õ¾të±?8ÄhL®~¿àÊNŸŠ
U¾Ð¼—šµÔe¾d ÂgÇ|B¾ç‘Àtš—5¿~` -4.9031e+238       0.0000      0.00000  0.00000000
8.  Ðõá0¼>{Õ¾të±?8ÄhL®~¿àÊNŸŠ
U¾Ð¼—šµÔe¾d ÂgÇ|B¾ç‘Àtš—5¿~`                                     4203.2627       0.0000      0.00000  0.00000000
9.  ¼—šµÔe¾d ÂgÇ|B¾ç‘Àtš—5¿~`        0.0000       0.0000      0.00000  0.00000000
10. ó–qýì>ð`nŽ}k=?§"=N÷ªì?åv>ÔÖâ¾Š·øbn¼?]˜9,Þ­Ô?>y*è…¦¾o•¤að„¾ê"£|P‡>&}ð(Í?5¿ˆÍžjc          36793.2891       0.0000      0.00000  0.00000000
11. øbn¼?]˜9,Þ­Ô?>y*è…¦¾o•¤að„¾ê"£|P‡>&}ð(Í?5¿ˆÍžjc                                          1.1731e+021       0.0000      0.00000  0.00000000
12. P‡>&}ð(Í?5¿ˆÍžjc        -2.5677e+045       0.0000      0.00000  0.00000000
13. C(1,1)        -7.2427e-003  1.7902e-003     -4.04579  0.00005215
14. C(2,1)        -8.8975e-005  1.6438e-003     -0.05413  0.95683315
15. C(2,2)        2.8661e-006  4.9067e-003 5.84128e-004  0.99953393
16. A(1,1)        -0.8041       0.1463     -5.49438  0.00000004
17. A(1,2)        -0.2136       0.1126     -1.89697  0.05783225
18. A(2,1)        0.2031       0.2289      0.88734  0.37489799
19. A(2,2)        -0.3593       0.1668     -2.15351  0.03127829
20. B(1,1)        1.2237       0.2725      4.49011  0.00000712
21. B(1,2)        1.1514       0.1842      6.25248  0.00000000
22. B(2,1)        -0.6243       0.4439     -1.40662  0.15953878
23. B(2,2)        -0.9113       0.2513     -3.62565  0.00028824
PERRY
Postby TomDoan » Tue Aug 02, 2011 2:35 pm
PERRY wrote:Running the above program I get the following output:
That's out of the second GARCH instruction, which isn't properly formed. The REGRESSORS option was never really designed to work on a multivariate model; instead, you need to use the MODEL option, as is done in your first GARCH.
Postby PERRY » Wed Aug 03, 2011 1:46 pm
TomDoan wrote:The first of the two looks correct. Generally, you
in.
Tom thank you again for all the help, I really appreciate it.
The program I posted is my impression from page UG301 of how I should
structure a M-GARCH-M. I thought both the first two as you mention and
the last part are needed to estimate the M-GARCH-M for the multivariate
system OIL, IPI.
Regarding the inclusion of the contemporaneous OIL and IPI I did not
notice it was not lagged.
PERRY
Postby PERRY » Wed Aug 03, 2011 2:01 pm
Here is how I modified the code based on the above:
CALENDAR(M) 1973:11
DATES OIL IPI
I assume that with the following I manage to create a matrix that will store the initial values and then the actual values for the conditional variances and covariances.
clear(zeros) hhs
Below I define the two equations that I need for the M-GARCH-M I want to estimate.
I still do not understand how RATS will associate hhs(i,j) with the conditional variances/covariances. It looks like the mean equation of a multivariate GARCH in-the-mean model without any other than the constant and the conditional variances explanatory variables but still hhs(i,j) are not associated with anything...
equation oileq oil
# constant hhs(1,1) hhs(1,2) hhs(2,1) hhs(2,2)
equation ipieq ipi
Next we group the equations into a model labeled "garchm" as you advised:
Finally in the last part of the program we instruct RATS to perform a GARCH(1,1) estimation using the "garchm" model, BEKK specification, preliminary estimation using simplex with 10 iterations.
garch(model=garchm,p=1,q=1,mv=BEKK,pmethod=simplex,piters=10,$
mvhseries=hhs)
Is the following the part where RATS stores the conditional variances/covariances in the hss matrix?
mvhseries=hhs
That is it? sorry for being so analytical but I am trying to understand the logic. I have been told RATS is very powerful and want to be able to use it for more than standard programs.
Thank you in advance Tom...!!!
PERRY
Postby moderator » Wed Aug 03, 2011 2:21 pm
PERRY wrote:Is the following the part where RATS stores the conditional variances/covariances in the hss matrix?
mvhseries=hhs
Yes. The key is to refer to the same variable name on both the MVHSERIES option and in your equations.
Tom Maycock
Estima
Site Admin
Postby PERRY » Fri Aug 05, 2011 8:26 am
OK now I run the program:
CALENDAR(M) 1973:11
clear(zeros) hhs
equation oileq oil
equation ipieq ipi
mvhseries=hhs)
And I got these results:
Convergence in    49 Iterations. Final criterion was  0.0000045 <=  0.0000100
Log Likelihood                      2106.4402
1.  Constant                        0.0030665    0.0063040      0.48644  0.62665755
2.  HHS(1,1)                        2.7241851    1.2881911      2.11474  0.03445239
3.  HHS(2,1)                      -58.0674533   21.4759674     -2.70383  0.00685445
4.  HHS(2,1)                      -57.7541027   21.4759760     -2.68924  0.00716144
5.  HHS(2,2)                     -160.8529558   95.2018502     -1.68960  0.09110469
6.  Constant                        0.0043623    0.0013002      3.35503  0.00079358
7.  HHS(1,1)                       -0.0427378    0.0812831     -0.52579  0.59903456
8.  HHS(2,1)                       -1.9714207    1.7100354     -1.15285  0.24897043
9.  HHS(2,1)                       -1.9022851    1.7100860     -1.11239  0.26596986
10. HHS(2,2)                      -20.9218211   20.8896361     -1.00154  0.31656546
11. C(1,1)                          0.0079456    0.0014138      5.61989  0.00000002
12. C(2,1)                          0.0000917    0.0012644      0.07249  0.94221068
13. C(2,2)                          0.0028532    0.0013020      2.19145  0.02841922
14. A(1,1)                          0.6897016    0.0710530      9.70686  0.00000000
15. A(1,2)                          0.0157191    0.0068716      2.28756  0.02216303
16. A(2,1)                         -0.0791518    0.3584136     -0.22084  0.82521761
17. A(2,2)                          0.4041140    0.1105482      3.65555  0.00025663
18. B(1,1)                          0.8050431    0.0306167     26.29421  0.00000000
19. B(1,2)                         -0.0058133    0.0051301     -1.13319  0.25713322
20. B(2,1)                         -0.1306640    0.3039599     -0.42987  0.66728833
21. B(2,2)                          0.7970205    0.1404967      5.67288  0.00000001
My main interest in doing this is to see how the conditional variance of OIL affects the mean equation of the IPI.
To make sure I am reading the output correctly, coefficients 1-5 are for the mean equation of OIL and 6-10 for the mean equation for IPI.
Also, 5-21 are for the conditional variances covariances.
They way it is constructed, what is the coefficient I am looking for? It must be coefficient #7 as OIL is the first variable and equation defined and IPI is the second so that
coefficient #7 gives the effect of the conditional variance of OIL in the IPI mean equation.
Am I right?
Thank you so much!
PERRY
Postby TomDoan » Mon Aug 08, 2011 2:08 pm
Because of symmetry H(2,1) and H(1,2) are the same, so you should leave one out of the regressor list. As you have this set up, yes, the effect of the variance of oil on the mean of IP is coefficient 7.
Return to ARCH and GARCH Models
Who is online
